April 05, 2025, 12:07:33 am *
Author Topic: SQ inconsistency  (Read 38184 times)
Marcin_gps
« on: December 05, 2010, 10:38:29 am »
Have you ever wondered why your PC 'sounds' better one day and worse another and this is without making any changes in player or OS?
Well, here's a clue - ever heard of system timer resolution? The default value is 15.6ms, but some applications can force the windows timer resolution e.g. Media Player, iTunes, WinAmp, Flash all set the timer resolution to 1ms. The interesting thing is that this change is global  so all applications get the new high resolution timer while one of these applications are running. So gentlemen, start your browsers with some lightweight flash content and play some tunes Happy How crazy is that?
You can view your system timer interval with that small tool: http://technet.microsoft.com/en-us/sysinternals/bb897568.aspx
start it from CMD
Peter, you should be able to set the timer in XXHE as well.
Marcin
« Reply #1 on: December 05, 2010, 11:33:58 am »
Nice Marcin. I didn't know it could be changed.
As far as I know this can't influence Engine#4. I think it can influence Engine#3. Not sure though (yet).
Now don't tell me we will increase SQ with this, somehow. Happy
« Reply #2 on: December 05, 2010, 11:39:33 am »
A bit of Googling later ... Yes, I think it can ...
Marcin_gps
« Reply #3 on: December 05, 2010, 11:53:39 am »
I'm on Engine#3 anyway and Josef's player - it matters Happy And in Vista you should be able to squeeze 0.5ms.
« Reply #4 on: December 05, 2010, 11:13:51 pm »
Marcin, thanks for this.
I can get down to 0.9ms by playing a flash demo on the net. But this has sound, so is obviously pretty useless when I want to use JPlay. Can you recommend a site with some "lightweight flash content" that I could try?
Marcin_gps
« Reply #5 on: December 06, 2010, 12:03:23 am »
apple.com ? I use safari browser and that's my start-up page.
« Reply #6 on: December 06, 2010, 12:11:22 am »
Hmmm, I can't get low unless I'm playing a video. 'Apple.com' doesn't help. But in any event, it should be possible for Peter to implement something, if other (WASAPI) players can do it.
Marcin_gps
« Reply #7 on: December 06, 2010, 12:26:06 am »
It can be done up to 0.5ms, that's for sure Happy
Raj.V
« Reply #8 on: December 10, 2010, 04:51:35 pm »
Marcin,
well done and thank you again! Wink This really works.
I use special-KS : engine 4 and the SQ change is way out of the placebo range.
Please keep us updated if you can get it to 0.5ms.
I just start DPC latency checker, stop it and minimise it so that I don't have to see it --> Clockres is 1ms.
Now, I know why XXHE sounds better when latency checker is "on".
possible to include it in the next version... ?
Raj
XXHE/Ramdisk 1G, Q(-1,0,0,0,0), Special (256), 4xArcP, Non-Invert, Peak Extend, Unattended-Services Off, Core Appointment - 1, Player priority - Lowl, Thread priority - Realtime, Split File size - 75MB, Vista 32Bit Home Premium Laptop (C2D) -> HiFace
« Reply #9 on: December 10, 2010, 05:42:29 pm »
Raj, thanks for your little trick here. There is a definite improvement in sound in my system. Less HF 'hash'.
And thanks Marcin for the headsup in the first place.
Mani
« Reply #10 on: December 10, 2010, 06:22:13 pm »
Hi Raj,
What about the "minimise it" ?
As far as I'm concerned just quitting it leaves the system with 1ms ...
Not with you ?
What not ? haha.
So Yes. Still have to do it, but it can be done.
Raj.V
« Reply #11 on: December 10, 2010, 06:48:21 pm »
I tried closing DPC Lat. checker and the clockres resets back to 15.6ms - SQ accompanying.
FYI.
Raj
« Reply #12 on: December 10, 2010, 06:56:43 pm »
Hmm ...
Btw, mine is default at 5ms; maybe it's related.
« Reply #13 on: December 10, 2010, 07:20:20 pm »
Ahum ...
Russ, Man of Down Under Latency World Records ...
I am sorry, but I just broke your record of 1 sample of latency. That is ... wasn't yours at 96KHz ? or was it 192KHz perhaps ?
Anyway, mine is now 1 sample at 352.8Khz (32 bits output) I guess 384KHz will work too.
How are you going to break that eh ?
I just tried it on The Moody Blues (does that matter ?) for a couple of minutes, Attended and with a bunch of tasks open, and maybe I'm afraid to let it go like this. Maybe I heard one or two ticks as well. But I'm sure you won't care ?
whistle
« Reply #14 on: December 11, 2010, 03:22:54 am »
 unhappy
Enjoy wearing the crown Peter Happy It's lined with kangaroo fur so it should keep your head warm this winter .. haha
I can use 1 sample at 96Khz, but need 6 samples minimum to get clean playback at 176.4Khz.
I also found running DPC Latency Checker dropped the system timer interval to 1.0ms. DPC doesn't have to be running, merely loaded, so I click "STOP" after load.
Russ (former champion)
[Now playing... Melody Gardot - Live in Soho]
