April 07, 2025, 02:51:47 am *
Author Topic: where to attenuate?  (Read 30015 times)
« Reply #15 on: January 13, 2011, 08:55:10 am »
1) 100
2) 100
3) 100
4) 90 (without neighbours Happy)
But when 3) is XX, you can do it there *too*. Just try it; it matters (for the better). Could be -6dB, -12dB.
Also notice that since this is perfectly allowed (I say and claim), you can use the Normalized Volume from XX just the same.
Btw, if 1) and 2) allow you to actually control the volume (when XX is used), something is not right. Unless the HD2 has a volume control of its own, and is connected to the Windows volume *slider* (slider only, not the Windows volume itself).
HTH
« Reply #16 on: January 14, 2011, 04:50:10 am »
Never heard this before. Started with -6db and then -3db. Very nice. Thanks!
gonzalito
« Reply #17 on: January 14, 2011, 02:45:46 pm »
1) 100
2) 100
3) 100
HTH
So, (3) being XX, is it better not to reach the 100%?
Thanks.-
Audiotrak Prodigy HD2 Xtreme > SSV Audio PURE Interconnects > Topping TP20 > BlueJeans 5T00UP cables > Accorde Mentor speakers
« Reply #18 on: January 14, 2011, 04:21:36 pm »
No, that's not what I'm saying. Happy
It's the other way around :
Analogue volume works (very) different from digital volume, and not for electrical reasons only. As a matter of fact, I don't like the way it works at all. This by itself means you should leave out the analogue volume, BUT, this is not what you want or at least asked for. But there's also a way in between : take a little part of the attenuation for digital, and leave the remainder for analogue. If I am right you will perceive a better sound, while you still have the volume control with that nice knob. Plus you are protected against static, might it happen.
PS: But I don't use analogue attenuation at all. Only digital (and only from XX).
« Reply #19 on: January 14, 2011, 04:38:07 pm »
Okay, let me make sure I have this right: If you have an integrated amp (analogue volume control on the amp) you should not keep the XX digital volume at 100%. Rather back XX volume off a bit and you should perceive an increase in SQ, which is what I did last night for the first time and it sounded better than ever before.
If your amp is not integrated take your preamp out of the chain (analogue volume control) and just use the XX digital control: this is best.
My amp is integrated but I've bypassed all the controls (balance, treble, bass) except volume. It only puts out 17w per channel, so reducing the XX digital volume by -3db sounded best for me.....a significant improvement to be sure.
« Reply #20 on: January 14, 2011, 04:46:11 pm »
But with some context : The DAC must be able to drive the interlink (lenghts) and/hence the impedance must match. DACs are not always made for that.
