November 23, 2024, 05:17:12 am *
Author Topic: 9z-3 Invalid Exception  (Read 9056 times)
wushuliu
« on: October 27, 2010, 07:25:20 pm »
When trying to install z-3 I still get the same error I would get with z-2, except before I figured out how to bypass (might have changed the compatibility setting to XP or something). Now the most I get is: It lets me install ONLY when selecting Admin, but then I get a something not registered error and Engine 3 won't start. The GUI comes up but Engine 3 error. If i deselect Admin in xxHE properties, I just get the Exception error and nothing else... this whole setup shenanigans is really starting to irritate me... unhappy
Custom PC w/ 560 AM3/8GB/30GB SSD/Win7x64/Antec Earthwatt;Dacport LX; SimpleSE Tube Amp; Mark Audio Alpair or EL70 Fullrange w/ 8" Usher
« Reply #1 on: October 28, 2010, 09:00:11 am »
To be honest, me too. But I am sorry for *your* problems.
What happens when you shut off UAC ? BUT :
I estimate this is about this small install ("Phasure OCX") and first you'd have to uninstall that (Software/Programs). If you now put XX in a new folder (!) and run XXHighEnd again (but UAC disabled !) for the first time, the install will go with uplevelled rights.
If this doesn't help, can you show me a picture of that "something not registered" error or decsribe it in full otherwise ?
Did you maybe disable services for Diagnostics ?
Sorry for your problems, but I guess it is all still for the better. yes
wushuliu
« Reply #2 on: October 29, 2010, 04:12:50 am »
Actually I do have a win7 optimizer running that may have services disabled.  I will turn off and try again...
wushuliu
« Reply #3 on: November 02, 2010, 07:32:42 am »
The Win7 optimizer appears to have been the problem and 9z-3 is up and running... very happy
« Reply #4 on: November 02, 2010, 08:24:10 am »
Thanks for letting know.
For a next person, which "optimizer" was that ?
« Reply #5 on: November 02, 2010, 09:09:35 am »
Its best to stay away from any so-called optimizers, cleaners and scanners etc.
some are even counter-productive if you do not know what you are doing, or not know what the software exactly does
for eg.
- indexing
- bootoptimizers
- prefetch
are called optimizers too, while we DO turn them off.
2c
Roy
wushuliu
« Reply #6 on: November 02, 2010, 09:58:17 am »
I used Vista Services Optimizer. I know my way around services.msc pretty well, but am getting lazier in my old age. Other than the 9z-3 install, it did its job well.
