November 23, 2024, 08:38:50 am *
Author Topic: 0.9-z3 crahses under XP  (Read 12992 times)
JoaquinM
« on: October 26, 2010, 03:27:15 pm »
Well, I have upgraded from Z1, and now the program crashes and no sound is produced. I am running Windows XP.
« Reply #1 on: October 26, 2010, 06:11:03 pm »
Could you provide me with a little more information ?
Crashes when exactly ? what is the message ? (a screen copy would be best).
Thanks (and sorry),
« Reply #2 on: October 26, 2010, 11:19:49 pm »
FWIW,
I'm running 9z3 under XP with no problems (or actually with the usual XP playerwindow redering quirks) at this moment.
regards, Coen
« Reply #3 on: October 27, 2010, 07:04:41 am »
Call me ignorant, but ...
which are ? Maybe open a new topic for it, post a picture of it, and hopefully many more people come up with their "render problems", because I have the feeling there is just more than I know ...
« Reply #4 on: October 27, 2010, 01:15:31 pm »
On second thought there is more to the latest versions of XX not working on XP.
The PC on which XX runs fine is unupdated-no-internet-stand-alone dedicated music system with stripped XP SP3 (started as is from the MS disc).
My fully updated and untweaked XP (SP3+) internet HP P4 3Ghz laptop which is used for everything else than music playing has a XX 9z2 install that does NOT work and occasionally crashes the system. Since I don't play any music on this system I allmost forgot. Didn't get really into this problem but it might be related to the crash of JoaquinM.
I will try a remove/install of XX to 9z3 and make an update of the .net framework. Could also be that some kind of XP patch does not like to work together with XX.
I will make some screen dumps of the window quirks (maybe tonight). Basically the XX playerwindow does *unfortunately sometimes* not allow for resizing, It stays just the same surface, yet not showing the windowpart that is outside of the original surface. Any buttons that are not 'in sight' cannot be controlled either. Backsizing after this happened seems impossible. Also after a move *again sometimes* the windowbuttons (right uppercorner) are covered and do not respond anymore. Rebooting usually helps.
regards, Coen
JoaquinM
« Reply #5 on: October 27, 2010, 02:37:47 pm »
The program starts. Then I push Play, and nothing happens, ´til I receive the following message (I´m translating):
"xxengine has detected a problem and must shut down..." etc.
Some seconds later another window opens that says:
"Fail!
Engine 4 did not start within the expected time!"
The fact is, the program is still open after all this, and I even can edit the settings or choose tracks. But every time a try to Play, the above happens.
JoaquinM
« Reply #6 on: October 27, 2010, 02:45:43 pm »
BTW, I have just tried 0.9-z2 and it works fine...
« Reply #7 on: October 27, 2010, 02:47:42 pm »
Joaquin, thank you.
Notice that XXEngine3.exe is another program from XXHighEnd.exe. Thus, it is not XXHighEnd crashing, but the audio engine;
The most common reason would be Out of memory.
Please set your Split File Size parameter to 12 (the lowest) to begin with (later you may increase it again). If that doesn't help, next edit the SFS.ini in your current XX folder, and change the 11 you see in the beginning of the file into 00.
Let me know what happens. After that we will see further.
PS: Now I think of it ... might the 11 change into 00 help, you may have some services shut down which are needed for 0.9z-3 (diagnostic stuff).
didierG
« Reply #8 on: October 27, 2010, 11:34:50 pm »
Hello
I had the same problem (XXEngine3.exe crashes on XP SP2), then I tried to reinstall XXHighEnd (after restarting my computer) and now it works. If it can helps, once installed the first time, there was something wrong with the engine setting, which was set to #3 engine instead of #4 engine, whereas the selected device was a KS one (KS:Lynx AES 16e...). It was not possible to force it manually to #4 engine.
regards
Didier
« Reply #9 on: October 27, 2010, 11:55:02 pm »
I think this may still be the proper thread to post the results of my experiments on my laptop after I installed 09z3.
Fortunately I experienced no crashes, but it isn't working either...
(also not for 09z3)
The problem is actually exclusive for all 09z versions, all 09y50x and before run fine.
After the usual messages the XX-window starts and looks fine with all buttons, playlist and coverart nicely, however than some inconsistent behaviour occurs:
 Sometimes I can 'push' buttons or select pulldown items for a half minute or so and it all works like it should. After that suddenly any 'push' takes ages to react (>30seconds, if ever). The same holds true for resizing, moving is no problem. Closing the window (very fast reaction), killing the .exe task and starting again gives a new short time (does not seem to be consistent) to push a few buttons. It is not related to any 'button' or menu, because the stalling also occurs when even none hase been 'pushed' before.
Never got it to play any music though (no XXengine#3 in the task ever appeared).
Looks like some window component introduced in 09z does not work properly. Any clue???
One extra thing I found and may/may not be related is that I cannot activate any XX version on this PC with the code I use for my music server...
« Reply #10 on: October 28, 2010, 08:49:20 am »
Coen - Thanks.
I recall that similar was happening with the first 0.9z version, and that people could solve that (the slow response) by switching off logging. Does that help for 0.9z-3 perhaps ?
I will send you a PM for the Activation Code.
« Reply #11 on: October 28, 2010, 12:25:34 pm »
Okeeeh,
Now I remember there was an issue with the logfolder not being present (or made for that matter). Will try that tonight!
Off topic: Those 9y versions actually don't sound bad at all (not a surprise: they never did!).... Will compare them for fun with 9z3 on RAMDisc @ the 'improved' music server.
regards, Coen
« Reply #12 on: October 31, 2010, 08:57:36 am »
Can I ask, what came from this ?
