November 26, 2024, 02:01:27 pm *
Author Topic: Tracks with strange letters  (Read 23554 times)
Flecko
« Reply #15 on: October 27, 2010, 10:21:24 am »
Well Adrian, you better give me the literal name, because all keeps on working here with my own creations ...
Try: "10 Müde - Subway To Sally.wav" or "01 Böses Erwachen - Subway To Sally"
The umlaut must be within the first 7 letters.
« Reply #16 on: October 27, 2010, 10:38:08 am »
Ok thanks.
I was just reading it all back, but now I'm confused about whether it's an MP3-only problem or a WAV-only problem; you start with MP3 (first post) but later dedicate it to WAV ?
Flecko
« Reply #17 on: October 27, 2010, 01:44:58 pm »
No, it is a WAV only. mp3 works. I tried a certain mp3 later and was surprised that it worked suddenly. I checked the wav again and it did not work. So, WAV files have this error.
« Reply #18 on: October 27, 2010, 01:51:58 pm »
Better send me such a file Adrian. Both titles work here. But regarding that "header" message I think it is related to WMP rips or something, those "officially" being wrong -but XX deals with it-, and during that "deals with it" process something might go wrong. But in fact I don't understand.
Looks like you have the "Jarek" problem now, which I also never could mimic (files sent and all).
Flecko
« Reply #19 on: October 27, 2010, 04:39:58 pm »
Strange thing...computers... scratching I will make an upload and send you the link in a pm.
thx
« Reply #20 on: October 28, 2010, 10:36:38 am »
Ok Thanks.
The Greek one is solved and needed the same application (but now for MP3) I ever made for that "Jarek problem" for FLAC.
The Umlauten ? beats me.
I know you said this is since 0.9z-3, but you do have your DOS 8.3 Short Names active, right ? (http://www.phasure.com/index.php?topic=982.0)
Flecko
« Reply #21 on: October 28, 2010, 10:54:03 am »
Great! Thank you.
Can I check, if I have the names are active before I do the trick? Sould be active I guess, I have a normal W7 Ultimate installation.
« Reply #22 on: October 28, 2010, 11:27:37 am »
I guess if you open a Dos box (Run CMD) and have a folder like MyMusicCDs and you perform CD MyMusi~1 and you end up in that folder, it works. So, this needs a name of more than 8 characters, and the last two must be replaced with ~1 (or ~2 if it's not unique).
But I guess it's allright. I'm just trying to think of what can be causing this at your place.
Flecko
« Reply #23 on: October 28, 2010, 01:31:42 pm »
This works.
If you got an idea, let me know, I will try.
Page created in 0.152 seconds with 19 queries.
