April 05, 2025, 01:37:24 pm *
Pages: 1 2 [3] 4 5 6 7 8 9 10  All
Author Topic: 9-Z3  (Read 148619 times)
« Reply #30 on: October 28, 2010, 09:18:22 pm »
SFSfile setting: 21 (comments hold for all 2x settings)
Compared to 11: Much more gentile presentation (less distortion?) aslo less 'dark' and 'heavy', more focussed and smaller, easier to follow the singers text and individual instruments, in general easier, yet less compelling to listen to. Didn't try this one @ high loudness.
Playing for an hour like this (SFS.ini = 21) but if this isn't true I'll go to some doctor tomorrow.
I'll admit I had a theory while developing it, but I really never tried it.
At least it loads the first playback faster (3 or 4 times of what I recall at measuring it back then).
Marcin_gps
« Reply #31 on: October 28, 2010, 10:07:59 pm »
Peter, could you schedule an appointment for me too? haha
Indeed, SFS.ini = 21 is better. Great dynamics!
« Reply #32 on: October 29, 2010, 12:09:07 am »
I think you have really pulled a rabbit out of the hat with z3, I cannot stop smiling whilst listening, many thanks.
Marcin,
I agree ini setting of 21 gives terrific dynamics.
IMHO I agree with earlier posts that ini 11 sounds clear and tonally staifying but is a little down on dynamics and slam in the low and mid range (still fantastic great overall though). Ini 21 is very dynamic I think system tuning effort will concentrate here for now.
I haven't posted on z3 so far as I have been recommissioning my main system after 8 months of being mothballed after my house move. It's a bit disorientating right now trying to pinpoint what components are contributing what but z3 is absolutely shins through a NOS DAC, Gainclone amps and horns speakers.
Suteetat
« Reply #33 on: October 29, 2010, 01:09:14 am »
I need to ask a stupid question regarding editing SFS.ini file ( 11, 21 etc).
I have absolutely no idea how to edit that unhappy
I suppose I need a little remedial help on this.
Thanks
« Reply #34 on: October 29, 2010, 05:10:35 am »
Thanks
I also had a little problem finding that but  you can find the .ini file in the folder of XX. Open that file and on the top change the 11 in 21 or something else.
Thats the trick i guess
« Reply #35 on: October 29, 2010, 05:25:54 am »
I will assume you are using Vista. Other O/S's will be very similar.
Highlight the SFS.ini entry in the XXHE folder using the left mouse button, then using the RIGHT mouse button to bring up the context menu, choose the "Open With..." option. You may be presented with Notepad in the list that pops up already, but if not, in the section underneath called "Other Programs" you should find it there. If you see nothing in that lower section you need to click on the little arrowhead to the right of where the text "Other Programs" is written.
If you still can't find Notepad , then you can use the "Browse" button to navigate to where it is located, which is normally in the main "\windows" folder.
If you tick the box labelled "Always use the selected program to open this kind of file", then next time you want to edit the SFS.ini, you need simply double click on it, and it will open in Notepad automatically.
Give that a try.
crisnee
« Reply #36 on: October 29, 2010, 06:28:34 am »
Hi Suteetat and others
An easier way to find notepad and many things, just start to type the name in the search box (Start button) and hit enter, or select it from the list that pops up. The quickest and easiest way to many things, particularly windows programs and things that live within the environmental paths.
Chris
Suteetat
« Reply #37 on: October 29, 2010, 06:45:30 am »
Thanks all for your help. I used notepad to look inside ini file before but was not sure if I could just use notepad to
edit or if I need a specific editor to do edit it. I guess that pretty much answer my question. Again, thanks all for your help.
« Reply #38 on: October 29, 2010, 09:06:34 am »
CPU usage with 21 peaks to 17% then comes to normal level (around 2%)
You mean : and after that (CPU being at 2%) nothing happens anymore ?
How long does this 17% approx. last ?
Is there a message "Engine#x didn't start wihing the expected time" ?
Nothing happens; there is no sound even if i wait for 2 mins. The spike on the CPU is only for a fraction of a second & there are no error messages. Everything happens as with SFS.ini=00, except there is no sound.
Hi Arvind,
If you are in the mood a bit, please post the X3 and XX log files after you are waiting for a minute or 2 with the 11 setting. Maybe I can see something in there.
« Reply #39 on: October 29, 2010, 12:05:10 pm »
I'm in a bit of a jet-lagged state, but I really like the sound of both 11 and 21. Right now, I'm leaning towards 21... but I haven't played around with SFS values, or with the new 'Do not Start Playback at all' feature.
In any event, 0.9-z3 sounds really, really great! Thanks Peter!
Tony S
« Reply #40 on: October 29, 2010, 12:37:43 pm »
Thanks! Peter for the 9-Z3 version. Sounding Good. I had a chance last night to try different settings and so far I'm liking SFS.ini at 21, 11 not too bad either but more towards 21. I am using Special mode with Scheme-1 and the SFS at around 70. CPU is running at 2-4% and the memory usage around 1.2 gigs. Bass seems tighter, better vocals and soundstage running deeper a bit wider now. Will want to try some other settings over the weekend. I do have some issues with some of the music sounding a bit harsh in the treble region but probably do to the cr*ppy recording, AC line noise, cheap dac, room acoustics, and not enough brew, otherwise the best sounding version to date.
Vista Basic, Usb ->Musiland Monitor 02 -> Parasound Amp ->2.5 way Vifa/Scanspeak.
Ver. 0.9z-2, Playerprio-Low, Threadprio-Realtime, Buffer 256, 2x Upsampling, Adaptive Mode, Arc Prediction, Scheme-3, Q1- 1/10/10/0/0, SFS 70, Unattended, Services Off.
« Reply #41 on: October 29, 2010, 01:34:24 pm »
Question do i still have to tick *Copy to XX drive*? Meaning load into Ramdisk.
« Reply #42 on: October 29, 2010, 02:06:01 pm »
Hi Arvind,
I am attaching the XX files with SFS.ini=21 & SFS=50. If I go higher than that the laptop stops responding. Hope it helps. X3 files are not created in the Temp Data folder.
* XX-20101029-171556.log (10.96 KB - downloaded 646 times.)
* XX-20101029-172101.log (3.87 KB - downloaded 697 times.)
« Reply #43 on: October 29, 2010, 03:02:42 pm »
Uhm Arvind, there's no explicit log entry for it, but it sure looks like you've set "Don't Start Playback at all".
« Reply #44 on: October 29, 2010, 03:06:16 pm »
Gerard, Yes. That is, if XX recides on the RAMDisk as well, otherwise it doesn't help (for copying music files to the RAMDisk).
