« on: October 26, 2010, 04:20:39 am » |
Well, after a quick listen it seems that 9-Z3, in all of its various SFS combinations, has lost a great deal of the midrange that my latest iteration of 9-Z2 is producing. Setting the SFS in the ini file to "00", which I believe is the same as 9-Z2, still leaves the Z3 midrange lacking. Its sorta hard saying this knowing all the work that has gone into Z3 and knowing that I am getting the very best sound I've ever heard short of a live performance on my current Z2 setup. I had both Z2 and Z3 on the RAMDisk and i had the SFS set to 98 in each.
« Reply #1 on: October 26, 2010, 10:12:03 am » |
Hmm ... strange. I would say the mid just got (much) better. But then I may be used to "something" for several months already ? (meaning something quite different from SFS stuff). Btw, think about the x1 setting (so 01, 11 or 21) allowing for a much larger SFS (Split File Size). I am not saying the various sizes should matter, but I found the setting 40MB under what it takes for maximum (260 -> 220 in my case) not showing any of the "there's something on top of it" I had before with very low and very high settings. But maybe I'm dreaming something. Also, you may try Scheme-1 with 0.9z-3. It really seems better now than Scheme-3 I always use.
Flecko
« Reply #2 on: October 26, 2010, 12:30:46 pm » |
First impression, testet both with the same settings I alwas use. The z3 sound is darker. This could have two reasons. 1.Bass improved. 2. Highs decreased. It seems mids and highs are quieter with z3. Something is missing. Bass und lower mids are dryer, have more punch and are more present with z3. I like that. z3 sounds a bit more focused as z2. I feel overall the sound has improved. THX Peter! Still prefering scheme-3.
« Reply #3 on: October 26, 2010, 12:38:25 pm » |
Darker would be my description. Or what about more "brown" for bass. To me this gives more reality (and variation) to basses. But I guess this is personal.
Flecko
« Reply #4 on: October 26, 2010, 01:01:24 pm » |
Darker would be my description. Or what about more "brown" for bass. To me this gives more reality (and variation) to basses. Jep, Darker. That was my first thought as I heard the first tones from z3. Agree!
Flecko
« Reply #5 on: October 26, 2010, 02:46:42 pm » |
You could try special mode and play with buffersizes and q1 value. It has a big impact. I tested z3 with the same settings as z2 and have also a loss of highs perceived. I tried some different buffersizes and q1 values. The sound changes very much depending on that. Bevor z3 I had buffersize 64, q1=1. With, for example, buffersize:32 and q1=6 I get very well defined highs and little less bass. I have not found the perfect settings yet but I think it is getting better than z2. Even in the highs.
Flecko
« Reply #6 on: October 26, 2010, 04:47:46 pm » |
So, for me it is done. z2 is ereased. Settings changed from buffer 64, q1=1 to buffer 32 and q1=6. The sound changed so dramatically with these settings, never got that before. Now it sounds really great! Very fast and clear highs! Like a magnifying glass.
ivo
« Reply #7 on: October 26, 2010, 06:10:25 pm » |
With this version should we set SFS to high values? I have been using previous versions with SFS=100. What is the legend here - higher SFS means better SQ? Or what?
Ivo
« Reply #8 on: October 26, 2010, 06:15:48 pm » |
No legend here (yet). I use 220 though, that being 40 under what my system can have (260) for playback. I think it sounds better when you're not near the limit. SFS.ini = 11.
Marcin_gps
« Reply #9 on: October 26, 2010, 06:27:08 pm » |
My initial impressions are that higher values sounds better, fuller. Scheme-1 works better too, as Peter mentioned. Scheme-3 is too smooth at the moment, while Scheme-1 is more resolving and lifelike. I won't update my sig yet, want to experiment more with the settings.
« Reply #10 on: October 26, 2010, 08:32:15 pm » |
Hi Peter, you have the great advantage to listen with the NOS1 and we are all playing music on total different systems, so everybody has to evaluate the SQ with his previous settings. SFS works best at 25 on my system, very fast response. 180 is very smooth. (engine 3, schema 3, Player prio: normal, Thread prio: realtime, Q1=5, others at zero. Firewire connection) All in all: best sound I've ever had on my system. Joachim
« Reply #11 on: October 27, 2010, 08:20:06 am » |
Hi Guys,
Tried out 0.9z-3 yesterday evening, my impression of the SQ is a bit mixed. Low bass has lost its tightness & has become a wee bit loose/diffused. Lower mids have improved significantly, more clear & softer, but the upper mids have become harsh. No significant change in the highs.
Peter: Tick sound at start of playback is not solved.
Marcin_gps
« Reply #12 on: October 27, 2010, 08:24:27 am » |
SFS.ini = 11 SFS = ~200
Try these
« Reply #13 on: October 27, 2010, 08:57:18 am » |
Try these
Tried SFS.ini=11 but it takes too long for playback. Maybe my laptop is very slow.
« Reply #14 on: October 27, 2010, 09:00:24 am » |
21 will be faster (this can really matter) and could even bring better SQ. I never tried it.
