Flecko
« on: October 14, 2010, 10:34:01 am » |
If you have gained sound quality with RAMDisk and the use of Special Mode, this might be interesting for you:
Since Scheme 2 is a little bit brighter than scheme 3, scheme 3 was the choice before the use of RAMDisk. But now, as things changed I experimented with the schemes and found, that with scheme 2 it seems to sound better. Especially the air between the instrumets is rendered finer. You have more the impression of instruments, playing in the same room. With scheme 3 the stage falls appart, compared to scheme 2. What do you think?
Edit: The bass seems to be better with scheme 3, more punchy and clear.
« Reply #1 on: October 14, 2010, 10:55:14 am » |
At trying for 30 sconds ... Ha ! it looks you are right !
Must listen longer for judgeing the bass to be less good, but it certainly is "less".
Flecko
« Reply #2 on: October 14, 2010, 11:05:12 am » |
I am not sure too. Bass seems really better with scheme 3 and dynamics too. Scheme 4 has more the Bass/dynamics as scheme 3 and might be worth to be listened to again.
Flecko
« Reply #3 on: October 14, 2010, 11:37:40 am » |
I might was wrong on this. It seems more, that scheme 2 softens the sound in a way that made me think it is finer. Tight bass should be a sign of low jitter, so this is a plus for scheme 3.
« Reply #4 on: October 14, 2010, 05:17:07 pm » |
Well, many hours of listening further on this side, Scheme-3 keeps on doing it for me. I must say, it varies a bit per album, but the highs are somewhat more "nasty" with Scheme-2. A Sax wants to be a trumpet more, that kind of thing. Also, bass is more tight with Scheme-3.
People, this will be very much depending on your PC. So just keep on listening for yourself. Peter
Marcin_gps
« Reply #5 on: October 14, 2010, 09:33:04 pm » |
Confirmed, Scheme-3 is the best!  BTW. I disabled some more hidden devices in device manager and applied the most recent optimisation from cics' site - the one responsible for reducing USB polling and guess what happened? I had to reduced the SFS to 50 MB, cause I found the sound too smooth and washed out of details. Now it's just great. I don't know if Mani's drivers work so much better that they don't interfere with other stuff or mine are hopeless. Anyway, this one is big, try!
« Last Edit: October 15, 2010, 06:42:36 am by PeterSt »
Marcin_gps
« Reply #7 on: October 14, 2010, 10:04:06 pm » |
   Yes, I did both at once so I don't know which was responsible for improvement. I'll update my topic once I'm done with disabling everything... haha, just kidding PS I wouldn't search for it, just try, it takes few minutes and you'll know. No harms done
« Last Edit: October 15, 2010, 06:43:17 am by PeterSt »
Marcin_gps
« Reply #9 on: October 14, 2010, 11:47:58 pm » |
« Last Edit: October 15, 2010, 06:43:57 am by PeterSt »
Flecko
« Reply #10 on: October 21, 2010, 04:07:31 pm » |
Well, many hours of listening further on this side, Scheme-3 keeps on doing it for me Sorry you spend so much time on this. I am using scheme 3 again too. But thanks for helping to disprove this! It realy depends on the music. With some track I thought it would be better with scheme 2 but at the end this is not "true". Tight bass and dynamics is better with scheme 3 and that is one hearable criterion for a better digital source, that's my experience at least. !  @Marcin and Josef I tried the tweaks on ciscs site about some month ago but meanwhile I have a new installation. If I want a pure-audio-setup I start with "msconfig" the debug mode. Very nice because most things are deactivated and you don't have to tweak your whole system. With dimr I get peak 2ms, I have a Logitech G5  But if the mouse rests it goes down to very differnt values (5-30ms). Does the ciscs tweaks go further than the debug mode?
