April 04, 2025, 07:48:17 am *
Pages: 1 2 3 4 [5]  All
Author Topic: IRQ CPU Affinity Setting  (Read 79025 times)
Marcin_gps
« Reply #60 on: October 29, 2010, 11:56:23 am »
Peter, could you tell me how to assign affinities of processes other than Engine3 to CPU0, so they wouldn't go back to CPU0,CPU1 and CPU3 every time I start Engine3? I don't want other processes to collide with my sound card driver, which occupies CPU2 and CPU3. Can I do this myself?
Greets,
Marcin
« Reply #61 on: October 29, 2010, 12:07:21 pm »
I think your only option would be to use Scheme "Nothing" and do it all yourself. But I'm afraid there's nothing available for that (like it is for the IRQs). So it would be a manual thing after each reboot plus you'd have to do XXEngine3.exe each time. Nothing much workable ...
blaine78
« Reply #62 on: March 27, 2011, 11:48:39 am »
Thanks for this advice. Has really made a BIG difference for the better here. much cleaner and focused, and yes, less jittery sound. Am using an i3 intel 2 core cpu with hyper threading disabled and having 2 real cores to play with. I have my audio player, USB audio driver and USB composite driver all running on the same one core rather than being split over 2. the difference is HUGE.
« Reply #63 on: March 27, 2011, 11:54:33 am »
Ha, nice wakeup of this topic;
Quote from: PeterSt
Well, since we're talking about 24 core systems by now (or 12 to keep it more "normally") this for sure will be in a next version now.
It's only one of the things which can be done ...
« Reply #64 on: March 27, 2011, 10:43:18 pm »
Quote from: PeterSt
Your proberbly aware but PCIE latency may be also be good place to focus in code as well. I'm finding a pcie latency of about 128 on the Jul@ card ( or usb interface for a hi face ) is worthwhile. Using a utility you can set the audio device to a different latency to other devices which run at BIOS default (often 32).
