November 23, 2024, 08:20:22 am *
Author Topic: No sound from 0.9z-1 and RAMDisk  (Read 7988 times)
« on: October 09, 2010, 01:12:45 pm »
Hi Guys,
I copied & pasted 0.9z-1 to Ramdisk, but I am not getting any sound. There are no error reports. When I go back to XXHE on my conventional C Drive it plays normally. Can anyone help me in what I have done wrong?
« Reply #1 on: October 09, 2010, 02:04:54 pm »
Should be your XX settings somewhere. Don't forget to look at Q1.
But generally ... wrong Sound Device selected ?
« Reply #2 on: October 10, 2010, 09:25:02 am »
All my settings are the same as XXHE on C Drive. Sound device is also selected correctly; still no sound through Ramdisk.
« Reply #3 on: October 10, 2010, 09:44:33 am »
Hmm ... I would say that technically it is impossibly that something makes a difference here ...
Make very very sure you are starting XXHighEnd from the RAMDrive (check the shortcut icon etc.). Or proove it by yourself by activating the Log files, and see whether the TemporaryData folder under the XX RAMDrive folder contains (new) log files.
And once the log files are activated anyway, you may look in the X3PB log files whether you see a difference with those from the normal C: drive. Or post them ...
Strange.
« Reply #4 on: October 10, 2010, 10:12:42 am »
I rebooted & suddenly XX is playing from Ramdisk, I dont know what happened but it works fine. Just for your info the Tick sound is still there.
« Reply #5 on: October 10, 2010, 10:24:32 am »
Ok, good. Still strange though.
