Marcin_gps
« Reply #120 on: October 12, 2010, 03:18:51 pm » |
Mani, ru using W2008 or W2008R2, cause they're completely different: W2008 - Vista W2008R2 - W7
« Reply #121 on: October 12, 2010, 03:59:56 pm » |
... pure from theory W2008 should be the better solution... You got me! Mani, ru using W2008 or W2008R2, cause they're completely different: W2008 - Vista W2008R2 - W7
Ah well, there's a story here. I had a few hours spare on Saturday - the wife was out with the baby (in the UK it's customary to refer to one's partner as 'the') and I thought, right, this is my chance to sort the PC out. I wanted to load Vistax64, but only had Vista32, so I went onto the MS website and installed a trial version of W2008 instead. I got it installed and carried most of the tweaks mentioned on this site. I had never heard anything quite like it before from PC playback - it was the most precise sound imaginable, but in a 'clinical' and 'overly analytical' way. After listening to it for a couple of hours that I thought something must be wrong. And guess what? It was R2! On Sunday, I downloaded the trial version of W2008 SP1, which is what I'm using right now. I have a full non-OEM licensed W2008 (with 5 CALs) on order, and it should arrive in the next couple of days. But I'm not going to be in too much of a rush to re-install it on my main machine. In any event, there's a huge difference in sound between R2 and SP1, the latter sounding so much more laid back and simply more listenable. Mani.
« Reply #122 on: October 12, 2010, 04:15:59 pm » |
Mani, ru using W2008 or W2008R2, cause they're completely different: W2008 - Vista W2008R2 - W7 Thanks Marcin.
« Reply #123 on: October 14, 2010, 11:43:07 pm » |
I think that the main differences are about graphics and network services - a slimmed version of either vista or 2008 server (not R2) should sound both good. I definitely decided to go back to Vista, need a SSD, though, i dont wanna load the OS on a spinning disk. How is it going, Roy?
Marcin_gps
« Reply #124 on: November 02, 2010, 05:07:19 pm » |
My attempt to enable memory above 4GB in Ramdisk (dataram) failed, I get a lot of BSODs, so gave up, but I tried different software, according to performance comparison that I found - the best. It's VSuite Ramdisk server edition. Not only I can use 8GB of RAM (4GB for Ramdisk) on 32bit OS, but I'm sure it improved SQ over Dataram Ramdisk.
« Reply #125 on: November 02, 2010, 05:13:48 pm » |
My attempt to enable memory above 4GB in Ramdisk (dataram) failed, I get a lot of BSODs, so gave up, but I tried different software, according to performance comparison that I found - the best. It's VSuite Ramdisk server edition. Not only I can use 8GB of RAM (4GB for Ramdisk) on 32bit OS, but I'm sure it improved SQ over Dataram Ramdisk. How much does it cost the server version?
Marcin_gps
« Reply #126 on: November 02, 2010, 05:15:51 pm » |
$99 but you can try it for free and use 15 days
« Reply #127 on: November 02, 2010, 05:21:28 pm » |
$99 $119 for the 64 bit version. Did you try also the standard one http://www.romexsoftware.com/en-us/vsuite-ramdisk/ramdisk-comparison.htmlThe main difference performance-wise seem to be only the overlapped I/O. Edit: nevermind, it's limited to 4GB, does not match my idea of having 16GB of ram 12+ of which used by the ramdisk.
Marcin_gps
« Reply #128 on: November 02, 2010, 05:55:23 pm » |
No, it's not limited to 4GB and you don't need 64bit OS in order to use memory above 4GB (PAE enabled) Ramdisk size can be up to 2048TB.
« Reply #129 on: November 02, 2010, 06:52:18 pm » |
Marcin_gps
« Reply #130 on: November 02, 2010, 08:38:38 pm » |
Yes, I see it and there's exactly what I quoted before. And I know that it works, because I'm using it right now on a 32bit OS. Do I have to make a screenshot or what?"
Marcin_gps
« Reply #131 on: November 02, 2010, 10:56:03 pm » |
« Reply #132 on: November 03, 2010, 12:15:51 pm » |
Assuming this "overlapped" springs from several requests at the same time ... the only part in XX where this would happen is during the conversions (read and write). However, they are not all so much I/O intensive (it's not "copying" only) so the chance that several requests exist at the same time is not that large. This makes the "base" operation slower (because that Overlapped support causes overhead to begin with).
In either case you won't gain a tenth of a second on even a large transaction anyway. So I wouldn't bother.
Marcin_gps
« Reply #133 on: November 03, 2010, 05:29:37 pm » |
Thanks
« Reply #134 on: November 03, 2010, 10:04:52 pm » |
What I meant is that only the server version can use more than 4GB, that is for my purposes it's the only version i would use, so i would have to pay 120$, which is not trivial. I'll try to A/B using the trial version. You can have two ramdisks running at once,right? this and the dataram one.
