November 22, 2024, 09:49:31 pm *
Pages: 1 2 3 4 5 6 7 [8] 9 10  All
Author Topic: RAMDisk  (Read 140298 times)
« Reply #105 on: October 11, 2010, 06:03:08 pm »
I'm happy as it is.
What RamDisk software do you use?
Hi Johan. We all use this : http://memory.dataram.com/products-and-services/software/ramdisk (Dataram RAMDisk), except maybe for a few experimenting with other manufacturers.
« Reply #106 on: October 12, 2010, 10:31:27 am »
Reading through the manual for RamDisk I noted that if you are using a 32bit version of Vista/Win7 , that RamDisk will utilize any memory above the 4GB limit normally restricted to. Great I thought, stick in another 4GB in the spare mem slots of my m/b and I can then have my cake and eat it too !
Turned out this wasn't such a joyous endeavour. I have just spend several hours phutzing around trying to get RamDisk working with that additional RAM but have been unsuccessful.
I'm currently playing under 32 bit Vista with SP2 installed.
The issue arises when asking RamDisk to load the saved image at a reboot. I could never find a combination of settings that allowed this. It would create a RamDisk from scratch without issue, but as soon as you requested a reload the system would start to load but then die and kick you back to POST. A jump into SAFE MODE to delete the image file and change settings for RamDisk were the only way of continuing.
In the end I've gone back to working with a 1.5GB Ramdisk using mem under Vista's immediate control. This is sufficient to load 2 albums at a time, which is usually the most I ever do.
I would be interested to know if anyone running 32bit versions of Vista/Win7 with MORE THAN 4GB MEMORY, has been successful in getting RamDisk working correctly using that additional memory.
Also, those running 64 bits versions with more than 4GB ram installed, are you able to create RamDisks up to 4GB OK that survive a reboot intact?
Hi there Russ,
I wondered ... Did you ever try to load/create the RAMDisk (of 4GB under 32 bits) just after the reboot ?
« Reply #107 on: October 12, 2010, 10:53:00 am »
Hi there Russ,
hey there Pierre, I may not have ever tried pressing the actual "LOAD" command from within the GUI itself just after a boot. I was simply trying to get the automation happening correctly, but alas, it all kept dying. It would certainly CREATE a RAMDisk OK though with the extra memory.
It's all a moot point now anyway, as I installed Vista X64 and that all works just dandy. Takes a while to write the image out at system shutdown though unhappy
« Reply #108 on: October 12, 2010, 11:18:50 am »
Yes, for you that is. swoon
« Reply #109 on: October 12, 2010, 11:56:02 am »
haha ... I thought that might have been the reply.
Tell ya what, I made a full system backup of my Vista 32 environment just before switching to X64, and I'll restore it to a harddrive and check out the ability to do an actual LOAD command.
It means working through my supper time, but anything for a good cause  whistle
Back shortly.
RGB
« Reply #110 on: October 12, 2010, 12:08:00 pm »
Thank you Russ. I guess it is a matter for those (like me) getting an additional 4GB of memory, which is not very much useful if it doesn't work anyway.
But now I think of it ... did you take into account the max amount of ram (something like 2,5GB) the RAMDisk program supports without payed license ? If not, that may be your (reboot) culprit ?
« Reply #111 on: October 12, 2010, 12:36:28 pm »
RAMDisk supports 4GB without a license. I'm hoping to use it @4GB as soon as my extra 4GB arrives (should be tomorrow).
« Reply #112 on: October 12, 2010, 12:56:25 pm »
DOH !  I don't know where I read it, but it sure says 4GB. My bad. Sorry.
« Reply #113 on: October 12, 2010, 12:59:13 pm »
Back shortly.
nup ... still no go. The reason I didn't try a manual image load is there isn't an option to do that after reboot as I discovered.
The system dies during the left/right/left green "Night Rider" lights phase of the boot process, and kicks me back to POST.
As I said in original post, everything works fine if you don't tick the "use memory above 4 GB limit" which is on the "advanced" tab that appears when you have more than 4GB installed.
I suppose a few batch jobs could be set up to copy the contents from the ramdisk to somewhere just prior to shutting down, and a similar one used to restore those files following a successful boot, but I would have thought that unnecessary if the program worked as intended.
Surely there must be someone else out there running Vista 32 with more than 4GB ram installed, to re-affirm this bug?
« Reply #114 on: October 12, 2010, 01:17:17 pm »
Thank you Russ.
But does this imply that the "4GB outside of the OS" just works ? (IOW, use 3GB under the 32bit OS and in the mean time have the ram disk of 4GB)
« Reply #115 on: October 12, 2010, 01:33:05 pm »
YES , creating an empty Ramdisk of up to 4GB works fine.
Josef
« Reply #116 on: October 12, 2010, 01:37:39 pm »
[/quote]
It is my understanding that you'd need Win Server Datacenter or Enterprise edition in order to be able to use more than 4GB.
But why bother with 32-bit versions? 64-bit has no limit plus you get back RAM that your GPU may have 'stolen' (Half a gig in typical case).....
« Reply #117 on: October 12, 2010, 02:19:15 pm »
Because many coincidentally don't have that running ?
I know that many of you make it a sport installing OSes, but I don't.
« Reply #118 on: October 12, 2010, 02:52:37 pm »
Haha...
Many of us were perfectly happy with W7 (ignorance is bliss) until you came along and told us to change back to Vista. But I was never going to do what you said, hence why I've ended up with W2008! Happy
Hopefully we (myself included) can all just calm down now and systematically work at optimising Vista - it looks like we'll be with this OS for a while...
« Reply #119 on: October 12, 2010, 03:12:19 pm »
Ahum ...
All,
I thought of it before, and now think I really should mention it :
While we're debating about W7 vs. Vista - or may think by now that Vista is the solution - pure from theory W2008 should be the better solution;
It is Vista, it is more lean, it is more decent/stable, it is more towards "server" activities (hence less fancy stuff), *and* those who tried it, were ever so enthusiast; I didn't do it, but I guess a search for "2008" may come up with some posts about it.
I am sorry if this comes as additional confusement to you, but better late than sorry.
You said what ? hahaha
