« Reply #390 on: December 24, 2010, 12:31:12 am » |
Hey Marcin, this SP1 fell out of the sky like a christmas-star? Where can we find this or just google? BTW. Since you're at the front of computer-sound-experiments, would you be so kind to share your findings? It would be nice if us NOS1-less suckers can have the best possible sound for our Christmas-songs!
Flecko
« Reply #391 on: December 24, 2010, 01:21:01 am » |
Insert Quote Hey Adrian, Currently I am listening to W7 again (after being used to Vista for some two months). The difference (nothing much different from what I described back in December 2009 and indirectly what I wrote in the beginning of this topic, but now looked from W7 again) :
Thanks you took time to listen to it again. How did you set up the installation? Same PC, same settings just a different partition? Generallly it is more rough. Just not clean. But careful now, because the sound I have here may be described as the most clean (it's not only me saying that anymore, and it's just the NOS1), so everything which is not jumps out.
Furthermore the sound is somewhat more dynamic (maybe not good) and the bas is generally less fuzzy (good), seems more tight (stiff). Maybe there's more slam too (would be the same as the stiff bass). Ok, I will listen to this sound signature. OK. I'm looking forward to your findings about SP1 than. I will give this a try after we discussed the normal version. Thanks!
Flecko
« Reply #392 on: December 24, 2010, 01:21:38 pm » |
Today I got a new CD. Very good recording, so I started again to listen to Vista. And yes, today I hear a difference. Sound for W7: Harder more emphased highs. Tighter more controlled bass More dynamics and transparency (could be because of the harder highs)
Sound for Vista: More relaxed/analog highs. Softer. Bass is not as precise. Muddier.
would say:Vista is for the tube guy and W7 for the transistor guy. or: Charakterristics of vista z3 sounds a little like w7 with z2
@Peter: Try SFS.ini 01 with w7. 21, 11 sounds to emphased on the highs.
I like to see where things go with SP1...
« Reply #393 on: December 24, 2010, 01:31:34 pm » |
Well, isn't that great Adrian ! (if you only didn't copy my words, hahaha).
So I suppose this is helping eachother (as said, -thus- for the better).
I must honestly say that I liked the "more freshness" of W7 yesterday, but some things disturb too much.
I've downloaded SP1 (RC) already, but first there's normal (DAC) wordt today. So, later. But I sure am curious (thanx Marcin).
Flecko
« Reply #394 on: December 24, 2010, 02:55:24 pm » |
So I suppose this is helping eachother (as said, -thus- for the better). Jep, it realy looks like this  But I think that is how it sounds. I spend more time defending myself than to listen to vista and w7. And it needs some time to get rid of expectations to really listen. Maby it needs a good mood too. I excpected a big change and it didn't happened. If my amp and dac is cold, vista could sound nicer but after 1-2 hours of getting warm, it is just right with W7. Maybe I should check vista again now... I must honestly say that I liked the "more freshness" of W7 yesterday, but some things disturb too much. That is the problem. Every day one hears the things a little different. Did you tried sfs.ini 01? It has just the right balance in the highs.
« Reply #395 on: December 24, 2010, 03:02:14 pm » |
01 ? ah, no. But I will.
« Reply #396 on: December 26, 2010, 03:33:13 pm » |
I got the Windows 7 SP1 RC release here: http://www.blogsdna.com/13301/windows-7-service-pack-1-rc-released.htmThe sound is great though I have not done a direct comparo with Vista....yet.
« Reply #397 on: December 28, 2010, 02:43:04 pm » |
Windows 7 SP1 RC is much better than original W7. After several days of listening am sorta blown away by how good SP1 it sounds! Is it better than Vista? May be a matter of taste but it has a clarity and transparency and warmth (sfs ini @ 00) that I'm liking more than my version of Vista. Thanks again Marcin!
« Reply #398 on: December 28, 2010, 06:21:47 pm » |
Me happy having a dual boot.  Marcin really thanx i like W7 with SP1 better than Vista. Sounds great! So it is W7 time again!! Like that better then going back to spinning disk.
Chriss
« Reply #399 on: December 28, 2010, 07:05:38 pm » |
I just want to say...GO GO MARCIN!!! No metter which OS is bettter I appreciate the Columb passion for discovering and searching!!! Once again Thank you Marcn for sharing no matter is it good or bad that's the way we improve and discover the world! P.S. Let's call him our digital Columb!(no joking!) Kind regards, Criss.
Marcin_gps
« Reply #400 on: December 28, 2010, 07:07:03 pm » |
It's definitely better, enjoy
