April 02, 2025, 10:32:19 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27  All
Author Topic: We all fell in the W7 pitfall  (Read 407627 times)
Chriss
« Reply #285 on: November 07, 2010, 11:30:34 am »
I'm sorry but Win98 is cr*p Happy
True! Question to Peter, is it possible to run XX on Linux(I'm sure you already answer it but can't find the topic). I've been trying few Linux OS and music program on them but...didn't like them!
Regards, Criss.
« Reply #286 on: November 07, 2010, 12:02:02 pm »
W2K would be an option though ... Happy
Criss, no, no Linux. Maybe sometime (when this small part is really finished), but it will really need a complete rewrite.
I've heard Linux implementations too, and didn't like them either. no
« Reply #287 on: November 07, 2010, 09:38:39 pm »
Hi Marcin_gps,
Hello everybody,
I think I'm gonna try XP one more time - slimmed&tweaked, minlogon etc. I remember I didn't like it some time ago, but now with new version of XXHE, Ramdisk and CPU affinity masks, it could be interesting... Maybe it's not too late and not everyone switched to Vista... haha
XP has one (among others) interesting option - it's called timeres and it allows to decrease 'waitable timer' from default's 7.8ms to 0.98 ms
Anyone using XP and Vista on the same machine?
Greets,
Marcin
Are these posts related?
regards, Coen
Marcin_gps
« Reply #288 on: November 08, 2010, 07:34:31 am »
Hi Coen,
Related to what? XP and Win98 are not the same, if that's what you wanted to know Happy
Marcin
« Reply #289 on: November 08, 2010, 09:56:26 am »
Hi Marcin_gps,
Thanks for the reply. So you tried win98 and disliked it, but still have plans for XP?
regards, Coen
« Reply #290 on: November 08, 2010, 10:37:49 am »
Coen, I think the story is a little different;
W98 (or ME) is no "OS" as such. It is a toy.
Says me. Happy
Chriss
« Reply #291 on: November 08, 2010, 12:40:08 pm »
How to set it up Marcin?
Marcin_gps
« Reply #292 on: November 08, 2010, 02:22:28 pm »
Hello,
CoenP - I think that Peter made a good point here Happy
Chriss, if you want to apply some serious tweaks, go to http://cicsmemoryplayer.com/ and knock yourself out, hehe
However if you play in unattended, you might want to skip Chapter 7.3, step 5 (change sheduler time slice), because it sets equal priorities for foreground and background processes, which may be good for attended.
Greets,
Marcin
Chriss
« Reply #293 on: November 08, 2010, 06:06:06 pm »
Marcin thanks for the link but i found that 'The setting only affects multi-processor systems' unhappy I have only one haha no point :D
Regards, Criss.
Marcin_gps
« Reply #294 on: November 08, 2010, 08:57:14 pm »
Chriss - too bad, but I highly recommend that you apply the rest of the tweaks. It really works, I tried them some time ago along with cPlay.
Greets,
Marcin
ivo
Music lover
View Profile WWW
« Reply #295 on: November 08, 2010, 11:12:02 pm »
Tried those USB polling numbers from 1....5 and without the key at all.
So, it seems, the best is 3. Less and more than 3 sound is more harsh and flat, with 3 it is deeper and warmer, like that.
Ivo
p.s. Peter, my internet connection was a bit damaged (cable was squeezed somewhere) now it is OK, can access this place.
« Reply #296 on: November 08, 2010, 11:24:46 pm »
Thank you for letting me know Ivo.
(after a PM mentioning troubles)
Chriss
« Reply #297 on: November 08, 2010, 11:54:06 pm »
So, it seems, the best is 3. Less and more than 3 sound is more harsh and flat, with 3 it is deeper and warmer, like...
a
Indeed, I'm with value 3 for more than week and it's the sweet spot for me too. Wink (so I'm not crazy ahaha :D )
Marcin I tried them ...yeap I can hear the difference! Hmm about Xp...hmm please try it I think it's not bad at all. I got better mid and high but kind of tiny bass. Still digging!
Regards, Criss!
« Reply #298 on: November 09, 2010, 11:25:02 am »
Ivo
I have also tried the USB Polling regedit and have found it very effective. the sweet spot for me is a value of 4 but its a close call between 3 and 4. I am also using a HiFace so it's interesting that Ivo and my results are converging.
Marcin_gps
« Reply #299 on: November 09, 2010, 12:42:32 pm »
Yes, but you have different DACs and different systems Happy
