April 06, 2025, 02:50:46 am *
Author Topic: Uninstall Completely  (Read 22816 times)
crisnee
« Reply #15 on: September 22, 2010, 08:53:50 pm »
Did you miss/forget about my request about tool-tips? About posting them as a file or sending a copy to me?
who am I to imply a lot of extra work from you only because you offered it ? But I will send it to you. No obligations !!
It's the kind of thing I enjoy doing. Assuming I can make heads and tails of it I'll be glad to, but it may take some time.
Chris
« Reply #16 on: September 27, 2010, 11:17:17 am »
Hi again Chris,
I was just working on something that let output those ToolTips in a "readable" fashion for you, but had some problems doing it right. Btw, it is based on asking for a ToolTip first. But then I saw that just copy (Ctrl-c) the selected text from the Help Area does exactly what I wanted to make for you, except you'll have to paste it yourself in your own text (which obviously has to be done somehow anyway).
So, wouldn't that suffice ?
crisnee
« Reply #17 on: September 28, 2010, 07:56:26 am »
I'm not sure if I understand what you mean. Do you mean "activate a tool-tip and then click Ctrl C, to copy. Will that automatically copy the tool-tip? I'll try it when I get to that computer; if it works, good. Or, if I misunderstood let me know.
I just thought you that you must have the tool-tips lying around in a file somewhere on your computer. You don't recreate them for every version of XX do you?
Chris
« Reply #18 on: September 28, 2010, 08:24:42 am »
Chris, the ToolTip Texts are in the program itself, and unformatted to your eyes (and techniques to get them out).
I meant : Activate a ToolTip, go to the Help Area where it is visible, select all, and perform Ctrl-c. Then paste into something else.
Of course this works with 0.9z-2, but you'll have to go there anyway at some stage (but maybe wait till 0.9z-3).
crisnee
« Reply #19 on: September 29, 2010, 07:45:11 am »
And when would 09.z3 be chuggin roun, de bend, approx, massah Peter? I jus' might dare'de try'er agin (z2)  grazy yessuh, if dat lon'some whistle ain't gonna blow fer'while.
Ok, so I had too many drugs; no no don't call the coppers, jus  teasing
Chris
« Reply #20 on: September 29, 2010, 08:54:11 am »
Better don't do that now hehe
0.9z-3 will be One of These Days.
