November 23, 2024, 01:39:00 pm *
Author Topic: 0.9z 2 wont keep settings...  (Read 5509 times)
pampam
« on: August 30, 2010, 12:57:35 pm »
Hi Peter
Just installed the undemo version of above. 2 things i need to seek your help:
1) XXhighend installed wont keep my settings on the music root, everytime i exit it pop up below error as attached in xxh002.jpg
2) After installing XXhighend, my Vista PC cant seem to send data into my external Zodiac + DAC. I was happily using itunes happily before that. Vista detects my DAC but fails config test>
Appreciate your input
Dave
« Reply #1 on: August 31, 2010, 08:14:50 am »
Hi Dave - Welcome.
To me it looks like you didn't answer similar questions as your 001 pic shows at the first startup of XXHighEnd with "Run" while UNticking that "Always ask" checkbox. To solve this, make a new folder and install XXHighEnd in there again. Run it, but now untick those checkboxes for all those messages passing by (can be 10 or more). After this, all should be fine - not sure though.
What it is with the DAC I can't tell without further info; it may give messages ? etc. In either case try both the device(s) prefixed by "KS:" and those without it (latter is Engine#3/WASAPI former is Engine#3/Kernel Streaming).
I hope you get it to work !
pampam
« Reply #2 on: September 06, 2010, 07:32:47 am »
Cool... Got it working. Sounding good my man.
Thanks
