April 19, 2025, 09:42:52 pm *
Pages: 1 2 3 [4] 5 6 7  All
Author Topic: Split file size and volume  (Read 106918 times)
« Reply #45 on: September 25, 2010, 09:37:57 pm »
At this moment I have no clue as to what can be happening that this influences so much, but regarding the character of it (frequencies come forward which shouldn't) I can even imagine it can me measured.
It's the "coming forward" of those frequencies and, conversely, their slow "disappearance" (and emergence of others....) when increasing the SFS, that has sorta obsessed me lately. So far, it seems there are no hard and fast rules for it, only generalizations. Most 16/44 material sounds pretty good (settings as signature below) between 70-100; however, SOME material, Oscar Peterson's "Night Train", 24/96 HD Traks version, sounds better with a setting around 20, while Karen Carpenter, 16/44 home rip (WMP unfortunately, would rerip it but can't find the disk!), becomes silk at 120.
Its because I find myself frequently fiddling with this setting that I ask for the convenience of a button on the face of the GUI. If you guys can make XX automatically adjust to the optimal setting per trak, that would be great too, though I think you'd need to employ magic, or maybe just adjust a cpu power setting or two.....to get that happening.  Happy
« Reply #46 on: September 28, 2010, 12:15:42 am »
For anyone who's interested, after quite extensive listening, my 'new' SFS values are:
35 - for non-upsampled 16/44.1 material
50 - for non-upsampled 24/176.4 material
50 - for QAP upsampled 16/44.1 material
These seem to be the 'Goldilocks' values for my system as it currently stands.
If you haven't played around with SFS yet to see how it affects the sound, then you should... asap...
Marcin_gps
« Reply #47 on: September 28, 2010, 08:43:59 am »
What happened to file size related values? Happy
« Reply #48 on: September 28, 2010, 10:22:00 am »
Haha, this was only ever a hypothesis and I made it clear that it could just have been a total coincidence. In any event, I shunned the hypothesis as soon as I discovered there seems to be an inverse correlation between the optimum SFS and the CPU power.
Now it could well be that larger files do actually require larger SFSs, but testing this with all the variables at play might prove really difficult.
Marcin_gps
« Reply #49 on: September 28, 2010, 02:05:09 pm »
Yeah, a hypothesis which can be very easy verified and for me it's true. Try playing very short tracks, which for 16/44 would have track size of around 15-20MB and compare the SFS of that 15 or 20MB to your 'Goldilocks' values'.
Marcin_gps
« Reply #50 on: September 28, 2010, 07:55:34 pm »
I've just had a session with Stan Getz - The Girl From Ipanema (24/96). The track played upsampled (double) sounds really bad with the SFS at 50. The voice and instruments are very unnatural and the bass is somehow missing. The one thing that in my opinion seems better is high, although I don't think it is meant to be so clear in that recording (reconrded in 1963). Anyway, what I'm trying to say is, that the optimal SFS maybe doesn't 100% equal the track's size, but I'm sure it is quite close and each time I play a small track (file size), the small SFS value sounds best, and the same formula applies for large tracks.
« Reply #51 on: September 29, 2010, 04:59:59 am »
Marcin, what would have been the best size for that track you think ?
Marcin_gps
« Reply #52 on: September 29, 2010, 06:19:46 am »
The track is 109 MB and I played it with 109, 50 and 25MB SFS. I don't know if that's the optimum, since I can't listen to analog source and compare, but for me it sounds pretty damn good. It would be nice if more people contributed - played around with various values and came here to post their findings. If we find the 'golden' rule then I guess you could implement it to XXHE next to manual SFS setting, as it is right now.
Suteetat
« Reply #53 on: September 29, 2010, 05:20:58 pm »
I have been experimenting a bit with split file size. SQ definitely changes and it really depends on your system and your preference.
In my system, larger file size give warmer, may be a tad darker, fuller sound whereas smaller file size is leaner and moving toward drier side
as split file size gets smaller. I definitely does not want to change split file size regularly depending on the file being play.
For me, I find 350mb to be the sweet spot. Anything bigger, the sound is a bit too sluggish and fat, but smaller split file size is too lean for my taste.
So for now, I have to accept the occasional out of memory error. At least now iPad/VNC make things a bit more bearable!
Marcin_gps
« Reply #54 on: September 29, 2010, 06:05:02 pm »
350 MB? That can't work well with upsampling... Maybe with DAP it could work, but certainly not for QAP.  I encourage you to try some very short track, check its file size and set the same SFS. Then compare to your 350MB setting.
« Reply #55 on: September 29, 2010, 07:01:19 pm »
I haven't noticed a specific connection between music file size and the appropriate SFS setting. Here things like powerful female vocalists and violins totally benefit from a higher SFS, whereas classical guitar and piano, generally,  sound much better, richer overtones and tighter treble, with a lower SFS.
« Reply #56 on: September 29, 2010, 09:57:31 pm »
I ordered a new mobo and nice i7, so tomorrow that should be up and running...
I'd be interested in knowing whether your preferred SFS values come down with a more powerful CPU.
Oh, and welcome to the modern world!
« Reply #57 on: September 30, 2010, 12:32:57 am »
My new Goldilocks value is 36 for all material.
Does anyone have an explanation as to why the SFS affects the sound so much? How is it that we're all pretty much hearing the same thing (irrespective of our preferred SFS value)? Reducing the SFS below the Goldilocks creates a 'thin' and 'shouty' sound. Increasing it beyond the Goldilocks creates a 'thick' and 'too mellow' sound. What the hell is going on here?
« Reply #58 on: September 30, 2010, 07:05:26 am »
On the matter of that boundary ... no clues here. But, I tried to avoid anything which can matter, and in 0.9z-3 you will have 3 options :
- The old one;
- A new one with certain organization which IMO can't be influenced by the Size;
- A new one with certain different organization which IMO can't be influenced by the Size.
At least this is a piece of cake to re-implement after I lost the source of it yesterday. Took a month to think about it only. Happy
Marcin_gps
« Reply #59 on: September 30, 2010, 08:45:33 am »
Peter said, that his DAC is totally resistant to PC Tongue Joke, we know that sth is going on on a software side rather. I personally don't believe in speed/robustness corelation to SFS value.
