November 23, 2024, 01:58:41 am *
Pages: [1] 2 3  All
Author Topic: Schumann synchronizer  (Read 42860 times)
Marcin_gps
« on: August 11, 2010, 08:11:39 pm »
Hi Guys,
Do you have any experiences with these devices?
http://www.6moons.com/audioreviews/acousticrevive/rr77.html
http://www.6moons.com/audioreviews/schumann3/schumann.html
The purpose is to eliminate/minimise EMI by emiting the frequency of 7.83Hz that is considered to be our planet's natural pulse.
« Reply #1 on: August 11, 2010, 08:15:41 pm »
Not me. But coincidentally I had a pair of Lessloss Blackbodies "in" the system yesterday. They didn't last long ...
It does something allright, but nothing good to my ears.
I believe they have to point to the north for best results.
But maybe I just don't like changes to "original sound". That's a placebo as well ... yes
Marcin_gps
« Reply #2 on: August 11, 2010, 09:07:44 pm »
http://ouir.ch/produkt.html?art=924
These plates are supposedly very effective and cheap...
I consider Schumann synchronizer, because I'm exposed to big amounts of EMI for 15 hours/day. I have a huge display (30") that is 50cm in front of me, 2 PCs and audio equipment. All of that in a small room (~10 square metres). I won't find out if it's any good if I won't try it.
« Reply #3 on: August 12, 2010, 12:06:47 pm »
I've ordered a 'Schumann Synchronizer' from Healing Earth here in the UK. It's 'only' £149, so won't break the bank. Will let you know how I get on with it...
Marcin_gps
« Reply #4 on: August 12, 2010, 12:18:52 pm »
Great! Let us know Happy
« Reply #5 on: August 21, 2010, 11:12:47 am »
I received mine yesterday. The verdict is still out on whether it makes a difference.
BUT... I did have a really good night's sleep!!!
Will report later with more thoughts...
« Reply #6 on: August 21, 2010, 12:57:13 pm »
Whatever it is what you have there Mani, don't point it to the east please.
Haha.
Marcin_gps
« Reply #7 on: August 21, 2010, 06:02:46 pm »
That is exactly what Srajan Ebaen wrote in his review. Sth has to be in it and it seems to be working...
Looking forward to your further thoughts, especially if there is any positive influence on A/V gear.
Marcin
« Reply #8 on: August 21, 2010, 10:31:48 pm »
This is really difficult for me. On the one hand, I want to share my experiences as openly and honestly as I can. On the other, I think it's so important for people to try things themselves and come to their own conclusions. So, let me just say this: for all its implausibility, I think this Schumann device does have an affect on the sound... one that seems to work well in my system.
Marcin_gps
« Reply #9 on: August 22, 2010, 12:22:15 pm »
Fair enough. I'll try one in my system.
« Reply #10 on: August 22, 2010, 02:21:03 pm »
I thought to be smart ...
I looked around whether I could buy such a thing (second hand) from someone in the neighbourhood, and couldn't find any. Ok ...
I hate it when I want something and can't get it right away, so I tought : why not create a 7.83Hz tone, and play it ...
Yeah, start laughing for the unexpected ending of this ...
swoonswoonswoon
So, generated the tone, put it in a nice "Schumann" folder, dragged in onto the playlist area and pressed play. At a really soft level of course, because one can't know what will happen when fooling with Mother Earth. Well, I didn't sense a thing, but walked to the woofer if I could feel it moving ...
... and immediately thought "fool, of course this won't work because the driver won't go as low as that". Yep.
swoonswoonswoon
That's me.
Next I thought, "no of course those drivers don't go as low as that, by maybe something comes from the subwoofers".
Felt those, and, nothing of course. Nope, they officially go to 12Hz with ports open, and I also have the ports closed.
But okay, the volume was still very low as well. So, maybe pump that up to more normal levels.
Nothing.
A "high" level maybe ? ...
Nothing.
Walked to the other sub as well to be sure, but no, nothing.
... But at standing there I very coincidentally saw the stif-ish flat wired cables to the mid-high section (which hang in free air for a meter or so), and saw them moving ! But it looked like from my walking there, or just a breeze in the room. But no, at standing completely still and not feeling any breeze or something, they just kept on moving. I even imagined that ~8 times per second. What the heck ...
Stopped the playback, and indeed, no movement anymore.
Set the timer to 10 seconds, clicked play and walked to the speaker, and ... yep, after 10 seconds the moving started.
Ahaaaa ...
Happy Happy Happy
Well, the level is fairly loud I guess (normal music would be kind of blasting, but still acceptable), and now it is the question : what should that level be ?
Oh, I just gabbed the dB (SPL) meter, and it nicely shows the frequency and 56dB SPL at 20cm distance (at 1 meter there's nothing visible).
Hahaha, oh ... oops ... I added 6dB, and indeed 6dB more shows. But while I still can't feel anything moving, the whole (over 100 Kg) speaker is moving now. Notice that the sub is not connecting to to the speaker, otherwise than via the concrete floor. Ok, so this is dangerous I guess, and the whole house must be shaking (it really can, and with some movie I had the outside earth (ground in the garden) really shaking). I now measure 56dB everywhere in the room, but over 60 in the back (standing waves).
Ok, I better stop it at this level. stop
What I don't quite understand is why I see the speaker moving (3mm back and forth on estimation), while I can't feel it. Am I moving myself on the same rythm maybe ? I'll admit it senses a bit strange, but sure not like that I'm shaking myself.
OUCH ... almost had a heart attack. I thought "let's look at that woofer again, because how can the speaker otherwise be moving back and forward" (the sub has its driver fireing downwards). So, I dove into the low-horn, and it *really* came to me as if something was trying to byte me. It was the woofer excursing sooo much that it it just came towards my face. And back of course. Brrrr ... that must be close to 7 cm back and forth (together). But it really shows a nice ~8 Hz frequency !
Ok, that woofer cabinet officially is straight to 27Hz, but that doesn't tell it can't do more. Btw, in another (newly designed) cabinet it goes straight to 18Hz (the BEST for a normal woofer cabinet !!). But pump in more juice and apparently it can even do more.
Ehh, don't try this at home ?
« Reply #11 on: August 22, 2010, 02:34:28 pm »
Hey Peter, has anyone ever told you that you're absolutely crazy - I mean certifiable crazy?
In your last post, you gave the impression that you're a bit impatient. So, how've you survived the NOS1 ordeal these last, what, 24 months or so? Must have been painful for you...
You've no doubt had a much bigger dose of Schumann 'energy' than I've been exposed to - feel any different? Less impatient maybe? Haha.
« Reply #12 on: August 22, 2010, 02:35:51 pm »
rofl
Marcin_gps
« Reply #13 on: August 23, 2010, 09:37:28 am »
Peter, don't you know that messing around with infrasounds could be dangerous?  grazy
BTW, here's an interesting link: http://en.wikipedia.org/wiki/Brown_note  yahoo
Eric
« Reply #14 on: August 23, 2010, 11:31:35 am »
Hi all.
I have the Schumann Resonance Plug running in my listening room now for a very long time.
My personal experience is excellent. There is really no need to try to convince anyone else because IMHO the effect on what and how you perceive is very much dependent on your degree of sensitivity for it. Just try the effect on your consciousness and decide for yourself. Still interesting to read the reviews of others.
Here is what I use. The price is 195 Euro.
http://www.kempelektroniks.nl/Shunt-Conditioners/Schuman-Resonance-Plug.aspx?lang=en-US
Cheers, Eric.
Pages: [1] 2 3  All
