April 06, 2025, 05:24:35 am *
Pages: [1] 2 3 4  All
Author Topic: cannot run as administrator anymore  (Read 51983 times)
Flecko
« on: July 18, 2010, 06:57:44 pm »
administrator mode doesn't work anymore. It say" XXHIghend stopped working" and in details
Problemsignatur:
  Problemereignisname:   CLR20r3
  Problemsignatur 01:   xxhighend.exe
  Problemsignatur 02:   1.0.3826.32428
  Problemsignatur 03:   4c223e27
  Problemsignatur 04:   XXHighEnd
  Problemsignatur 05:   1.0.3826.32428
  Problemsignatur 06:   4c223e27
  Problemsignatur 07:   29bd
  Problemsignatur 08:   106
  Problemsignatur 09:   System.InvalidOperationException
  Betriebsystemversion:   6.1.7600.2.0.0.256.1
  Gebietsschema-ID:   1031
If I start the program normal, there is no problem. I didn't changed anything. The only thing that was changed, was a windows update. Any idea how to solve?
Greatings Adrian
« Reply #1 on: July 19, 2010, 09:26:28 am »
Hi Adrian,
Strange ... What happens if you apply what I wrote in here : Re: install problem ?
Ah ... and I can imagine this is related to running that Setup under the scope of "Administrator". And, I see you did not apply the "general" uplevelled rights but apply it per program you start (like XXHighEnd). I can imagine that this doesn't coorporate nicely. So in either case, run that setup As Administrator too, and let me know whether that helps.
Flecko
« Reply #2 on: July 19, 2010, 05:27:51 pm »
I uninstalled phasure and reinstalled it as administrator. I still does not work. The strange thing is, that it worked all the time and now suddenly there is this error...???
« Reply #3 on: July 19, 2010, 06:01:24 pm »
-removed post-
Must think ...
Edit : Do you know what Windows update that was ?
Flecko
« Reply #4 on: July 19, 2010, 06:33:15 pm »
At 17.07.2010 Update for windows defender - KB915597 (Definition 1.85.2136.0)
At 15.07.2010 Windows Tool for "remove of dangerous software" (in german " zur Entfernung bösartiger Software" )
At 15.07.2010 Security update for windows 7
I am not sure if the error occured the first time on sunday or saturday.
I tried diagnostic startup but even then it is not working. I will try to remove the updates and see what happens.
The same problem I had last week on friday with a different system (Dell Notebook with Vista home). As far as I remember I tried it on this system a while ago and I think there was this error before. So the updates might not be the reason.
Flecko
« Reply #5 on: July 19, 2010, 06:47:46 pm »
I removed the update. It had nothing to do with it. As the error occured the first time, I "played" with windows media player, creating a playlist. I started xxhe parallel without stopping wmp. I think that was, when it first happend. I don't know if this helps. I guess not very much unhappy
Flecko
« Reply #6 on: July 19, 2010, 06:59:25 pm »
So, now a better clue. xx9y4 and 9y8 start as administrator. The problems comes with 9z. So it might be not the setup. Maybe the new gui?
« Reply #7 on: July 19, 2010, 07:00:42 pm »
Oh, sure that is related. But are you now telling me that you never got 0.9z running ?!
« Reply #8 on: July 19, 2010, 07:02:45 pm »
Anyway, did you try this "general means" of upleveling the rights ? See Vista Users ... prepare yourselves ...
Flecko
« Reply #9 on: July 19, 2010, 07:18:13 pm »
No, all z versions worked!
Flecko
« Reply #10 on: July 19, 2010, 07:21:02 pm »
No, that was never necessary but I will try later.
Flecko
« Reply #11 on: July 19, 2010, 10:23:17 pm »
I disabeld the uac and now it works again. Strange, it worked all the time with uac. But thanks Peter! Is disabeling of uac also important for soundquality?
« Reply #12 on: July 20, 2010, 06:27:05 am »
A good. But strange, and not much comfortable. I'm not done with this yet. aggressive
But can you tell me, what actually went wrong without running as Administrator ? Did you notice anything ?
Flecko
« Reply #13 on: July 20, 2010, 02:46:22 pm »
There were two a masseges. One, that something is not possible because of the rights and one that says I don't run xxhe as administrator and there is sound degradation. The program worked fine.
« Reply #14 on: July 20, 2010, 06:06:45 pm »
http://mymce.wordpress.com/2009/07/17/fixing-clr20r3-issue-in-windows-media-center/
I think maybe there went something wrong in your .NET framework update, if this was updated.
Maybe this helps a bit !?
Roy
Microsoft .NET Framework 3.5 SP1 Update for Windows 7 and Windows Server 2008 R2 for x64-based Systems (KB982526)
Microsoft .NET Framework 4 Client Profile for Windows 7 x64-based Systems (KB982670)
