April 07, 2025, 02:59:13 am *
Author Topic: install problem  (Read 13408 times)
rediazvh
« on: July 18, 2010, 09:47:04 am »
hi peter/everybody...
im new to this forum and XX high end things..
this is my first time to install this program, because im sick off with itunes & foobar. i just  want  to try  install the newest model : xx high end 0.9z -2..
i already follow the instruction : extract to specified folder, turn off the user account, and so on and so on..
and finally, when i click the  XXhighend .exe ..  this one pops out..
Description:
  Stopped working
Problem signature:
  Problem Event Name:   CLR20r3
  Problem Signature 01:   xxhighend.exe
  Problem Signature 02:   1.0.3718.32893
  Problem Signature 03:   4b93df6b
  Problem Signature 04:   XXHighEnd
  Problem Signature 05:   1.0.3718.32893
  Problem Signature 06:   4b93df6b
  Problem Signature 07:   19
  Problem Signature 08:   ca
  Problem Signature 09:   System.InvalidOperationException
  OS Version:   6.0.6002.2.2.0.768.2
  Locale ID:   1033
Read our privacy statement:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
[/font][/color]
anybody could help me please..?? iT seems that no body in this forum have the same problem with me.. everybody just goes well & fine. i want to try this player so bad.. any help would be much appreciated. thx!
oh, btw, im using vista basic service pack 2.
« Reply #1 on: July 18, 2010, 12:55:43 pm »
Hi there,
When you run XXHighend.exe for the first time, s amll install should be presented, and it looks that here something went wront (but it is a bit of a long shot);
In your Configuration - software/programs should be a "Phasure" entry. If not, that is the cause. If so, better uninstall that, and next run the Install.exe which will be in your XXHighEnd folder. Please pay attention to the following process, and whether something goes wrong or strange.
If all goes right then you could try to start XXHighEnd.exe again and try whether "it" helped.
If this all doesn't help I'm not sure at the moment what our next step will be. But let me know in either case.
Good luck for now,
« Reply #2 on: July 20, 2010, 06:30:50 am »
Ok, I think what is in here may solve it for you too : Re: cannot run as administrator anymore. In brief for now this comes down to disabling UAC.
But maybe you already did ...
Can you let me know ?
rediazvh
« Reply #3 on: July 23, 2010, 08:15:16 am »
it still  doesnt work, i already tried all ur advice.. i've gone to that thread too..   done all the step u mentioned.. but stil doesnt work  unhappy . so what should i do now?? is this got something to do with the net framework ? i already tried to uninstall and re install it.. and no  progress  unhappy
rediazvh
« Reply #4 on: July 23, 2010, 08:27:23 am »
and sorry, what do u mean by phasure entry ??
« Reply #5 on: July 23, 2010, 09:03:08 am »
Dzjee, I am sorry for your problems, and at this moment I don't know how to help.
In Control Panel there's "Add or Remove Programs" (or something which is called similar) and in there Phasure should be listed.
Ok, what happens if you install 0.9y-8 ?
I think I can promise you that will work. You will have a few features less (and the old GUI), but at least it will get you going. Then after that (you will be happily playing) we can look into this issue with some easy.
Is that an idea ?
PS: But did you disable UAC ?
rediazvh
« Reply #6 on: July 23, 2010, 11:58:57 am »
hi peter , its a very very bad news for me.. the 0.9 y-8 version seems doesnt work too ! unhappy  i really dont know whats going on in my systems... the UAC has been disabled since the first time i try to install.. im afraid that i missed some installation step..
this is what ive been through:
- extract the xxhighend mode
-put in the folder (that u have mentioned)
-disable the UAC
-install the phasure(OCX)
- Run the XXhighend. (doesnt work)
optional:
-ive uninstalled and reinstall the net framework  3.5 SP1 (kb963707), framework 3.5 (kb 951487), framework 4 (kb 982670) using windows vista basic sp2.
i have tried all the Xxhe mode.. and NO ONE seems to work.. please tell me if theres something that i  missed or uncorrect
thx
« Reply #7 on: July 23, 2010, 12:15:52 pm »
Hmm ... you must have something special going on indeed.
I assume you don't have any laptop or whatever laying around, just to try it on there ? nah ... then you would have done that already.
Ok. Do you have time tomorrow so we can sort it out by means of a debug version you'll receive from me ?
I don't know what time zone you're in, but here it is 12:15pm now and we could start at (my) 7am. On my part we'll continue till we drop, if only you want that, and have some time to be behind the PC all the time (me adjusting things for you in the mean time).
We'd do that by email.
Two other questions in the mean time :
1. Did you ever see the GUI at all ?
2. What processor/PC/OS do you have ?
rediazvh
« Reply #8 on: July 23, 2010, 12:25:13 pm »
ofcourse, i think tommorrow is better, forgive me now im feeling that im getting too excited Happy
at the moment im using toshiba laptop (dont have any pc).
1. no, ive never seen the gui at all. thats what make me feel so frustated
2. i have core2duo 2 ghz, vista basic 32 bit sp2.
ofcourse, i got whole day for tomorrow.
« Reply #9 on: July 23, 2010, 12:33:24 pm »
But am I right you're from Australia ?
Ok, I will send an email to the address known to the forum, but later, and by that time you will be sleeping. Then tomorrow at 7am my time we will continue. So for you that is 5,5 hours earlier then it is now. Ok ?
Btw, I have been Googling for the error codes, but all I find is your post. Happy
rediazvh
« Reply #10 on: July 23, 2010, 01:46:55 pm »
yep. im from australia. ok i'll wait for ur email
