November 23, 2024, 05:05:17 am *
Pages: [1] 2 3  All
Author Topic: Tick sound at starting playback  (Read 34812 times)
« on: July 15, 2010, 06:17:20 am »
Everytime I start playback there is a loud tick sound before playback starts. This happens only during starting playback or when the next track is played using hotkey.
« Reply #1 on: July 15, 2010, 09:16:48 am »
Arvind, since when do you have this ?
« Reply #2 on: July 15, 2010, 09:56:44 am »
This is since 9y, somehow I had forgotten to point it out. Sorry about that.
« Reply #3 on: July 15, 2010, 12:27:10 pm »
Ok. Is there anybody else out there with a "DAC Needs" setting of 24 bits, having this same problem ?
Or *not* having this problem at that setting ?
Thank you,
jeffx
« Reply #4 on: July 17, 2010, 11:58:31 pm »
I am experiencing the same thing with my Off Ramp 3 with 0.9z-2. However, it does not do it every time.
Jeff
Vista -> XXHE -> EA OffRamp 3 w/ UC & Hynes PS -> AN Kits DAC 3.1 -> AN Kits L2 Pre
« Reply #5 on: July 18, 2010, 06:46:43 am »
That is what I wanted to know; One additional case is enough I guess. Thank you very much Jeff, especially at taking the effot with a "first post". Really appreciated.
Ok, Arvind. Can you please try to find out which exact version change caused this. You said 0.9y which of course can be that one. But I think you will mean some sub version of that; If I don't know the exact version I won't be able to find it, because it will be dependend on your 24 bit-only device, and I don't own such a device.
Please let me know,
« Reply #6 on: July 18, 2010, 06:28:13 pm »
This problem has started with engine #4 if my memory serves me right.
« Reply #7 on: July 19, 2010, 09:22:49 am »
Hi Arvind - It won't be so that today's Engine#3 doesn't give the problem, or ? It would be helpful to know this.
« Reply #8 on: July 22, 2010, 02:19:22 pm »
Tried out Engine #3 & it gives the same tick sound while commencement of playback.
« Reply #9 on: July 22, 2010, 03:17:31 pm »
Thank you very much Arvind.
« Reply #10 on: August 15, 2010, 06:23:11 pm »
Guys,
I have been working the whole afternoon on this one;
I started with using a HiFace and setting at as DAC Is 24, and indeed, a tick (most of the times).
I ran through everything and everything, until I noticed that with DAC Is 32 the tick is there just the same.
I can have no other conclusion than that it is the HiFace. This is also encouraged by Engine#3 as well as Engine#4 is doing it, while both have completely different initialization trajects. Now, if it would have happened with 24 bits only, I *still* would have given up because I can't find anything, but that always leaves the hope for overlooking something. But not now it's also with 32 bits.
Now, I can't know whether you (both) indeed use the HiFace, so please let me know. This is important, because the tick I perceive seems familiar to the tick my Fireface800 produces at switching sample rates and it *could* be so that I'm initializing the device first with another sample rate than the intended one, and it is just the Fireface doing it to me. Not that I really recognize this, but still. On the other hand, I had a Weiss here the other day, and *that* one ticks (rather loudly plops) when sample rates are really switched, and it didn't tick or whatsoever at the normal start of playback.
But on this matter, is it correct that the tick is often from the right channel only ?
« Reply #11 on: August 15, 2010, 08:42:13 pm »
I use a hiFace in my office system and have never heard any ticks at all. And this is with a very modest Atom-based PC usiing Adaptive with 1024 buffer.
In my main sytem, I have an RME PCI interface and when I switch HDCD decoding on, I get an intermittent loud tick from the left channel.
Sorry if this doesn't help.
« Reply #12 on: August 16, 2010, 12:12:23 pm »
I have the Empirical Audio/Off-Ramp & the tick is from both channels.
« Reply #13 on: August 16, 2010, 12:17:30 pm »
Arvind - Thanks.
(I knew that, but wasn't sure whether it can be used with SPDIF-In and thus a HiFace)
« Reply #14 on: August 16, 2010, 12:29:17 pm »
I just tried 0.9x-7 and the problem with the HiFace is there too.
This only means I can't test it, since it is my only "24 bit only" device.
Maybe I can get it away with the latest driver version (and notice that the Internet is full about HiFace click problems, although most are from the MAC (and from before May 2010)).
Supposed I can get rid of it, can you give me an example of a (more known) album where it sure will happen ? I know you will say it happens with all, but I want to have some confidence.
Pages: [1] 2 3  All
