November 23, 2024, 08:34:22 am *
Author Topic: Activation Code Problem  (Read 7056 times)
« on: July 06, 2010, 09:54:23 pm »
Hi Peter
I have just added Win 7 on my pc so it dual boots with Vista. I installed xx under Win 7 but it will not accept the activation code. I have attached the error message.
All the best
P
« Reply #1 on: July 07, 2010, 07:45:07 am »
Hi Paul,
I just sent you a PM with what to do best in this case.
didierG
« Reply #2 on: November 01, 2010, 07:53:48 pm »
Hello Peter
I have installed Vista in dual boot with XP and XXhighEnd  (9z3) on Vista doesn't accept my activation key, whereas it works fine on XP.
I have the same popup as above, e.g:
Code at target xxx Code to target <my activation key>
Can you help me ?
Thanks by advance
Didier
« Reply #3 on: November 01, 2010, 10:37:43 pm »
Didier - Hi,
I just sent you a Private Message in the Forum (see "My Messages").
stefanobilliani
« Reply #4 on: November 01, 2010, 11:03:22 pm »
I have seen the same thing in 2000 ..
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
