« on: July 02, 2010, 05:54:09 pm » |
« Reply #1 on: July 02, 2010, 05:55:46 pm » |
Yes, well done The Netherlands...
Per
Music is forever...
« Reply #2 on: July 02, 2010, 06:10:39 pm » |
Yes, congratulations, Peter - and to all of Holland.
What a fantastic victory for Orange, won by: Spirit, brain work and talent. The game reminded me of the heydays of the Danish Laudrup, Elkjaer team from 1986.
Per
Sep 2010 Acer Aspire M1201 | AMD Athlon Dual Core 4450e 2.30 ghz | 2GB RAM | Hitachi HDD (SATAII) 384GB | Vista Home Premium 32 bit SP2 | XXHighEnd 0.9y-8 Engine 4 | Q1/2/3/4/5= 14/14/7/0/0 | No Invert | KS Mode=Adaptive | Device Buffer Size=1024 | Split file=60 | DAC at 24 bit 44.1 khz | No Invert | No Upsampling | Playerprio=Low | Threadprio=Realtime | Scheme=3 @ Attended | -> PCI AudioTrak HD2 Advance DE | -> Sony EarPhones and Philips PC-speakers ;-)
« Reply #3 on: July 02, 2010, 10:08:56 pm » |
« Reply #4 on: July 06, 2010, 08:04:04 pm » |
Here we go again!!
« Reply #5 on: July 06, 2010, 08:30:18 pm » |
GO HOLLAND! Teach these Uruguayans that cheating doesn't pay.
Ghana deserved to be playing tonight...
« Reply #6 on: July 06, 2010, 09:32:19 pm » |
« Reply #7 on: July 06, 2010, 10:34:26 pm » |
« Reply #8 on: July 06, 2010, 10:37:14 pm » |
Peter is about to announce that if Holland win the WC finale in football, then old XX customers and members (>100 postings) of this forum will receive a €1000 discount on the new DAC!
« Reply #9 on: July 06, 2010, 10:59:03 pm » |
Hahaha yeah right.... hmmmm maybe for those +500.... hahaha  What it is it is....
« Reply #10 on: July 06, 2010, 11:00:58 pm » |
 I'am soaking in beer, saw the game on big screen in Eindhoven, the southern (Brabanders) knows how to party. und jetzt kommen die kamelen, brawah Eindhoven gekste!!
« Reply #11 on: July 07, 2010, 03:17:05 am » |
Congratulations Netherlands!
« Reply #12 on: July 07, 2010, 08:14:06 am » |
Hehehe, now I am going to buy a vuvuzela and give it to my son for indoor-use next sunday (I heard that the longer than 1m ones are for in-door useage  ). I don't think we will be watching the final at home, so whereever it will be, there they can laugh.  But first tonight we will have another nice match. I vote for Germany and next we will have the most "loaded" match since 1974.
« Reply #13 on: July 07, 2010, 10:16:10 am » |
Hehehe, now I am going to buy a vuvuzela and give it to my son for indoor-use next sunday (I heard that the longer than 1m ones are for in-door useage  ). I don't think we will be watching the final at home, so whereever it will be, there they can laugh.  But first tonight we will have another nice match. I vote for Germany and next we will have the most "loaded" match since 1974. Maybe if you paint your speakers orange the look a bit like vuvuzela's...
« Reply #14 on: July 09, 2010, 10:04:38 am » |
Since i lost my bet (germany), now i cheer for Netherlands!
