November 23, 2024, 11:31:48 am *
Author Topic: 0.9z-2 Error message not solved  (Read 23763 times)
« Reply #15 on: July 03, 2010, 02:23:19 pm »
Well, that would be a good idea, because I can check for that service running or not (assumed it is caused by a service not running), and if not shut off the communication.
Thank you for your time, but don't make it too wild ...
Eric
« Reply #16 on: July 04, 2010, 12:03:27 am »
I found a way to Solve or (re)Create the problem. You can try it as well iof you like.
On the desktop, Rightclick on Computer and select (click on) Properties. Now click Change Settings and click on the tab Advanced. Now click on Performance Settings.
Now you are offered 4 options.
If you choose Automatic or Best Visuals (or something like that), the problem is gone.
If you choose Best Performance, than XXHE will show XP-like tree and the Error Message appears.
My next step is to play with Manual selections to find the best settings for me.
Eric.
Eric
« Reply #17 on: July 04, 2010, 07:12:53 am »
The only option that needs to be switched ON is Apply Visual Styles.
If you do that, the XP style will not occur to spoil the party.
P.S. Not sure which Service is needed (if any).
« Reply #18 on: July 04, 2010, 08:10:08 am »
No, I already knew that - no explicit service for it. But I think I can set the developers of that piece of software (which is extrernal) to solve this. At least with this information it should be easy now. But there's also a newer version of it available, and who knows it is solved in there.
As always, great thanks for your efforts.
« Reply #19 on: September 26, 2010, 06:18:13 pm »
Hi Eric,
I made the small mistake of first implementing a new version of the Embedded Explorer (hoping for the problem to go away), without before again testing how it goes wrong. I did that before allright, but I'm not 100% anymore whether I could copy the problem. I thought I could. Anyway, without now first testing it, I can only test it after this new install, and at least now I can't copy the problem. It may not say a thing though ... However, the problem at startup which was there before, but solved in 0.9z-2, for sure has gone. So, assuming both have the same origin (and I do), your problem here should be gone too.
But please check it when 0.9z-3 is there, okay ?
Thank you,
Eric
« Reply #20 on: September 26, 2010, 09:43:51 pm »
Sure, no problem!
Eric
« Reply #21 on: October 27, 2010, 12:40:08 am »
Per your request, I tested 0.9z-3 for this problem.
i) The error message has gone. GOOD!
HOWEVER
ii) Like before, if the option Apply Visual Styles has been switched OFF, the XP style will still occur.
Furthermore now NEW:
iii) If the option Apply Visual Styles has been switched ON, XP style will not occur initially. But after playing at least 1 track (unatteded) and XXHE comes back up:
the XP style will occur AGAIN. Very strange. Still 2 Explorer instances not being able to communicate ?
Eric
« Reply #22 on: October 27, 2010, 06:49:00 am »
Eric (thanks and) this is normal and has nothing to do with "communicating" as such. It is just the "style" which is respected, and this is "Vista" or it is not. And, when XX is brought up at Unattended, it is not (the Services concerned are down at the moment of bringing up XX, and that part (Embedded Explorer) won't reset).
