November 23, 2024, 01:43:13 am *
Author Topic: Need advice - installed Juli@ and now Brick won't work  (Read 7260 times)
glynnw
« on: June 24, 2010, 11:17:13 pm »
Today I successfully installed my new Juli@ soundcard, but when finished my  usb Wavelength Brick had disappeared as an audio device.  I am unable to reinstall it now and Wavelength says I may have corrupted the driver scheme by installing Julia.  However, I can get a usb Music Streamer to work.  It looks like I am going to have to reinstall windows and start all over.  Any ideas?
glynnw
« Reply #1 on: June 24, 2010, 11:23:50 pm »
I just unplugged it all and let it sit a while and not everything is back to the normal.  I have no idea what that was all about.
glynnw
« Reply #2 on: June 27, 2010, 10:11:18 pm »
Finally have Juli@ installed and (apparently) working.  After 24 hours of frustration and several blue screens, at the advice of a friend I tried installing the Juli@ card in a different PCI slot on the motherboard.  This worked.  When I play back a 176400 signal on XXHighEnd, this shows up on the Juli@ monitor, so I am assuming all is well.  Do I need to install any of the other things, like Cubase, Cakewalk, etc. if all I intend to do is use the SP/DIF output?
« Reply #3 on: June 27, 2010, 11:17:14 pm »
Nothing that I know of !
