April 08, 2025, 03:24:02 pm *
Pages: 1 2 [3]  All
Author Topic: Thanks and Sound Quality  (Read 49098 times)
« Reply #30 on: October 28, 2010, 09:56:44 am »
Hi Bill,
What happens if you set the Split File Size (settings Area) to 12 ?
If that doesn't help, edit the SFS.ini file in your XX folder, and change the 11 in the beginning of the file to 00.
Does that help ?
In either case after this we must see further.
simpsimon
« Reply #31 on: October 28, 2010, 06:22:29 pm »
Hi Peter, I'll try what you suggested.  One other thing I noticed.  When I unzip the files to my C Drive, both the XXHighEnd.exe and Hotkey shortcut icons have little shields attached to them.  They have the shape of a Knights shield.  Does this bring anything to mind.  Oh, I sent you the same message about my problem in a new post today.  I wasn't sure if you would get this one that I sent yesterday due to my inexperience with your forum.
Bill
Yahoo!!!!  It worked.  I did both of the above ie changed split file size to 12 and changed the 11 to 00 in the sfs.ini file.  Sounds great.  I have a question though.  Which is better, a low split file size like 12 or a higher one between 50 and 100 (my son Tony uses 50)?  My computer has a quad processor with 8 gigs of RAM.
Thanks again,
Bill
« Reply #32 on: October 28, 2010, 08:36:23 pm »
Hey Bill, great you managed.
What you actually first should do is try the SFS.ini at 11 again, but leave the SFS itself at 12 (this is what I sort of suggested).
Notice this is merely to find out whether your PC can't cope with the new "11" functionality or something else is the matter.
Next about the SFS size ... this is the typicle subject nobody could make definite conclusions about. This is why the "11" functionality emerged ... to eliminate the differences between the SFS settings.
So, when you can still play with SFS.ini set to 11, try to increase the SFS setting itself and just try to perceive differences.
If "11" doesn't work fot you, just do the same. But now I can guarantee that there *will* be differences. Try to find the setting you like best. 65 would be a good figure.
And oh, if possible, please put some data in your sig (can be similar to mine) so we know what you're using and all (XP, Vista, etc.). At least I can't remember that for everybody. Happy
Edit :
PS: Sorry forgot to answer on the shields ... which answer I don't know anyway. But Christoffe (below) seems to know more about it. Happy
« Reply #33 on: October 28, 2010, 09:08:55 pm »
did you install the TuneUp Utillities
simpsimon
« Reply #34 on: October 29, 2010, 12:57:13 am »
Hi Peter, I played with all the settings today and noticed that if the second digit in the SFS.ini file is a 1, I get the xxengine3.exe stopped working notification.  Thus 00, 10 and 20 work fine and 01, and 11 don't .  With 00, 10 and 20, I can raise my split file setting to 110 with no problems.  I did notice also that, with my computer, I can't run in the "Special" mode unattended no matter what Q1 setting and with the buffer at its 4096 highest.  I am running 64 bit Vista, with 8 gigs of RAM and a Quad processor.  Still need to play more to get the best sound I can from my computer and hopefully approach vinyl warmth.
Christoffe, what do you mean by TuneUp Utilities?
Bill
sergero
« Reply #35 on: March 09, 2011, 02:55:36 pm »
Hello everyone Happy
I think I have to post it here .....I have just registered here today but spent few days listening to my new software player......demo version yet ( I am going to purchase it this week )....XXHighEnd....so what can i say....from the very first moment when i have compared it to foobar I hear huge improvement in SQ.......and this just brings so my joy to my everyday life...lol
I wanna thank Peter for all his efforts ( i have read CA tread forum too ) in designing this player and I hope to try not beta version someday too Happy
i am running XXHE on external hard drive ( music folder is at the same hdd too )  via esata connected to my pc : XP 32 bit Q9550 2Gig ram through ASUS Xonar D1 soundcard analogue connected to NAD amp.......and i love this sound already Happy
Should i call you Peter the Great now?Happy)))
Regards from Russia,
Sergei
HTPC Thermaltake Bach: Intel Q9550 - 3 Gb RAM, WinXP 32bit, music and XXHE are on external hdd via eSATA, > Hama 053742 USB 2.0 cable> NAD M51 DAC > VanDenHul The Orchid IC > NAD C165BEE preamp > Vampire Wire AI/2 IC > Yamaha MX-2 power amp > Kimber Kable 4TC speaker cables > Yamaha NS-F500 speakers + pair of Infinity Beta SW-10 subs....ooooph:)
0.9-z4-1 Engine#4 Adaptive, Device buffer 1024, Qs - 4,0,0,0,0, thread prio - real time,Processor core - scheme 3 , Clock res - 1 ms, DAC 16 - 44.1, SFS 110 Mixed contiguous
« Reply #36 on: March 09, 2011, 03:54:26 pm »
Dear Sergei,
Thank you very much, and nice very to hear.
But let's stick to the Alexanders to be Great. Not me.
Well, later maybe. Haha.
Kind regards, and welcome of course !
« Reply #37 on: March 09, 2011, 04:26:33 pm »
Dear Sergei,
No no, No Alexander the Great!!
You have the name "Saint Peter" already!  Wink  (That name has been giving to you by someone) (Do not remember who)
 rofl  rofl  rofl
sergero
« Reply #38 on: March 09, 2011, 04:54:52 pm »
.....Saint Peter.......sounds not bad also.....but then he should move to Saint Peterbourg probably  Grin
« Reply #39 on: March 09, 2011, 04:58:16 pm »
hahahaha mmmmm yes that i guess he did!  rofl
« Reply #40 on: March 09, 2011, 05:01:54 pm »
Haha. Well, als long as you all don't forget that I'm only your "tool".
So, it can't hurt to mention once in the few months that it is *you all*who create this.
Can't be done by one single person ...
Peter (due saint ? mwah)
« Reply #41 on: March 09, 2011, 05:09:07 pm »
Well for me and i am sure for many others too you are much more than just a tool!!  yes
It is time for a  thankyou once again!!!!!
Pages: 1 2 [3]  All
Page created in 0.125 seconds with 19 queries.
