November 24, 2024, 03:52:49 pm *
Pages: 1 2 3 [4]  All
Author Topic: 09-z1 issues  (Read 55619 times)
0 Members and 16 Guests are viewing this topic.
« Reply #45 on: June 22, 2010, 02:56:33 pm »
I am experiencing the same problem. Last digit of runningtime is superposed.
How did you solve it Arvind?
Eric
As a matter of fact I now saw it too. Only the last digit, and somehow it is related to the background. Also, it is (very very strange) not all digits which remain. So, the 4 (or whatever) resets it all.
If I have no background (just black) there is no problem, but if I have my drive screen (with "VU meters") as the beackground, the "whiping" of each digit somehow doesn't work.
No clues here ... no
Eric
« Reply #46 on: June 22, 2010, 03:31:36 pm »
Of course I can do it manually.
(using Windows search and select+delete them all in 1 go).
So I guess you can do it in an automatic way or at least provide a kind of "cleanup" button? Food for thought.
After making a (differential)backup, I always check the result (total number of bytes must be equal). The XXAnalysis.dat file makes it much more complicated to verify the correctness of the backup.
So here is the challenge.
Eric.
« Reply #47 on: June 22, 2010, 05:01:52 pm »
Eric
Hi Eric,
Frankly I have done nothing at all. It just works ok.
« Reply #48 on: June 23, 2010, 07:40:13 am »
Uhm - Eric - Why ?
Either a normal backup or a differential backup will also backup those XXAnalysis.dat files. I don't get this ...
Eric
« Reply #49 on: June 25, 2010, 08:42:26 pm »
Uhm - Eric - Why ?
This is my usual scenario.
I have a base B (1000ths of albums) and an identical backup B'. These sets used to stay identical, so when I add some new albums A  to the base B and to the backup B', my new base B1 will be identical to my new backup B1'.
This has changed now because everytime I play an album, my base B will change. And everytime  I add new albums A, I will find that B1 is not equal to B1'. So I need to check the cause of the difference.
It is possible to do that but it is annoying. If I am the only one, then just forget it and I will live with the manual removal solution.
Eric
« Reply #50 on: June 26, 2010, 04:36:31 am »
Ok, so it seems I understand it Eric. Happy
But your "differential" backup is a manual one, right ? couldn't you change that into something which determines for you what is changed ? (ehh, like how it goes normally if we make backups) ?
You must understand that this is "my" means to store data with an album useful for a next playback. Whether you use that today or not is not all that important, because it could be tomorrow. So for example, it you would be using the Normalized Volume, you'd know you have to wait for the calculation of that for maybe 30 seconds. Not when you play the album the next time, because then this data is known. And you know where ...
So I think it would be a bad idea to let me make a parameter so you would be waiting 30 seconds each time, which would end up in you not using the functionality at all.
So just the question : wouldn't it be better for you to find this automated incremential backup procedure ?
Eric
« Reply #51 on: June 26, 2010, 09:38:04 am »
now I see why you need to have that info in the music files.
I guess I want backup that info as well !!
So I will find a solution how to handle this.
Nothing for you to be done (in this area  Happy)
Thanks, Eric.
Page created in 0.123 seconds with 19 queries.
