November 24, 2024, 02:01:44 pm *
Pages: [1] 2 3 4  All
Author Topic: 09-z1 issues  (Read 55599 times)
jarek
« on: June 08, 2010, 10:43:22 pm »
I noticed that after changing from 09-z to 09-z1 I cannot play any track when setting the DAC to be 2x or 4x. When I select 2x or 4x I have message "Device cannot be allocated....Check your DAC settings....", and next message "Engine 4 did not start in expeted time...". My DAC is 24/192 and so was defined.
Cheers !
Jarek
« Reply #1 on: June 09, 2010, 05:53:02 am »
Hi Jarek - But are you sure this is not about a 176.4/192KHz file (for 2x) or a 88.2/96KHz (for 4x) ? Because that (obviously) wouldn't work in your case ...
jarek
« Reply #2 on: June 09, 2010, 07:16:24 am »
I am trying to play 16/44.1kHz tracks, and there was not any problem to play them 4x or 2x on 24/192kHz dCS Scarlatti DAC using dual AES. This version simply does not allow any such settings. Only pure 16/44.1Khz is playing. Otherwise I have a message "Device allocated but Can't play. Check DAC settings..." . Obviously DAC settings are OK in XXHighEnd.
Log files will tell you more, I hope.
Jarek
* X3-20100609-074210.log (2.46 KB - downloaded 551 times.)
* X3PB-20100609-074210.log (0.66 KB - downloaded 539 times.)
* XX-20100609-073958.log (4.59 KB - downloaded 595 times.)
« Reply #3 on: June 09, 2010, 11:55:40 am »
My dac is 24/96. With a proprietary connection between the source and the dac it can play sample rates up to 192. I do not have this connection so I should only be able to play 24/96.
With z1, if I 2x the sample rate of a 24/96 file, XX shows 192 in the display and the file plays. ( how can that be!) If I then tick arc prediction the slider at the bottom of xx moves but I get no sound. This is with scheme 2. If I try scheme 3, I get many "Engine 3 stopped working" errors, but about 1 in 6 times I get the same results with scheme 2.
Because I have playlists that have both redbook and high rez files, z1, in its present configuration doesn't work for me, cause I use arc prediction for all the redbook stuff. Is there a plan to be able to choose what type of file gets upsampled?
« Reply #4 on: June 09, 2010, 12:18:04 pm »
Hi Brian,
Here is a quote from the release notes,
Please notice that some care was taken to not let you choose impossible combinations for your situation, but that this will not be foolproof.
Also notice that what we "fix" is the upsample rate (like x4) and not the output rate. This may not be convenient in all situations. Also, while (in the latest versions) before a hires file was left alone despite upsampling was set to be active, now it can happen that during playback of 4x 44.1 we run into a 192 file, which obviously can't be upsampled 4x on your DAC. It should be left alone, but possibly it tries, followed by a message your DAC can't cope; Too many combinations, and a sheer too much to test, but in a next version this will be arranged for (possibly by defining an output rate instead of an upsample amount).
Roy
« Reply #5 on: June 09, 2010, 12:24:11 pm »
Thanks Roy. Guess I need to learn to read better!
« Reply #6 on: June 09, 2010, 12:35:15 pm »
Even an e.g. 96KHz file most probably came from an original 192KHz or higher file. This may mean that it has been band limited within itself (read : the inaudible frequencies above 20KHz have been filtered out). In this case it is useless to upsample ("filter" !!) the file for this reason. It won't do a thing, with a chance of destroying.
When the file was not band limited, it means that theoretically spoken it still needs a filter to operate well. In that case upsampling it is a good idea.
Since you won't know whether the file is already band limited or not, it is better not to upsample for the "filtering" reason.
It is better to upsample the file for the resolution reason ..
Does this mean that even with a "band limited within itself" 24/96 file it will still sound better upsampled because of the increased resolution?  If so, wouldn't it make sense to rip a redbook cd as a 24/96 with a ripper like dbpoweramp?
Slow But Hopefully Not In The Way OLeary
« Reply #7 on: June 09, 2010, 12:41:27 pm »
Yes, with AP. It makes perfect sense if you read the threads about how AP works and the tests that Mani did with the samples.
I think that doesnt make any sense. On the contrary you would loose a few times of AP upsampling, i.e.:
44.1k - 16x to 752k (with the NOS1)
96k - 8x to 768k (")
scale down for 192k limited dacs (4x and 2x respectively)
Besides it could also be a non-integer resampling rather than a 0-stuffing what done by dbpoweramp (i dunno).
Short answer: no, rip the way the cd was recorded.
« Reply #8 on: June 09, 2010, 12:48:21 pm »
Thanks Testar.
« Reply #9 on: June 09, 2010, 01:20:10 pm »
If all is right this is because you told XX that your DAC is 24/192. If this is not the case (and you set it to 24/96 as should) please let me know.
« Reply #10 on: June 09, 2010, 01:21:51 pm »
Jarek, I am not sure, but wasn't it so the dCS is a "DAC Needs 24" ? I think you set that to 32 ...
Or ?
« Reply #11 on: June 09, 2010, 01:46:04 pm »
Yeah, dac is set in XX to 24/96 not 192.
« Reply #12 on: June 09, 2010, 02:05:37 pm »
Thanks, I see it now;
It goes wrong with Hires files. My bad ...
DannyD
« Reply #13 on: June 09, 2010, 03:18:53 pm »
First off, very nice Peter!  The z version is maturing.  One issue though: With HDCD tracks, I’m getting a tick every minute-or-so through the left channel.  It doesn’t appear to be related to a cpu spike.  I’m using Quad Arc.
« Reply #14 on: June 09, 2010, 06:09:08 pm »
Dan - Thanks.
Do you perhaps have this with more albums ?
Page created in 0.129 seconds with 19 queries.
