November 23, 2024, 12:08:27 pm *
Author Topic: Error 0.9zb  (Read 7645 times)
« on: June 07, 2010, 07:53:04 pm »
I just did a fresh install of windows 7 64 bit. And i got this error. Do you know what to do?
Thanx  Happy
* Document.rtf (4726.65 KB - downloaded 535 times.)
« Reply #1 on: June 07, 2010, 08:21:06 pm »
http://www.ehow.com/how_5341183_remove-x.html
Maybe this helps a bit.
« Reply #2 on: June 07, 2010, 08:22:55 pm »
hahaha Run as admin did... Stupid me...  Happy
« Reply #3 on: June 07, 2010, 08:30:12 pm »
That was the next thing, run as admin.
So its solved now ?
Already building ?
« Reply #4 on: June 07, 2010, 08:41:37 pm »
So its solved now ?
Already building ?
Yes a first build. The ocz is defect and need to go back. That will take a while. No luck with this... But have set W7 on the 80 SSD. Will ask a new licence after i got the OCZ back. And have used my old PSU. The other one will go in later if it is allright.
So there is music here again.  Happy
