November 23, 2024, 07:53:04 pm *
Author Topic: Change WP Problems  (Read 5865 times)
« on: June 03, 2010, 10:30:48 pm »
I have just started using 0.9zb and I do like the new user interface but am experiencing problems. One of them is that ChangeWP.exe loads (I am not using unattended) multiple times. I just checked Task Manager and there were 10 copies of changewp running. I do not recall this happening with 09y.
P
« Reply #1 on: June 03, 2010, 10:39:57 pm »
Can it be so that you received those messages after the install "Run this program ?" (similar) and you answered no *OR* did not uncheck "ask this the next time ?" (also similar) ?
« Reply #2 on: June 04, 2010, 09:20:28 pm »
not sure? anyway have reinstalled and is OK now (so maybe!!)
