November 23, 2024, 06:33:22 am *
Author Topic: RDP and XXHE aren’t compatible on my Win 7 PC  (Read 22290 times)
DannyD
« Reply #15 on: September 07, 2010, 04:34:47 pm »
No, no, no Peter.  You didn’t offend me at all.  I thank you for delving into this problem.
I’m pretty sure I followed your steps correctly.   The reason I asked why you thought it would be different this time is that I wanted to be sure I wasn’t missing anything.  The only difference I see is that I’ve un-checked Stop Services and Show Wallpaper.  Otherwise I’m doing everything the same way as ever:
-   start XXHE locally
-   hit Play
-   launch  Remote Desk Connection on my macbook
And then I can connect if I have Processor Appointment Scheme set to No Appointment, but I can’t connect if I have it set to, say, Scheme 3.  It doesn’t matter if I’ve set the Processor Scheme before of after a reboot.
Did I do it right?
I mentioned to you a while ago that it works if I run a VPN connection instead of RDP.  Is there any information in that?
Dan
« Reply #16 on: September 07, 2010, 08:08:35 pm »
First off, yes yuo did it right. Of course you did. This is because it stopped at #4. Nothing strange about that indeed !
Also :
and I can imagine you ever did something similar before
Of course I wanted to say "can't" here, but this was before I (only now) realize how very normal all is up to step 4. Of course you could have (ever before) created the RDP connection before that, so there was a small chance this helped.
Oh well, stupid PC's.
About that VPN connection ... I'm not sure if this is really what you want to say ? You don't mean VLC do you ?
But otherwise, -if VPN- does that help you ?
And sorry for the confusement; it's completely on my side !
« Reply #17 on: September 07, 2010, 08:20:52 pm »
Of course I meant VCN. Haha.
DannyD
« Reply #18 on: September 08, 2010, 08:29:02 pm »
I mean Virtual Network Computing (VNC).  At least, I think.  That seems to do the trick from my iPad, but I don't have a client for my macbook yet.  I'll have to hunt around for one.  I'm running TightVNC as the server on my PC, and Jump Desktop on my iPad.
Eric
« Reply #19 on: September 09, 2010, 09:02:27 am »
I am using software called "logmein" to control my Music PC (desktop) with my Laptop from anywhere in the world (including my bedroom).
It it freeware. Please check it out on WWW.LOGMEIN.COM.
Eric.
