November 24, 2024, 12:39:55 am *
Author Topic: Is it possible to defeat HDCD in 9z?  (Read 5082 times)
DannyD
« on: May 31, 2010, 03:38:39 pm »
Is it possible to defeat the new HDCD processing functionality?  I think it's a great new feature, but my DAC is HDCD-capable so I don't necessarily need XXHE to do it.
When XXHE decodes the HDCD, what bit depth and word length does it send to the DAC?  I would think it would need to send more than 16/44.1, which (to me) means that the DAC would have to be more than 16/44.1 and the "DAC is... " setting in XXHE would have to be set accordingly.  Is that right?
Dan
« Reply #1 on: May 31, 2010, 04:23:03 pm »
Shutting off HDCD decoding will be possible in a next version (maybe "the" next).
16/44.1 HDCD encoded material will be output in 24/44.1 (32/44.1 for DAC Needs = 32) when not upsampled. And notice that in 0.9z the upsampling of HDCD will not work anyway.
Lastly, you pointed out that HDCD decoding requires a 24 bit DAC at least, and a check for that is not in there ... -> to the bug list ! Happy
Thanks Dan,
