November 24, 2024, 08:48:16 am *
Author Topic: Bugs of 0.9z  (Read 26831 times)
« Reply #15 on: June 02, 2010, 01:51:45 am »
Johan,
I think this an old bug, about the dots in the filename.
Just rename folder to "George Russell - New York, NY"
Roy
« Reply #16 on: June 02, 2010, 08:09:17 am »
It is true that I never solved that (yea, a first part, but this turned out long ago not to be enough). But, I don't see how it worked (for your example, Johan) in the old version, while now it does not.
I merely dedicate this to something else I can't grab yet. This is about quite some more things around the pictures which seem to behave differently. You may not notice it immediately, by I do.
I will try to sort it out !
Marcin_gps
« Reply #17 on: June 03, 2010, 04:44:44 pm »
I haven't stopped playback nor quit app normally before rebooting my PC and that's what happened after the restart. I am welcomed with these "pleasent" messages. What now? I can't start XXHE, so I can't listen to music ;/ Tried fresh installations (z, za, zb) - nothing changes. Installing elsewhere doesn't help plus I get a "demo version" popup before errors appear.
I'd appreciate your help asap Peter,
Marcin
« Reply #18 on: June 03, 2010, 09:01:00 pm »
I much prefered the old GUI, which was according to "form follows function", with large buttons with text, so you knew which to push. With the new GUI the buttons are so small, that I strugle to find them at all...
With the new GUI there is a lot of unused space, still the buttons are small, and still you have use sub menues (like settings area).
(I am using a standard Thinkpad as remote desktop controle).
Apart from that I LOVE the sound. Will check out some more settings before I reach a verdict.
« Reply #19 on: June 03, 2010, 09:35:18 pm »
Marcin,
I think this is about removing a misbehaving XML user.config file, see:
http://www.phasure.com/index.php?topic=709.0
Dont forget to put the new xx install in the same folder as your first install of xx 0.9z version
Because registry entries are made with this new version, see the quote from the release notes:
• Kind of important : While so far we could manage without really installing anything (Registry stuff), now it takes two OCX files to be registered.
  Two subsequent messages at the first startup of 0.9z will tell you so. Notice they can be unregistered manually only.
  When you want to do that (hence get rid of XXHighEnd in the first place) do this, and to it *before* you throw out your XX folder :
- Open a command window (cmd.exe from the Startbutton - Run). Then go to your XX folder (CD \yourXXFolder) and in there, type these two lines :
   regsvr32/u isanaloglibrary.ocx
   regsvr32/u isdigitallibrary.ocx
Both commands should be followed by a message that the Unregistring has succeeded.
Then do a fresh install of xx 0.9z, followed by 0,9zb
Hope this helps you a bit,
Roy
Marcin_gps
« Reply #20 on: June 04, 2010, 09:21:15 am »
That helped, thank you very much!
« Reply #21 on: June 23, 2010, 12:44:34 pm »
I've noticed in the library area (midle pane) of 09z that some artworks are not shown correctly. The directory of the artist contains a folder.jpg. In version 09y it works ok. What caused this problem?
Johan
Johan, please check whether this is solved in 0.9z-2. If all is right it is ... And let me know by the time 0.9z-2 is there.
Notice that I am not sure it is your exact problem I solved, because your reference to 0.9y implies a time period of 10 months ...
« Reply #22 on: June 26, 2010, 11:12:55 am »
Solved!
Only a right mouse click in the left pane give's an unreadable menu. (in library-mode)
Regards Johan
« Reply #23 on: June 26, 2010, 11:34:49 am »
Thanks.
Do you mean like this, or do you mean something else :
(please show me, if something else)
« Reply #24 on: June 26, 2010, 12:24:39 pm »
Do you mean like this....
Yes!
Page created in 0.504 seconds with 19 queries.
