« on: May 29, 2010, 07:28:54 am » |
Here's a listing of hotkeys. See below for the OLD version it is applicable to.
Alt-X Start XXHE
Alt-O Off ( Quit)
Alt-P Play
Alt-S Stop
Alt-E Pause
Alt-N Next Track
Alt-L Next Album
Alt-V Previous Track ( N/A for UN-attended )
Alt-A Set A point for A-B loop ( N/A for UN-attended )
Alt-B Set B point for A-B loop ( N/A for UN-attended )
Alt-U Volume Up
Alt-D Volume Down
Alt-T Toggle UN-attended/attended
Alt-K Toggle "End after Track"
Alt-I Invert
Alt-F Load Library Item ( UN-attended only )
Alt-C Copy Track to "Nice Stuff" gallery entry
Alt-H Copy Album to "Nice Stuff" gallery entry
Alt-Z Copy Track to "Demo" gallery entry
Alt-1 to 0 Used immediately before Alt-U or D to change preset amount
Ctl-Alt-C Clear Playlist. Needed when tracks are opened via Explorer and playback is to start at just opened track
( Updated for changes introduced in 0.9z-3 )
« Last Edit: December 29, 2013, 10:39:22 am by PeterSt »
« Reply #1 on: May 29, 2010, 06:42:00 pm » |
Thanks Russ.
« Reply #2 on: October 29, 2010, 09:43:56 am » |
Listing in Post#1 updated to reflect changes introduced with 0.9z-3
« Reply #3 on: October 29, 2010, 10:31:14 am » |
Thanks Russ, really useful.
For anyone who's interested, I've created a jpeg of these AutoHotKeys (attached) that I use as a desktop background on my dedicated XX PC...
Mani
« Reply #4 on: October 29, 2010, 11:07:08 am » |
Haha, a nice "trick" I have seen from users in my other "life" (ERP), and for exactly the same purpose. Good idea ! But ... This seems to urge for the red characters to be in blue or something - better readable on the black background. So, in order to not let Russ change his red into blue, you (Mani) might copy Russ' text into your own temporary post, have a "Preview" of it with the blue (or whatever you want - but better readable) characters, and draw a jpeg from there. In either case, many thanks. Peter PS: Now I can get rid of my sticky note.  PPS: What about making a photo of your remote, rework it with Paint or something, and integrate that with your Wallpaper. PPPS: Or what about one special large hot key (for the remote) which switches between the XX Wallpaper during playing - and this helpful jpeg ? Or maybe an OSD part where the hotkeys show up just in text ? (can be set On/Off next to the XX Wallpaper).
« Reply #5 on: October 29, 2010, 11:11:45 am » |
...I've created a jpeg of these AutoHotKeys (attached) that I use as a desktop background on my dedicated XX PC...
That's a clever idea Mani. Then I thought to myself, the background disappears on my system when in UN-attended mode so this is really only useful for attended mode. Nevertheless, if those shortcuts are in your vision most of the time you will probably remember them more easily. Russ
« Reply #6 on: October 29, 2010, 11:22:27 am » |
Russ, like you, I use UN-attended mode. My background stays...
« Reply #7 on: October 29, 2010, 11:26:30 am » |
PS: Now I can get rid of my sticky note.  Every little bit helps
« Reply #8 on: October 29, 2010, 11:28:32 am » |
hmmm .. OK. I shall investigate why mine disappears. ta
« Reply #9 on: October 29, 2010, 11:36:57 am » |
This seems to urge for the red characters to be in blue or something - better readable on the black background. Here's a blue... But I've really got to get down to some serious listening today... Mani.
« Reply #10 on: October 29, 2010, 11:50:08 am » |
PS: Now I can get rid of my sticky note.  Every little bit helps  LOL Russ. hmmm .. OK. I shall investigate why mine disappears. That seems obvious ... Mani isn't showing the XX Wallpaper, and *thus* his ShortCuts Wallpaper stays ... Or I don't understand what this is about ? Mani, thanks again. Peter
« Reply #11 on: October 29, 2010, 12:30:03 pm » |
hmmm .. OK. I shall investigate why mine disappears. That seems obvious ... Mani isn't showing the XX Wallpaper, and *thus* his ShortCuts Wallpaper stays ... Or I don't understand what this is about ? Mani, thanks again. Peter ah ... umm ... senior moment here! I've always used the XX wallpaper function and it never occurred to me that anyone wouldn't want the coverart displayed while in un-attended mode. When that option is unticked all behaves as expected.
« Reply #12 on: May 12, 2014, 06:53:34 pm » |
Mani
Thanks Mani. I downloaded and installed your desktop background today
