April 05, 2025, 06:49:31 am *
Author Topic: 0.9z Install problems  (Read 25818 times)
Marcin_gps
« Reply #15 on: October 02, 2010, 12:46:05 am »
In XXHighEnd directory.
« Reply #16 on: October 02, 2010, 05:13:42 am »
Ahaaaa ...
But the problem is not that those files are missing, the problem is that you didn't uninstall them when you wanted to get rid of 0.9z. The actual problem is that you installed 0.9z ...
BUT
What I learned from it (as it seems), is that when those files are there again (now they are not there on purpose) the problem goes away. Well, maybe. So, just in case, they will be there again in 0.9z-3.
Notice that they are there anyway after the install, but in System32.
So, all 'n all the problem is created by putting them in a directory A and register them there (like 0.9z required), next throw them out without unregistering, then install (hence register) them again but in Windows32, and now use directory A again for XX. The files are now just missing *there*.
In the end my fault because of the clumsey way 0.9z dealt with this.
Then I looked in 0.9z archive and compare that archive to 0.9z3 directory and found 2 missing files:
Just for others : the 0.9z3 is a typo here. We're still at 0.9z-2.
I have to uncheck the start as administrator. I have never gotten XX to work when checked. Same error message.
There's a topic floating around somewhere (by Flecko I think), and the solution to this is in there. Ah, here it is : cannot run as administrator anymore.
Thanks for your outlay Marcin, and sorry for your troubles.
Marcin_gps
« Reply #17 on: October 02, 2010, 11:35:27 am »
You misanderstood me. 0.9z2 didn't work in the first place, after series of tries, I went with 0.9z.
« Reply #18 on: October 02, 2010, 12:26:15 pm »
In that case you should have done something wrong regarding UAC at your first attempt ... (?)
Then it would be the other way around :
Your normal install isn't recognized (in System32), but the install in that "A" directory is. But only of the files are there.
Not sure ...
Marcin_gps
« Reply #19 on: October 02, 2010, 12:48:26 pm »
No, I'm sure I turned UAC first and rebooted PC before attempting to install XXHE. But it's goog that we know it could happen.
« Reply #20 on: October 02, 2010, 12:59:36 pm »
Assuming you wanted to say "Off" here ... strange. *And* never heard of it (which is different from having had installed 0.9z first).
Well, glad you got it working.
