November 22, 2024, 03:10:52 pm *
Author Topic: 0.9z Install problems  (Read 25222 times)
Tony S
« on: May 27, 2010, 01:40:19 am »
I am having problems installing the new version. The first attempt went fine in demo mode then I clicked on some button in the software, at some point getting familiar with the new layout Happy, and it hosed up the computer. I ended up having to do a hard boot. I then brought 0.9z back up again successfully and I activated the new version, went to restart XXHighEnd and I get a message saying XXHighEnd had stopped working. I tried another reboot and the same thing. I did a reinstall of the software and the same. Went back to the previous version and it works fine. Maybe I didn't read the instructions well on this new version in my wild frenzy to try it out. Any ideas on where I went wrong?
Tony
Vista Basic, Usb ->Musiland Monitor 02 -> Parasound Amp ->2.5 way Vifa/Scanspeak.
Ver. 0.9z-2, Playerprio-Low, Threadprio-Realtime, Buffer 256, 2x Upsampling, Adaptive Mode, Arc Prediction, Scheme-3, Q1- 1/10/10/0/0, SFS 70, Unattended, Services Off.
Tony S
« Reply #1 on: May 27, 2010, 02:54:02 am »
Here is the problem details I should have left with my last message.
Description:
  Stopped working
Problem signature:
  Problem Event Name:   CLR20r3
  Problem Signature 01:   xxhighend.exe
  Problem Signature 02:   1.0.3797.34912
  Problem Signature 03:   4bfc1621
  Problem Signature 04:   XXHighEnd
  Problem Signature 05:   1.0.3797.34912
  Problem Signature 06:   4bfc1621
  Problem Signature 07:   2985
  Problem Signature 08:   106
  Problem Signature 09:   System.InvalidOperationException
  OS Version:   6.0.6002.2.2.0.768.2
« Reply #2 on: May 27, 2010, 07:25:27 am »
Description:
  Stopped working
Problem signature:
Hi Tony, I think you must try this : How to delete a misbehaving ConfigFile.
It's a bit of a wild guess though, so let me know whether that helped.
« Reply #3 on: May 27, 2010, 12:24:19 pm »
Hmm ... I was thinking some further, and I might have a clue ...
(make sure XXHighEnd is not running ... oh, yeah, nice remark)
Please try this (copied from the Release Notes) :
- Open a command window (cmd.exe from the Startbutton - Run). Then go to your XX folder (CD \yourXXFolder) and in there, type these two lines :
regsvr32/u isanaloglibrary.ocx
regsvr32/u isdigitallibrary.ocx
Both commands should be followed by a message that the Unregistering has succeeded.
I am not sure at all this will finish allright. But if not, I'd estimate that you are not in the same folder as before, when things started to go wrong. In that case, recreate that folder if it's not there anymore, and copy these two files from the current XX foler into this other folder :
isanaloglibrary.ocx
and then perform the two regsvr32/u commands again (see above) from within the folder you just put in those two files.
Whether or not the commands now succeeded, now startup XXHighEnd again. It should come up with the two similar messages about registering, which if all is right, you have seen at the first time of installing 0.9z (hence running XX for the first time).
Let me know whether this helped ...
Peter (I'm out for a while now)
PS: If the above doesn't help, please post the XX log file of an attempt (in the TemporaryData folder under your XX folder, and after logging is switched on (Settings Area at the bottom)).
Tony S
« Reply #4 on: May 27, 2010, 10:14:28 pm »
      Thank-you for your help. I followed your instructions and the new 0.9z version is working! Looking forward to a listening session shortly. Thanks again.
Marcin_gps
« Reply #5 on: October 01, 2010, 07:26:37 pm »
Description:
  Stopped working
Problem signature:
Got back to Vista and can't run .9z2 - I get the above error. I have all necessary NET libraries, latest dx, tried removing config file - it doesn't work! Funny thing, because 0.9y8 works fine and sounds better (than optimized W7 + 0.9z2)  Happy
« Reply #6 on: October 01, 2010, 08:25:55 pm »
The latter is a good thing to begin with. Happy
Ok. Did you see that small install passing by ?
If not, there's a setup.exe in the XX folder. Run that.
It should be about those ocx files.
Here it went fine ...
Let me know,
Marcin_gps
« Reply #7 on: October 01, 2010, 08:41:46 pm »
Yes, it passed. I tried to remove it and install again - nothing changes, still the same error brrrrr Sad
Different folders won't work either.
« Reply #8 on: October 01, 2010, 09:11:32 pm »
Sh*t. I don't know ...
Still try to focus on this OCX thing.
If you uninstall it again, and next just start XX, what happens ?
(actually nothing much different because it should come up with that install again; but if it does not, is the error still the same ?)
sorry
Marcin_gps
« Reply #9 on: October 01, 2010, 09:52:47 pm »
Same sh*t again  no
Although, I have a clue - maybe it's related to folder attributes, because I somehow can't untick read-only...
« Reply #10 on: October 01, 2010, 11:09:04 pm »
What about UAC ? Start as Administrator stuf ??
Marcin_gps
« Reply #11 on: October 01, 2010, 11:26:45 pm »
UAC = OFF (tried on and off again - the same)
start as administrator - checked (always run XXHE this way)
I'll install 'the most important updates' via windows update and see than - over 100...
I remember having similar problem before, but somehow I managed to solve it.
Marcin_gps
« Reply #12 on: October 01, 2010, 11:53:57 pm »
Oh boy, the problem is solved and I know what's wrong. I went back to 0.9z and it worked fine, then I cleaned that directory and installed 0.9z2 in place of 0.9z - error again. Then I looked in 0.9z archive and compare that archive to 0.9z3 directory and found 2 missing files:
isAnalogLibrary.ocx
isDigitalLibrary.ocx
I assume that these should be right there after Phasure OCX install is passed, but not in this case. So I copied those files and everything is ok now Happy Thanks for your help.
wushuliu
« Reply #13 on: October 01, 2010, 11:54:36 pm »
I have to uncheck the start as administrator. I have never gotten XX to work when checked. Same error message.
Custom PC w/ 560 AM3/8GB/30GB SSD/Win7x64/Antec Earthwatt;Dacport LX; SimpleSE Tube Amp; Mark Audio Alpair or EL70 Fullrange w/ 8" Usher
wushuliu
« Reply #14 on: October 01, 2010, 11:56:27 pm »
isAnalogLibrary.ocx
Wait, where should those 2 files be?
