November 23, 2024, 08:50:01 am *
Author Topic: Changing the Hard drive  (Read 10144 times)
ivo
Music lover
View Profile WWW
« on: May 27, 2010, 12:17:59 am »
Hi all,
Just want to understand will it be OK with Windows7 activation if I switch from regular drive to SSD and reinstall Windows?
Will I be able to re-activate my Windows7 with the same key?
Ivo
Marcin_gps
« Reply #1 on: May 27, 2010, 12:37:30 am »
Yes, but you will have to get a new code from Peter.
« Reply #2 on: May 27, 2010, 04:56:59 pm »
I believe he can use the old one, if he has saved it somewhere. I mean, one code works for one pc.
« Reply #3 on: May 27, 2010, 05:30:22 pm »
Thank you Telstar - True. It depends a bit on what was changed though. And in either case it is no problem (for me) to hand out a new Code. It won't cost you another license anyway.
ivo
Music lover
View Profile WWW
« Reply #4 on: May 27, 2010, 08:08:43 pm »
Actually, I am not that worried about XX code rather than Win7 key.
Thanks.
« Reply #5 on: May 27, 2010, 09:48:50 pm »
If you have an official key, no problem. And if all goes normal, you won't even have to enter it (it's sorted out over the Internet automatically).
