November 23, 2024, 05:36:37 am *
Pages: 1 [2] 3  All
Author Topic: new GUI!  (Read 33976 times)
« Reply #15 on: May 26, 2010, 12:52:30 pm »
Hey Peter. I really like the new gui. Took some sorting out but I think I've got most of what I regularly use figured out.
One of the things that I noticed was that XX is much faster at loading songs into memory and beginning play. (Scheme 2)Its lightening fast here. I made sure from the first set up that logging activities was turned off.
One issue I've noticed is that there is no way to get back to a currently playing playlist, if you've left that screen, without reloading the playlist. There is just no button for "playlist" like in the other versions. Or maybe I'm doing something wrong?
The sound is Sweet too!
« Reply #16 on: May 26, 2010, 12:57:31 pm »
Roy , clear playlist is the arrow pointing up. Load is the one pointing down. I don't see a button to go to currently playing playlist.
« Reply #17 on: May 26, 2010, 12:59:33 pm »
Doh, that one has the led always on and if i click it duplicates the track in the playlist (while playing).
« Reply #18 on: May 26, 2010, 01:00:04 pm »
Please, Peter add tooltip and help entries for all buttons.
« Reply #19 on: May 26, 2010, 01:01:02 pm »
Telstar,
In the pane were you see the play and stop buttons, right under button in that pane is gallery button.
I found it, but it took me a good read of the release notes to understand Happy
Suteetat
« Reply #20 on: May 26, 2010, 01:21:14 pm »
Just got the new version. Nice looking but it will take a bit to get used to.
Quick question, is there an adjustment for q1-5 somewhere? I don't seem to
find one. Also with my computer, the older version in adaptive mode, I can get
by with buffer of 512 but the new version, I need buffer to 1024 to keep all the crackles
away.
« Reply #21 on: May 26, 2010, 01:27:42 pm »
To Suteetat,
In the pane were you see the play and stop buttons, right under button in that pane is gallery button, next to it is the button
that shows q sliders. (well no sliders, but knobs)
« Reply #22 on: May 26, 2010, 01:32:25 pm »
Okay, found the currently playing playlist button! Its the musical note in the upper left corner of the center screen.
I would recommend that this button be moved down in the play, load, clear button area. It's a little confusing having it "way" up there.
« Reply #23 on: May 26, 2010, 01:38:42 pm »
Maybe putting the playlist button right in the center above the counter would look cool!
Suteetat
« Reply #24 on: May 26, 2010, 02:06:30 pm »
Audiodidakt, thanks, I found it.
Suteetat
« Reply #25 on: May 26, 2010, 02:35:52 pm »
Hmmm... interesting, once I got adjusted q1 to 1 from the default 0, now I am able to go down on buffer all the way to
32 without any crackling in both special and adaptive mode. Not something I was able to do with previous version.
« Reply #26 on: May 26, 2010, 03:08:43 pm »
hehe,
Nobody will go unattended anymore with such a great looking GUI, whether this is a good thing ?
 good
Still room for improvement, but, great looks for an ever greater piece of software !
YOU ARE THE BEST  dancing
« Reply #27 on: May 26, 2010, 03:47:41 pm »
Can't access the playlist button if the GUI isn't fully opened, which I don't always do (expand the GUI) cause I'm addicted to substance not form, though this new form be beautiful  Happy  and I love the sound of Unattended.
« Reply #28 on: May 26, 2010, 11:12:48 pm »
But to me it seems that or you can drag the right border of the form to the right, or drag the splitter bar (i.e. the right border of the middle pane) to the left, and *then* drag the right border of the form to the right.
Or ?
« Reply #29 on: May 26, 2010, 11:17:44 pm »
Of course, you are correct. Wasn't thinking with all the new buttons to push!
Pages: 1 [2] 3  All
