November 23, 2024, 05:35:46 am *
Pages: [1] 2 3  All
Author Topic: new GUI!  (Read 33975 times)
« on: May 26, 2010, 12:55:48 am »
Still using the 8" touch screen. I can't find some buttons in 09z:
  • Clear-button to clear the playlist
  • Off-button to switch off XXHighend
  • Checkmark for unattended mode
Please put some pictures in your release notes.
(I'am not sure if your GUI is an improvement, not for a 8" lcd screen)
Regards, Johan
« Reply #1 on: May 26, 2010, 01:11:57 am »
Hey Johan,
Clear is "Eject" hence the button with the arrow pointing upwards.
Off is still available but far away at this moment. Just cross away the form (ah, you knew that one Happy).
Unattended is the middle button of the left three.
All still anticipates on 640x480.
« Reply #2 on: May 26, 2010, 09:28:34 am »
Overall is cool. But:
- confusing at first (couldnt find the gallery!) but when you get used it's a nice improvement.
- the buttons and text are way too small. This is exactly the opposite as what i expected. Try to see it at 1920x1200 and uou'll understand. I had to rely to the slow see below) tooltips to know what the hell every button was (except the config, play and stop which were obvious).
- Text too small in buttons and gui (ok in the help panel)
- Too much emboss makes the leds seem on and white, when they are off.
- tooltips take to long to appear, same applies for the help text in the middle panel when activated. But this can be related to the general slowness i experience.
- again please remove the transparency below the title bar.
- minimize, maximize and exit buttons on the upper right corner should have some picture in the off state, it's confusing as of now.
« Reply #3 on: May 26, 2010, 11:03:33 am »
Telstar is right about about the sluggyness,
xx is very slow, to select and play an album takes ages, I really mean dead slow.
And when xx finally plays a track, it just stops when track is finished.................
But I sure love the looks and sound coming from it
« Reply #4 on: May 26, 2010, 11:14:35 am »
Here too, I believe you of course,but elaborate as much as possible, just because I don't recognize it at all.
Btw, I use Scheme-3, and this sure WILL matter. I am not saying that you must Scheme-3 from now on, but I have to now exactly what is slow where.
Just give me one example to start with. Like the "select" you mention. How do you percieve that "select" as being slow ? what exactly happens ? don't forget what might be happening in the right pane !
Thanks.
« Reply #5 on: May 26, 2010, 11:31:50 am »
I will read your notes a couple of times extra first.
But ALL is slow, like a curtain of sluggyness fell upon xx.
I will elaborate in details later.
Why does xx places the XXAnalysis.dat file in the album folder I play ?
« Reply #6 on: May 26, 2010, 11:40:57 am »
You'd rather have it in the Program Files folder ? Happy Happy
IOW, I don't understand the question.
« Reply #7 on: May 26, 2010, 11:45:21 am »
Not really needed from what I read in your complaints. But there is a small list of issues at the end of the normal Release Notes (I don't mean those right at the bottom).
« Reply #8 on: May 26, 2010, 11:46:10 am »
I have nodiced things become real real slow when putting log activities on!
« Reply #9 on: May 26, 2010, 11:53:28 am »
Found the culpit on sluggyness.
IT IS THE LOG ACTIVITIES
Thnx Gerard good
« Reply #10 on: May 26, 2010, 11:59:04 am »
But xx does leave a trail of XXAnalysis.dat files in my music folders.
Can you explain why does this happens.
wow, every album played gets that file placed in the folder.
« Reply #11 on: May 26, 2010, 12:05:19 pm »
Where is clear playlist button ?
« Reply #12 on: May 26, 2010, 12:12:42 pm »
Yes when i read it it only shows HDCD-NO.
And where is the data map when switching on Logging???
« Reply #13 on: May 26, 2010, 12:36:48 pm »
Thnx Gerard good
Ohhh! Gotta remove it and try right now Happy
UI isnt sluggish anymore now.
But the playback still start a bit later than with the previous version.
i put a single track (using explorer, since i couldnt find the gallery), clicked on play button and waited 3s instead of about 2s.
« Reply #14 on: May 26, 2010, 12:43:44 pm »
Telstar,
In the pane were you see the play and stop buttons, right under button in that pane is gallery button.
If somebody could tell me were the "clear-playlist" button is !
Pages: [1] 2 3  All
