April 06, 2025, 05:08:49 am *
Pages: 1 2 3 4 5 [6]  All
Author Topic: SQ of 0.9z  (Read 79612 times)
« Reply #75 on: June 08, 2010, 05:16:45 pm »
Compared to my hoerwege usb/spdif hf resolution is not as good with the hiface.
So this must be wrongly put, or ?
(I guess you meant to say this the other way around ... or ... not so good with the hiface, I think ... hahaha, I changed my own sentense three times now)
Flecko
« Reply #76 on: June 08, 2010, 05:24:50 pm »
No this is for sure not wrong. But I deleted the reply because I like to listen to it a longer time. I hoped nobody has read it yet but you came before Wink The hiface is not bad but hf resolution is realy not as good. Parts might be not as good like in the hoerwege. the hoerwege is also not a dream and technically it has not this superior asynchronus mode but highs are better that is sure. It is not better in every aspect. I still have to listen more.
« Reply #77 on: June 08, 2010, 06:10:09 pm »
Ok, I can delete all the (by now) three posts if you want ...
Flecko
« Reply #78 on: June 08, 2010, 06:58:24 pm »
If you like you can but it is not so important to me. I tried some different settings now. It is very interesing how the sound depends on it. With Hoerwege I used special mode scheme2. The hiface lacked the hf resolution as I said but when I switch to scheme3! and adaptive mode the hf resolution comes back. So the settigns depends very much on the device. Now I would say hifiace is better. It is more dynamic and seperates the instruments better with a more massive sound. The hoerwege has still a bit more "air" but in every other aspect it is not as good. So i still live on the same planet as you, puhhh Happy
Page created in 0.017 seconds with 19 queries.
