« Reply #30 on: May 28, 2010, 05:27:57 pm » |
Soundcard 1024, and Q1 = 1.
But I'm also afraid you are comparing apples and oranges ... If you play this (HDCD) album in 0.9y-8c it will be (QAP) upsampled, while in 0.9z nothing will happen to it. So, I can listen to it, but I will do it in 352.8 anyway. This is not much usefull ...
But I will listen to it because I like to listen to music, haha.
« Reply #31 on: May 28, 2010, 05:31:23 pm » |
You are right, Peter
Its the buffer settings, much better with 1024 Now I have my bass and mids back
Thnx
And enjoy the music
« Reply #32 on: May 28, 2010, 05:34:00 pm » |
But still don't listen to HDCDs if you are used to QAP !! (you may have missed it, but it is a bug that HDCDs don't upsample).
Anyway, good that it helps. And you heard it pretty quick ! (as you should)
DannyD
« Reply #33 on: May 28, 2010, 05:38:24 pm » |
This makes me curious. If Audiodidact can play at buffer size=48, Q1=1, why is it better for him to play at 1024?
In my case, I can get my HiFace to work at 256, Q1=1. Should I too be playing at a higher buffer value?
June 10, 2010 Windows7Ultimate 32-bit / jkeny-modified HiFace / Berkeley Audio Alpha DAC /
« Reply #34 on: May 28, 2010, 05:39:03 pm » |
Anyway, good that it helps. And you heard it pretty quick ! (as you should) More fun now  Can be heard in the first seconds, just listen to Beef and it is pretty obvious !
« Reply #35 on: May 28, 2010, 05:45:10 pm » |
There is a hdcd led somewhere? It's funny because i'm listening to one of the HDCD albums courtesy of Roy and i'm loving the sound (using QAP on the computer where i always use it).
« Reply #36 on: May 28, 2010, 06:10:20 pm » |
using QAP on the computer where i always use it But sadly it doesn't do that (QAP). There is a hdcd led somewhere? Maybe I don;t understand the question, but under where normally the FLAC logo appears, there will be the HDCD logo, if HDCD encoding is detected.
« Reply #37 on: May 28, 2010, 06:12:21 pm » |
I think it depends what your preference is : KS Special Mode or Adaptive Mode. With Adaptive Mode I (personally) don't think the lower settings are better. Higher settings are more warm and of better color (all IMHHetc.O).
DannyD
« Reply #38 on: May 28, 2010, 06:31:20 pm » |
With 9z I'm preferring Adaptive, and I used to favor Special. I'll play around with increasing the buffer size to see how the sound changes. Do you have any objective way of determining what the optimal setting is - what I should listen or look for if it's too high or to low?
Thanks, Dan
« Reply #39 on: May 28, 2010, 06:38:02 pm » |
Danny,
Just try some settings between 48-1024 samples, Think as 1024 is maybe to fluffy in bass region 512 is more firm.
I stick with 512 for now
Roy
DannyD
« Reply #40 on: May 28, 2010, 06:43:54 pm » |
Thanks, Roy. I'll give it a try.
« Reply #41 on: May 28, 2010, 07:39:26 pm » |
Thanks, Dan Dan, Apart from just listening (like Roy tries / just did) I would always incorporate the cpu behaviour. The higher the buffer size, the more normal it gets. Normal = consistent. But it completely depends on the driver. In the very end it is listening of course. Peter
« Reply #42 on: May 29, 2010, 03:14:55 pm » |
There is a hdcd led somewhere? Maybe I don;t understand the question, but under where normally the FLAC logo appears, there will be the HDCD logo, if HDCD encoding is detected. Let me check. I dunno if the album was hdcd or not. The numbers in the top left still show the 176400 upsampled bitrate. Checking... OK, so it shows FLAC and below hdcd. This means that it's not upsampling, correct?
« Reply #43 on: May 29, 2010, 04:06:26 pm » |
Yep. Unless you use Octo/Double Octo.  And notice this is a bug. So, it will be solved.
ELFUEGO
« Reply #44 on: May 29, 2010, 07:32:55 pm » |
Hi to you all!!
I've just purchased the XXHIGHEND player!! This new 0.9Z was that amazing good that I just made my descission!
I am listening to it right now in Special Mode Q-1 /0/0/0/0
My system is a Gryphon Tabu / Ensemble PA-1/Profundo speakers and a Xindac dac-9 upsampling 192Khz. I am just starting to know what is my system capable of!!!!!!!! Laptop HP 1,66GHz 2,5 GB Windows 7 professional.
Peter, you did a very good job! I've tried J.River 15 / Foobar / I-tunes etc.and did not expect this kind of difference in sound. The Ensemble / Gryphon combo is obvious capable of a lot more I could ever dream of!!
Also my wife, whos is the best reference in listening, noticed the better quality immediately.
I am wondering what setings are better for my dac, wich is an usampling dac 24-192. Am am playinf 16 / 176400 right now / Invert / Arc Prediction(does that work on 16 B.
Any helpfull information is welcome!!
Al the best regards Peter,
ELFUEGO also known as Ronald (from the Netherlands also)
Win 7 pro - XXhigh-end 0.9z-2 engine4,sheme3 adaptive, 2048 samples, Q1,2,3,4, = 1,0,0,0 arc prediction,player low,thread real time, SFSis 18, hi-face with 5V battery, Xindak DAC-09, Gryphon Tabu, Ensemble PA-1+Profundo. Laptop HP nc6120 1,6Ghz.Cpu , 2,5 GB memory, Samsung Story 1,5TB.
