« on: May 26, 2010, 12:09:15 am » |
I have the following settings:
Special: Q1=1, buffer=32 Adaptive: Q1=1, buffer=32
Wow - Special sounds totally different to how it used to! It's drier... much drier than it used to be. My main criticism of the old Special was that it sounded a little too 'thin'. This is no longer the case.
Adaptive sounds... wonderful. Better than before? I'm not sure. But certainly as good. I likey, likey very muchy.
« Reply #1 on: May 26, 2010, 12:17:57 am » |
Special: Q1=1, buffer=32 This is 1 sample internal latency. Is this correct ? (yes, I am asking you, not myself haha)
« Reply #2 on: May 26, 2010, 12:31:57 am » |
Ah, slight misunderstanding I think.
The Q1 'knob' is set to 1, but the caption above says 'Q1 32'. So, I guess it's buffer=32 and Q1=32, right? If I take the knob down to Q1=0, then the caption reads 'Q1 16'... and I get distorted sound.
Sorry, my mistake.
« Reply #3 on: May 26, 2010, 12:42:13 am » |
No, it just is confusing. But I can't get the "32" on the button itself. So, I guess it's buffer=32 and Q1=32, right? With a net latency of 32 samples, yes. But you agree on the dry sound ? If you're only not placeboed by me (earlier today) ...
« Reply #4 on: May 26, 2010, 12:48:20 am » |
Absolutely not placeboed by you.
Special sounds much drier. So much so that I think you should check the code - I reckon you may have got Adaptive and Special the wrong way around! The overall sound is totally the opposite of how I had it only earlier today - Special was the 'sparkly' one and Adaptive the 'organic' one. Now it's the other way around... although I'd call Special 'dry' and Adaptive... well, just 'perfect' actually. It is very, very listenable.
Marcin_gps
« Reply #5 on: May 26, 2010, 09:13:36 am » |
This is the best sound I've had a chance to listen to from my PC - congratulations Peter! However, I'm not able to go lower than 1024 samples in special mode, still it's an improvemnt from 2000 something in 0.9y-c. Haven't tried adaptive yet, I'm afraid that I may hear sth worse :D
« Reply #6 on: May 26, 2010, 09:30:46 am » |
Adaptive sounds... wonderful. Better than before? I think so. Need to listen more.
Marcin_gps
« Reply #7 on: May 26, 2010, 09:48:08 am » |
I am sure it sounds better, at least in my system. The difference is clear to me after a second. Now I had trouble choosing Special/Adaptive. Special is sweeter, great for jazz/vocals, but heavier stuff sounds better via Adaptive, I suppose...
What a cr*ppy driver, it doesn't matter if I play with QAP or at 24/44 (even 16/44), I can't go below 1024 samples and that is for Special and Adaptive mode. Never mind, it sounds terrific
« Reply #8 on: May 26, 2010, 10:20:49 am » |
... Not to this post, but to the sound. I mean, don't get fooled because it sounds different (which it 100% sure does). And, enable yourself to come back on your own first findings. That is not stupid you know; you don't want to know how many times by now I came back on something I thought was better, at the fifth day of listening.
Why do I write this ? well, because I (again) have problems with proper judging myself because of doing two main things next to eachother : this software and the Phasure NOS1. I mean, at times I can't tell what causes what, while I have to proceed on both projects. Also, each has their own negatives (and positives) at changes, and when e.g. XXHighEnd gets worse, it is not said that this expresses through the current setting/setup of the DAC I am listening to.
If you all keep on saying that XXHighEnd got better, I will have to believe that, and take it as the standard. If with me things got worse for the net result, it has to be the DAC. Man, I hope you guys can believe what differences hardware changes can make (like one resistor) if bit perfect software already does *this* to us. Sometimes it drives me crazy and I don't know what to revert to.
There's also - I am fairly sure of that - the physical boundaries which just are there ... somewhere. I mean, if we are capable of getting out the waves better, then "better" means in general better outlined. Better outlined means more "sharp", or more transient like if you want. This by itself puts constraints on the hardware. So, one of the things I noticed, is that the step at going from 176.4 to 352.8 does something in unexpected areas, like capacitors suddenly can't cope (read : you start to hear them and they start to bring a flavour). You could think "but this happens to all DACs with a higher output rate", but I don't think this is so because of the ringing always happening (and that smears hence removes those (micro !) transients).
So you see, I can't do this alone. All input is welcome ! Thanks all, Peter
« Reply #9 on: May 26, 2010, 10:36:25 am » |
Peter, I don't know what you have done, but...
Special sounds totally diffferent from before. This is to be expected, right?
BUT...
It's Adaptive that's amazing me. What did you change? Anything? It's like you've read my mind - I wanted a combination of the old Special and old Adaptive... and to my ears, this is exactly what the new Adaptive brings.
Downsides with Adaptive? Well, the 'standing waves' in room seem to have shifted, so I'll now need to reassess my speaker and seating positions. I've just lost a bit of bottom end. But the top is beautifully sweet. I really don't think my DAC is 'struggling' in any way whatsoever.
I don't think Special is for me... with my current setup.
Marcin_gps
« Reply #10 on: May 26, 2010, 10:44:58 am » |
Good that you added "with my current setup". I believe that the differences between different setups, especially interfaces, could be vast.
« Reply #11 on: May 26, 2010, 11:39:10 am » |
Mani, I really don't think my DAC is 'struggling' in any way whatsoever. To be clear about things : this is not what I suggested. I was only talking anecdotally what happened to me a while ago, which looked as serious as Arc Prediction being wrongly coded for Octo. But I could solve it at the hardware side of things. The new means of KS Special Mode (which is new indeed) again brings things down to another level, and I too don't think it's the best. But this is mainly because Adaptive is so much better. That too changed, but by means of a less explicit fashion (but it did anyway, and I know it). Combine this all with what I said yesterday about cardboard stuff PLUS my added bass power, and you can see that all fits perfectly, including the bass side of things at Adaptive Mode which just falls into place at my site. The bass is hardware though, and what you said about it enables me to better judge Adaptive. By now I think this must be the hardest job of the world -> try to see through everything and see the elements involved. So again, your help is the most valuable in order to see those elements. Oh, if all is right, which the NOS1 you can move your armchair back to where it was. Hahaha.
Marcin_gps
« Reply #12 on: May 26, 2010, 12:47:51 pm » |
OK, after a series of comparisons, here are some thoughs regarding different modes:
Special: - richer midrange and that is why I liked it when I first hit the play button - better bass punch - gentle top end - overall I get the feeling of easy listening
Adaptive: - more details, especially at high frequencies - bass could be better - overall feeling - natural
Each has its advantages and disadvantages and it depends on album which I'm listening at the moment, but for me and my current setup Special is better at the moment.
« Reply #13 on: May 26, 2010, 12:49:53 pm » |
Now i'm sure too. Did an a/b too. The distortion is much lower, I feel wanting to raise the volume, which is always a positive thing in my book. 1024 samples as well. It's good that the same exact settings work with just... better SQ
Marcin_gps
« Reply #14 on: May 26, 2010, 01:35:48 pm » |
Another remark from my side. Adaptive always sounds good and coherent, no matter what kind of music we're listening to. This is not the case when it comes to special mode. Yes, there are tracks where you think it sounds better, but it's just an illusion  Just set a playlist with tracks of different genres and you will know what I'm saying. Special adds warmth and colour, but it's not a good thing in general (IMHO). I updated my signature and it's stays this way for a while.
