« Reply #90 on: May 28, 2010, 08:08:20 pm » |
Brian,
Engine3.exe is also used for Engine4 thats were we message comes from.
But, do turn of log activities in xx, and restart xx, hope this helps
Roy
« Reply #91 on: May 28, 2010, 09:15:09 pm » |
Thanks Roy. I just used Alt N to change tracks and am rebooting again cause that command caused the "Device Alocated Dread Message". Darn, these new fangled machines......
« Reply #92 on: May 29, 2010, 08:00:06 am » |
I just used Alt N to change tracks and am rebooting again cause which definitely indicates something is too slow in your machine. Please tell us whether you shut off that logging Roy talked about. And may you happen to know it, what brand of processor there is in your Dell (AMD/Intell). ... I am starting to smell things here ...
« Reply #93 on: May 29, 2010, 10:37:06 am » |
Yes I had shut off logging. My processor is 1.4 GHz Core 2 Duo, T5270. It definitely feels like my processor is being maxed out with the new GUI. When I tried to test some tracks in attended mode yesterday for a new playlist, I had way too many dropouts. Had to revert back to unattended.
Also, got bit by the playlist buttons yesterday. I had tracks playing and wanted to add another playlist. I selected the list that I wanted to add, and I'm so used to hitting the load button that I hit the save button and accidentally wiped out the tracks of the list I was trying to load! That list, the one I was trying to load, now names the list of tracks that were playing when I hit the save button. THis is mostly user error caused by a sudden spate of insomnia......Without a load button, its not possible to add a list to a currently playing list. Hope that makes sense.
However, the sound remains quite wonderful.
« Reply #94 on: May 29, 2010, 10:40:53 am » |
Forgot to mention that I nearly eliminated drop outs by reducing the split file size down to 60 from 200.
« Reply #95 on: May 29, 2010, 11:12:47 am » |
I can't make up whether you still didn't find the load button, but it's the one the mouse pointer is at.
« Reply #96 on: May 29, 2010, 11:15:28 am » |
Oops! Thanks Peter.
« Reply #97 on: May 29, 2010, 11:19:05 am » |
Something very weird just happened. I've been listening to Diary of Dreams album when suddenly the sound disappeared. OK, I start XXHE again, push stop and play again - nothing. Looking for process in task manager, nothing strange. I change the sample rate, try to play a test tone in playback devices properties - dead silence. Quick restart, hit play in XXHE and get horrible distrortions followed by To many buffer errors window.
I just experienced a similar situation. I had an album playing in UNattended mode and it completed OK. 5 or so minutes later I went to queue up a fresh album, hit PLAY, and when the GUI disappeared a flash of a error message appeared, but happened so quick I was unable to read it. Thereafter I was greeted with silence. No coverart or anything was forthcoming. ALT-X'ed back to GUI and tried again with similar results. Tried same album in attended mode and still silence. Went into control panel but couldn't even produce test tones from "Sounds" applet. So whatever happened during initial error, it mangled the resident audio driver code. A quick reboot and everything back to normal again. Couldn't find anything amiss amongst the system logs either which might have identified that error message. Will continue to monitor. Cheers, Russ
« Reply #98 on: May 29, 2010, 11:28:54 am » |
Russ, what I don't see in your sequence is - I brought up XX again. - I quitted it. - Brought it up again.The bold lines are necessary in such a situation, because it clears the (apparently) wrong cache data of something. The error message you saw in a flash must be unrelated, because I see it too, and all goes right after that. But might you be able to capture that error, I will be the most happy to know what it is ...  Thanks, Peter
« Reply #99 on: May 29, 2010, 11:30:45 am » |
Allright. But still something is slower of course. This is nightmare stuff. If only I had it too ...
« Reply #100 on: May 29, 2010, 12:35:20 pm » |
Russ, what I don't see in your sequence is - I brought up XX again. - I quitted it. - Brought it up again.The bold lines are necessary in such a situation, because it clears the (apparently) wrong cache data of something. The error message you saw in a flash must be unrelated, because I see it too, and all goes right after that. But might you be able to capture that error, I will be the most happy to know what it is ...  Thanks, Peter sorry Peter ... I wrote the abbreviated version of events  I did close down XXHE a few times and retried, but to no avail. I've seen that exception error pop up from time to time also, and I don't think it was one of those. The difficulty I had identifying the exact message contents was partly due to the text in the message being the same colour as the background. Casting my mind back to the event, I "think" i noticed ChangeWP consuming a heap of CPU cycles when I went looking into the process manager to check what might have been happening. If (when) it happens again I will activate full logging and see if anything turns up thereafter. ciao, Russ
Marcin_gps
« Reply #101 on: May 29, 2010, 12:47:32 pm » |
I just experienced a similar situation. I had an album playing in UNattended mode and it completed OK. 5 or so minutes later I went to queue up a fresh album, hit PLAY, and when the GUI disappeared a flash of a error message appeared, but happened so quick I was unable to read it. Thereafter I was greeted with silence. No coverart or anything was forthcoming. ALT-X'ed back to GUI and tried again with similar results. Tried same album in attended mode and still silence. Went into control panel but couldn't even produce test tones from "Sounds" applet. So whatever happened during initial error, it mangled the resident audio driver code. A quick reboot and everything back to normal again. Couldn't find anything amiss amongst the system logs either which might have identified that error message. Will continue to monitor. Cheers, Russ This situation happened few times and it always occurs when playlist ends in unattended mode and I don't bring up XXHE again shortly after last songs ends.
« Reply #102 on: May 29, 2010, 01:21:09 pm » |
Ok ... and when this happens, did XXHighEnd come up automatically after Unattended playback ? It should ... (after some 15 seconds or so).
« Reply #103 on: May 29, 2010, 01:31:12 pm » |
In my instance of that subsequent error the GUI was waiting for me after UNattended play finished the last track. I can't say for certain how long it took for GUI to come up as I wasn't paying attention to music server at the time. Within 15 seconds sounds about right under normal conditions though. Russ
« Reply #104 on: May 29, 2010, 03:11:56 pm » |
BTW, Peter please add an "APPLY SETTINGS" button - it's much better than quitting and restarting xxhe since i'm forced to do everytime a new version is up
