April 06, 2025, 06:25:59 am *
Pages: 1 2 3 4 [5] 6 7 8 9 10  All
Author Topic: 0.9z  (Read 123263 times)
Marcin_gps
« Reply #60 on: May 26, 2010, 06:19:24 pm »
And after a format I still can't achieve 1024 samples :D Than what kind of combination of settings or maybe specific order of running them (!) enabled my Cantatis to run at 1024 samples? I have no idea. I got it and now it's lost.
Everyone is running W7? Can anyone tell my how are things on Vista or XP?
Greets,
Marcin
Leo
« Reply #61 on: May 26, 2010, 06:30:35 pm »
You may laugh at this question  but where is the Unattended button these GUI days ?
Marcin_gps
« Reply #62 on: May 26, 2010, 06:37:04 pm »
Look for [X] near playback buttons Happy
« Reply #63 on: May 26, 2010, 06:44:55 pm »
I really like the upper-left pane, with all the digital readouts (I drive an old S2000 and still love the dashboard... even seven years on!) But it'd be great if the bit depth and sample rate readouts didn't keep defaulting back to '0' once XX resumes from Unattended - it's really nice knowing exactly what's going in and what's coming out.
glynnw
« Reply #64 on: May 26, 2010, 08:14:02 pm »
Help me please.  For the life of me, I cannot figure out how to get this thing to play music.  I don't use gallery.  I click on an artist in the left column, his albums then appear in the middle pane.  Before this new version I could double click on the album (or single click and then hit load) and then click on Play and I would get music.  Now when I try to double click I get the HDCD message. To get rid of this I click in an unused area and the message disappears, but is apparently still running.  (And are all of my WAV files really HDCD?)  Nothing ever appears in the playlist area.  How do I get an album pictured in the middle pane to play?
« Reply #65 on: May 26, 2010, 10:21:16 pm »
Hey Glynnw, I don't use galleries either. I'm not having your problem at all. Highlighting an album in left window, sends it to center window. Doule click and it loads here no problem. Maybe you should check log activities and send the appropriate file to Peter.
« Reply #66 on: May 26, 2010, 11:33:25 pm »
Hi Glynn,
What HDCD message ? There shouldn't be any, as none exists. Unless you are actually try to play and something goes wrong.
Please let me know this message exactly.
Btw Double Click still works; I just tested it.
Anyway for now, the Load button is the one at the right in the middle pane (near the bottom), with the down arrow on it.
Sorry for the inconveniencies,
« Reply #67 on: May 26, 2010, 11:37:20 pm »
Greets,
Marcin
Hi Marcin, what a stupid situation you have there.
The only thing I can imagine is that the (internally set ! by the OS) buffer size of your soundcard changed without notice. So, if you'd repeat the procedure to find its buffer size, do you come to the same as before ?
But actually I don't have other answers than : the most strange.
« Reply #68 on: May 26, 2010, 11:40:51 pm »
Something very weird just happened. I've been listening to Diary of Dreams album when suddenly the sound disappeared. OK, I start XXHE again, push stop and play again - nothing. Looking for process in task manager, nothing strange. I change the sample rate, try to play a test tone in playback devices properties - dead silence. Quick restart, hit play in XXHE and get horrible distrortions followed by To many buffer errors window. WTF? Nothing has changed, I didn't change anything nor install a thing. It's on the same track that played very well before. Special modes confirms that sth is going on. I had to increase the buffer size to 2048, both for Adaptive and Special mode to get rid of distortions, but it doesn't play that well now. My question is: what happened during that faulty playback that caused all of this?
Actually ... I recall you had something like that before. Or am I wrong ?
« Reply #69 on: May 26, 2010, 11:48:19 pm »
I have a problem with 0.9z. After installing the software I cannot get past the security warning for the programs like changewp, flac etc. . When i select run (uitvoeren) nothing happens. What could be the cause of this ???
Leo
Ineresting ... You may recall I mentioned this in the Release Notes, as I have it on one PC myself. And if I am correct there's an AMD in there. How this would relate (you have an AMF too it seems) ? dunno.
Keep in mind though : what I expect is that once the program in question is needed, you will be having the same probs, and just can't execute it.
The most strange (for me) is, that you prooved that before this was allright (unlike that PC of mine, which I never used for XX). So, can you perform FLAC conversions (if one of those programs you saw passing by indeed was FLAC.exe) ?
Marcin_gps
« Reply #70 on: May 27, 2010, 12:39:48 am »
Greets,
Marcin
Yes, that's strange and I'm sure we can't control everything, at least not in Windows :D
Marcin_gps
« Reply #71 on: May 27, 2010, 12:43:28 am »
Not exactly, I lost "the rabbit" after I've done "don't know what or system has done it for me". I think it's much easier to have a dedicated pc just for xxhe - no network, no 3rd party apps, no additional drivers.
glynnw
« Reply #72 on: May 27, 2010, 03:22:24 am »
Hey Boleary - Thanks for the suggestion.  When you double click on the album, are you immediately getting the security warning about running hdcd.exe?
« Reply #73 on: May 27, 2010, 04:09:52 am »
No.  Double click, tracks load; hit play and all works. Maybe I don't get that warning cause the hdcd.exe didn't install. I had to cancel most security warnings when installing cause, with most,  nothing happened when i clicked "Run". But everything seems to work here. A little weird....
« Reply #74 on: May 27, 2010, 10:36:19 am »
Occasionally only two track in a list will play, even though when I hit play it looks like all the tracks get processed into memory. This seems to happen when i select a file from the library and double click it to load it. Thereafter, all looks good but only the first two tracks play.
