April 05, 2025, 03:20:34 pm *
Pages: 1 2 3 [4] 5 6 7 8 9 10  All
Author Topic: 0.9z  (Read 123190 times)
« Reply #45 on: May 26, 2010, 02:12:37 pm »
cuetools,cuetools,cuetools,cuetools,cuetools,cuetools,
 Happy Happy Happy
« Reply #46 on: May 26, 2010, 02:15:48 pm »
I still have to scan my Jazz section, 4000CD's so i will find many more.
Will keep on adding newly find HDCD's on a list somewhere
Because there are more albums unkown than known as HDCD.
« Reply #47 on: May 26, 2010, 02:26:46 pm »
4000 Jazz CDs? Wow.
Looking forward to seeing your list. I will compile a list of the hirez HDCD material that I'm aware of. I reckon it will be slightly smaller than your list...
Flecko
« Reply #48 on: May 26, 2010, 03:01:04 pm »
One error occurs sometimes. If the last track in the playlist is played, playback stops without reason after about 1 minute. It happens on the prevous version too.
I have some fear about my DAC because of the distortion I get if the Q1 values are not set right for special mode. I wanted to try the new version and made settings for special mode and presed play. after that I swiched on my dac...no sync. I plugged the CDP ... no sync. Wandering what has happend I opend the case of my DAC to look if something is not right with the connector. Eveything was fine. After several minutes I tried the CDP again. It worked..puhh. I startet mediaplayer and plugged my usb/spdif, it worked. Now XXHE. Ouch... a lot of distortions. I set the buffer size wrong as it turned out. I am not sure if this is dangerous for any dac but probably you can check the output if the signal is clean, before passing it to the soundcard.
Thanks!
Marcin_gps
« Reply #49 on: May 26, 2010, 03:20:04 pm »
Something very weird just happened. I've been listening to Diary of Dreams album when suddenly the sound disappeared. OK, I start XXHE again, push stop and play again - nothing. Looking for process in task manager, nothing strange. I change the sample rate, try to play a test tone in playback devices properties - dead silence. Quick restart, hit play in XXHE and get horrible distrortions followed by To many buffer errors window. WTF? Nothing has changed, I didn't change anything nor install a thing. It's on the same track that played very well before. Special modes confirms that sth is going on. I had to increase the buffer size to 2048, both for Adaptive and Special mode to get rid of distortions, but it doesn't play that well now. My question is: what happened during that faulty playback that caused all of this?
« Reply #50 on: May 26, 2010, 03:24:22 pm »
No real idea here, except from your PC maybe being busy with something. A driver fault seems more likely though. Try a reboot, and don't forget to set back the buffer size ...
« Reply #51 on: May 26, 2010, 03:27:55 pm »
No danger to be expected. To your DAC this is just music. Happy
This is no window breaking sound, hence no max-max voltage jumps as with static. And even then, your DAC should be able to cope with that.
Marcin_gps
« Reply #52 on: May 26, 2010, 03:58:41 pm »
Sth must have changed, because I can't listen to that awful sound that's coming out of speakers...
Removed drivers, restarted, reinstalled drivers - same thing. Loaded last known  system configuration - the same. I' gonna reinstall the system again, damn. At least that's not taking so long, but Peter has to send me new activation code all over again. I wonder, how much time he's going to spend on that once there will a lot more "customers'...
easternlethal
« Reply #53 on: May 26, 2010, 04:45:56 pm »
Peter - I'm get a "HDCD decoding problem during decoding" error when decoding a FLAC encoded CD which XX has recognised as an HDCD in AP mode. No problems in AI or Linear mode. what gives?
Love the SQ (especially 'special' mode) by the way.
I like the new layout of the GUI a bit better in that the Q sliders are now more intuitively placed, as well as the double-octo slider thing (even though my DAC doesn't support 8x AP). Not sure about the knobs though or the way panels slide in and out. I find them a bit gimmicky. Am sure you're able to fit all the sliding panels on the same front panel no? Also the colour scheme is a bit.. er like something from the 80s.
These are just minor minor observations though, because I don't know enough to comment on what's under-the-hood other than that it sounds great and well worth the money!
[PC: Win7Ultimate 64 bit - SP1 Spinning Disk (no SSD)/Intel dual core/XXver.09Z-4-00 Settings: Adaptive/1024/Q1:1024/Arc Prediction + Peak Extension/Quad/SFS=2/Mixed/Unattended/12ms/Scheme 3] [Audio Chain: Weiss Dac 2 (via firewire) - Holfi 1.5.1 & NB1 - JBL 4428]
DannyD
« Reply #54 on: May 26, 2010, 04:53:08 pm »
Question for any HiFace users out there:
In Adaptive mode, the smallest Device Buffer Size I can achieve is 256 with Q1=1.  Anything smaller and I get a "too many buffer errors" error after several seconds of playing. Is this consistent with others' experience?
Leo
« Reply #55 on: May 26, 2010, 04:58:04 pm »
I have a problem with 0.9z. After installing the software I cannot get past the security warning for the programs like changewp, flac etc. . When i select run (uitvoeren) nothing happens. What could be the cause of this ???
Leo
« Reply #56 on: May 26, 2010, 05:03:54 pm »
Leo,
I installed 0.9z on my office machine this lunchtime and had the same issue(s). I just unticked the 'ask each time' box and pressed Run. As you said, nothing happens. I then pressed Cancel. I did this for the next 4-5 occurances of this.
When you then close and re-open XX, it works fine.
« Reply #57 on: May 26, 2010, 05:09:04 pm »
Massive Edit - I'm confusing myself!!!
Yes, getting something similar.
EDIT
Have you played with Q1 in Special Mode? I can get down to Q1=-1... that's 8 samples!... on an Atom machine!... ??? Are the hiFace drivers that good?
Leo
« Reply #58 on: May 26, 2010, 05:48:56 pm »
Thanks Mani that did the trick,
I had to do it about 20 times but then the program realized I would not quit so it gave in. And now I am listening and listening and listening
« Reply #59 on: May 26, 2010, 06:02:48 pm »
Hey Danny, what core appointment scheme are you using? Buffer size changes here depending on the scheme. I've been using Q1=1 @ 2046, Scheme 2.
