« Reply #30 on: May 26, 2010, 10:21:39 am » |
But can you manage to correct it ? (move the splitter bars)
Marcin_gps
« Reply #31 on: May 26, 2010, 10:26:09 am » |
No, I'm a total idiot, haha - joke
« Reply #32 on: May 26, 2010, 10:36:25 am » |
Peter, First the looks are really really nice!!! very good job you have done there.  But Special Mode does not work any more. Meaning lot of chraks tiks. Am i right and are the steps smaller when i set the buffer size to 4096 and like to fine tune with the Q1? Before Special Mode sometime's played allright. Adaptive Mode needs a higher Buffer size than before. This is 16\44.1 only. Setting to AP i can't play anything anymore. O and just writing this the music stops before the song has ended. (AM) (Building a new pc so things will be totally different when it's finished) ( I hope)
« Reply #33 on: May 26, 2010, 11:23:06 am » |
Adaptive Mode needs a higher Buffer size than before. Oh dear ... This is all going to be difficult I'm afraid. What I noticed is that for me it can be smaller now ! (and this was not expected). Am i right and are the steps smaller when i set the buffer size to 4096 and like to fine tune with the Q1? Not exactly, but they are at different places (better : the steps are different). What maybe (or hopefully) is the culprit here, is that for Special Mode you better set the Device Buffer Size to what it is in reality. This was NOT so before, and I didn't mention it in the Release Notes. In the end it should be the other way around as what you perceive : the Special Mode "working" settings for Q1 should be far more easy to find. But this starts with setting the real buffer size as to how it is. To find that, use Adaptive Mode first (and see the ToolTip howto do it). Please let me know whether this helps, because if so it has to be in the Release Notes (and the ToolTip etc.).
« Reply #34 on: May 26, 2010, 11:48:45 am » |
Peter, In the tooltips you say somethin like set to 1024 and the Q1 slider is communicating with the sounddevice. Than it will show the right setting. Where can i find that???
« Reply #35 on: May 26, 2010, 12:16:45 pm » |
Hi Gerard - I can try to repeat what's in the ToolTip instead of whay you just said, but it's not much useful. Please read what is in there, and notice it didn't change. You may copy paste the text if you want (see ? button) and make bold what you don't understand.
« Reply #36 on: May 26, 2010, 12:55:42 pm » |
All this below has been fixed by just disabling the log! Only the playback of a track is somewhat slower (20-30% tops), and i can live with that. Hey Telstar, The gui takes 3s to load compared to <1s. Yes, I can imagine something like that. Not 100%, because in the before situation it wasn't under a second on my system, while today it indeed may come down to 3 seconds. Personally I don't think this is a big deal, because you don't do this often. And very important : this doesn't happen this slow at Unattended and Remote Commands. Moreover, the library is behaving slowly and weirdly like when you first introduced KS. I know what you mean, but I'm afraid I can't do anything with it because as far as I can remember you always had the problem, and me myself and I dedicated it to you (to the sense of : couldn't interpret the problem well, caused it yourself etc. etc.), while at the same time I don't think I ever heard you solved it. ... Which is what you now imply. Yes, the problem went away in the third relase after KS was introduced. Now it went away after disabling the logs! The library is snappier than ever.  In either case I don't recognize it, but I sure hope you read the Release Notes - about the scrollbar issues. I did
« Reply #37 on: May 26, 2010, 12:57:52 pm » |
Not for me, the same worked (but there is a big difference between 768 and 1024, so the requirements may have changed but 1024 still covers it). Will check on the main system after a bugfix release is out
Marcin_gps
« Reply #38 on: May 26, 2010, 01:42:53 pm » |
Found a bug (I think). XXHE takes a WAV as a HDCD and the WAV file is a redbook.
« Reply #39 on: May 26, 2010, 01:51:44 pm » |
There are many CDs that are not identified as HDCD anywhere on their covers or inserts. E.g. the Steve Vai that I mentioned to Peter earlier. But don't be disappointed with this - it just means that its been mastered using the best converter ever made  It interesting to see a small increase in HDCD CDs being released - e.g. the recently remastered series by Steve Hoffman. Mani.
« Reply #40 on: May 26, 2010, 01:58:09 pm » |
2Pac & The Outlawz - 1999 - Still I Rise (HDCD) 311 - 1997 - Transistor (HDCD) 311 - 1998 - 311 Live (HDCD) 311 - 1998 - Omaha Sessions (HDCD) 311 - 1999 - Soundsystem (HDCD) 311 - 2001 - From Chaos (HDCD) 311 - 2003 - Evolver (HDCD) 311 - 2005 - Don't Tread On Me (HDCD) Al Di Meola - 1981 - Friday Night in San Francisco (HDCD) Alice Cooper - 1971 - Killer (HDCD) Alice Cooper - 1971 - Love It To Death (HDCD) America - 1983 - Your Move (HDCD) America - 1998 - Human Nature (HDCD) Andy Bey - 1974 - Experience and Judgment (HDCD) Andy Narell - 2004 - The Passage (HDCD) Ani Difranco - 2006 - Reprieve (HDCD) Art Ensemble of Chicago - 1974 - Fanfare for the Warriors (HDCD) B-52's - 1998 - Time Capsule (HDCD) Barb Jungr - 2002 - Every Grain Of Sand (HDCD) Beck - 1998 - Mutations (HDCD) Beck - 1999 - Midnite Vultures (HDCD) Beck - 1999 - Noboby's Fault But My Own (HDCD) Beck - 2000 - Stray Blues - A Collection Of B-Sides (HDCD) Beck - 2002 - Sea Change (HDCD) Bee Gees - 1998 - One Night Only (HDCD) - 2CD Bee Gees - 2001 - Their Greatest Hits - The Record (HDCD) - 2CD Bee Gees - 2001 - This Is Where I Came In (HDCD) Bee Gees - 2004 - Number Ones (HDCD) Bee Gees - 2005 - Love Songs (HDCD) Behemoth - 2004 - Demigod (HDCD) Benny Waters - 1999 - Live at the Pawnshop (HDCD) Bettye Lavette - 2004 - A Woman Like Me (HDCD) Big Kahuna & The Copa Cat Pack - 1999 - Hawaiian Swing (HDCD) Bill Laswell - 1998 - Jazzonia (HDCD) Billy Cobham - 1975 - A Funky Thide Of Sings (HDCD) Birdsongs of the Mesozoic - 2003 - The Iridium Controversy (HDCD) Blink-182 - 2003 - Blink-182 (HDCD) Blue Man Group - 2003 - The Complex (HDCD) Bob James - 1997 - Playin' Hooky (HDCD) Bruce Springsteen - 1999 - 18 Tracks (HDCD) Bryan Ferry - 1973 - These Foolish Things (HDCD) Bryan Ferry - 1974 - Another Time, Another Place (HDCD) Bryan Ferry - 1976 - Let's Stick Together (HDCD) Bryan Ferry - 1977 - In Your Mind (HDCD) Bryan Ferry - 1978 - The Bride Stripped Bare (HDCD) Bryan Ferry - 1985 - Boys and Girls (HDCD) Bryan Ferry - 1987 - Bete Noire (HDCD) Bryan Ferry - 1993 - Taxi (HDCD) Bryan Ferry - 1994 - Mamouna (HDCD) Béla Fleck & The Flecktones - 1998 - Left of Cool (HDCD) Béla Fleck & The Flecktones - 1999 - Greatest Hits of the 20th Century (HDCD) Béla Fleck & The Flecktones - 2000 - Outbound (HDCD) Béla Fleck - 1999 - The Bluegrass Sessions- Tales From The Acoustic Planet - Vol 2 (HDCD) Camel - 1984 - Stationary Traveller (HDCD) Camel - 1999 - Rajaz (HDCD) Camel - 2002 - A Nod And A Wink (HDCD) Camper Van Beethoven - 2004 - New Roman Times (HDCD) Cat Power - 1998 - Moon Pix (HDCD) Chris Isaak - 2006 - Best Of Chris Isaak (HDCD) Clark Terry & Bob Lark - 1996 - Clark Terry Express (HDCD) Corey Harris - 1999 - Greens from the Garden (HDCD) Covenant - 2002 - Nothern Light (HDCD) Creative Music Studio - 1981 - Woodstock Jazz Festival 2 (HDCD) Crosby, Stills, Nash & Young - 1999 - Looking Forward (HDCD) Crosby, Stills, Nash & Young - 2005 - Greatest Hits (HDCD) Cypress Hill - 2000 - Skull & Bones (HDCD) - 2CD David Byrne - 1997 - Feelings (HDCD) Deep Purple - 1970 - Deep Purple in Rock (HDCD) Deep Purple - 1972 - Machine Head {2010 Audio Fidelity 24 KT + Gold, AFZ 065}(HDCD) Deep Purple - 1973 - Who Do We Think We Are (HDCD) Delbert McClinton - 1997 - One Of The Fortunate Few (HDCD) Diana Krall - 2002 - The Best Music Just For You Vol 1 (HDCD) Diana Krall - 2002 - The Best Music Just For You Vol 2 (HDCD) Diane Schuur - 1999 - Music Is My Life (HDCD) Dick Dale - 1996 - Calling Up Spirits (HDCD) Dick Hyman - 1994 - From the Age of Swing (HDCD) Dick Hyman - 1996 - Swing Is Here (HDCD) Dire Straits - 1998 - (Sultans Of Swing) The Very Best of (HDCD) Dire Straits - 1998 - (Sultans Of Swing) The Very Best of (HDCD) - 2CD Doors - 1969 - The Soft Parade {2009 Audio Fidelity 24 KT + Gold, AFZ 038}(HDCD) Doors - 2000 - Essential Rarities (HDCD) Doors - 2000 - The Best Of The Doors (HDCD) Doors - 2003 - Legacy - The Absolute Best (HDCD) - 2CD Doors - 2006 - Perception (Box Set)(HDCD) - 6CD Dredg - 2002 - El Cielo (HDCD) Drumbo - 2008 - City of Refuge (HDCD) Earl Klugh - 1997 - The Journey (HDCD) Eric Clapton - 2007 - Complete Clapton (HDCD) - 2CD Etta James - 2004 - Blues To The Bone (HDCD) Faces - 1971 - A Nod Is As Good As A Wink... To A Blind Horse (HDCD) Faint - 2004 - Wet From Birth (HDCD) Fleetwood Mac - 2003 - Live In Boston - Vol 1 (HDCD) Fleetwood Mac - 2003 - Live In Boston - Vol 2 (HDCD) Fleetwood Mac - 2003 - Live In Boston - Vol 3 (HDCD) George Winston - 1999 - Plains (Solo Piano)(HDCD) Gerald McCauley's West-Coast All Stars - 2004 - Live Sessions (HDCD) Gil Parris - 1998 - Gil Parris (HDCD) Gorillaz - 2001 - Gorillaz (US Reissue)(HDCD) Grateful Dead - 2003 - The Very Best of (HDCD) Grateful Dead - 2004 - Wake Of The Flood (HDCD) Grateful Dead - 2007 - The Vault Box (HDCD) - 7CD Grateful Dead - 2009 - Winterland 1973; The Complete Recordings (HDCD) - 9CD Green Day - 1997 - Nimrod (HDCD) Greg Fishman & Jeremy Monterio - 2003 - Only Trust Your Heart (HDCD) Guitar Pete - 1999 - Burning Bridges (HDCD) Henry Kaiser & Wadada Leo Smith - 1998 - Yo Miles! (HDCD) - 2CD Ice Cube - 2000 - War & Peace Vol II (The Peace Disc)(HDCD) Ice Cube - 2003 - The Predator (HDCD) Ishii Yasushi - 2002 - Hellsing OST 1 RAID (HDCD) J. J. Grey & Mofro - 2007 - Country Ghetto (HDCD) Jacky Terrasson & Cassandra Wilson - 1997 - Rendezvous (Blue Note)(HDCD) Jacques Loussier Trio - 1998 - Satie - Gymnopedies Et Gnossiennes (HDCD) James Carter - 1998 - In Carterian Fashion (HDCD) James Newton Howard - 2003 - Dreamcatcher (OST)(HDCD) Jean Michel Jarre - 1998 - Odyssey Through O2 (HDCD) Jean Michel Jarre - 2006 - The Symphonic (HDCD) - 2CD Jeff Ball - 1998 - Reverence (HDCD) Jerry Garcia & David Grisman - 1998 - So What (HDCD) Jessye Norman - 2000 - I was Born in Love with You (HDCD) Jheena Lodwick - 2002 - Feelings (HDCD) Jheena Lodwick - 2005 - Getting To Know You [XRCD24](HDCD) Jheena Lodwick - All My Loving (HDCD) Jim Brickman - 1997 - Picture This (HDCD) Jimi Hendrix - 1992 - The Ultimate Experience (HDCD) Jody Williams - 2001 - Return Of A Legend (HDCD) John Barry - 1990 - Dances with Wolves - Extended (OST)(HDCD) John Fogerty - 1985 - Centerfield (HDCD) John Lee Hooker - 1997 - Don't Look Back (HDCD) John Mayall & The Bluesbreakers - 1966 - Blues Breakers with Eric Clapton (HDCD) Jonathan Butler - 1997 - Do You Love Me (HDCD) Josè Serebrier - 1999 - Serebrier conducts Serebrier (HDCD) Kaada & Patton - 2004 - Romances (HDCD) Karunesh - 2003 - Global Spirit (2000)(HDCD) Kaskade - 2003 - Its You, Its Me (HDCD) Keb' Mo' - 1998 - Slow Down (HDCD) Keiko Matsui - 1987 - A Drop of Water (HDCD) Keiko Matsui - 1994 - Doll (HDCD) Keiko Matsui - 1995 - Sapphire (HDCD) Keiko Matsui - 1996 - Dream Walk (HDCD) Keiko Matsui - 1997 - A Gift of Hope (CD5)(HDCD) Keiko Matsui - 1998 - Full Moon and the Shrine (HDCD) Keiko Matsui - 2000 - Keiko Matsui Live (HDCD) Keiko Matsui - 2000 - Whisper From The Mirror (HDCD) Keiko Matsui - 2001 - A Gift Of Life (HDCD) Keiko Matsui - 2001 - Deep Blue [Japan KMJ-1002](HDCD) Keiko Matsui - 2001 - Glances Of The Past (HDCD) Keiko Matsui - 2001 - In A Mirror [Japan VICJ-61522](HDCD) Keiko Matsui - 2002 - The Ring (HDCD) Keiko Matsui - 2003 - Doll (HDCD) Keiko Matsui - 2003 - The Piano (HDCD) Keiko Matsui - 2003 - White Owl (HDCD) Keiko Matsui - 2004 - Wildflower (HDCD) Keiko Matsui - 2005 - Walls Of Akendora (HDCD) Kenny Wayne Shepherd - 1997 - Trouble Is... (HDCD) King Crimson - 1969 - In The Court Of The Crimson King (HDCD) King Crimson - 1970 - In The Wake Of Poseidon (HDCD) King Crimson - 1970 - Lizard (HDCD) King Crimson - 1971 - Islands (HDCD) King Crimson - 1973 - Larks' Tongues In Aspic (HDCD) King Crimson - 1974 - Starless and Bible Black (HDCD) King Crimson - 1982 - Beat (HDCD) King Crimson - 1984 - Three Of A Perfect Pair (HDCD) Kinks - 1977 - Sleepwalker (HDCD) Kombo - 1999 - The Big Blast (HDCD) Linda Perry - 1996 - In Flight (HDCD) Lisa Miskovsky - 2003 - Fallingwater (HDCD) Live - 1997 - Secret Samadhi (HDCD) Madeleine Peyroux - 2005 - Dreamland (HDCD) Makyo - 2005 - Swara Mandala (HDCD) Marc Ribot y Los Cubanos Postizos - 1998 - The Prosthetic Cubans (HDCD) Marion Meadows - 1999 - Another Side of Midnight (HDCD) Mark Knopfler - 1996 - Golden Heart (HDCD) Mark Knopfler - 1998 - Wag The Dog (OST)(HDCD) Mark Knopfler - 2000 - Sailing To Philadelphia (HDCD) Mark Knopfler - 2004 - Shangri-La (HDCD) Matt Eakle - 1998 - Flute Jazz (HDCD) Metric - 2003 - Old World Underground, Where Are You Now (HDCD) Mike Garson - 1993 - The Oxnard Sessions Vol Two (HDCD) Mike Oldfield - 1973 - Tubular Bells (HDCD) Mike Oldfield - 1978 - Incantations (HDCD) Mike Oldfield - 1984 - Discovery (HDCD) Mike Oldfield - 1989 - Earth Moving (HDCD) Mike Oldfield - 2000 - Platinum (HDCD) Miklós Rózsa - 1970 - The Private Life of Sherlock Holmes (HDCD) Minnesota Orchestra - 1996 - Exotic Dances from the Opera (HDCD) Motley Crue - 1999 - Live Entertainment Or Death (HDCD) - 2CD N.W.A. - 2002 - The N.W.A Legacy Vol 2 {Compilation} Nancy Sinatra - 2004 - Nancy Sinatra (HDCD) Natalie Merchant - 1998 - Ophelia (HDCD) Neal Morse - 2003 - Testimony (HDCD) - 2CD Neal Schon - 1997 - Electric World (HDCD) - 2CD Neil Young & Crazy Horse - 1969 - Everybody Knows This Is Nowhere (HDCD) Neil Young & Crazy Horse - 1981 - Reactor (HDCD) Neil Young & Crazy Horse - 1996 - Broken Arrow (HDCD) Neil Young & Pearl Jam - 1995 - Mirror Ball (HDCD) Neil Young - 1968 - Neil Young (HDCD) Neil Young - 1970 - After The Gold Rush (HDCD) Neil Young - 1973 - Time Fades Away & Where the Buffalo Roam (HDCD) Neil Young - 1974 - On The Beach (HDCD) Neil Young - 2000 - Silver & Gold (HDCD) Neil Young - 2004 - Greatest Hits (HDCD) Neil Young - 2005 - Prairie Wind (HDCD) Neil Young - Archives Vol 1 (1963-1972) [8 HDCD Box Set Remastered] - 2009 Niacin - 1998 - High Bias (HDCD) Nils Petter Molvær - 2002 - NP3 (HDCD) Olu Dara - 1998 - In The World - From Natchez To New York (HDCD) Opeth - 2005 - Ghost Reveries (HDCD) Pat Donohue & Mike Dowling - 2001 - Two of a Kind (HDCD) Patricia Barber - 1994 - Cafe Blue (HDCD) Patty Griffin - 2003 - A Kiss in Time (HDCD) Patty Griffin - 2008 - Impossible Dream (HDCD) Paul Anka - 2003 - The Vey Best Of (HDCD) Paul Simon - 2000 - You're The One (HDCD) Paula Cole - 1996 - This Fire (HDCD) Peter Frampton - 2001 - Frampton Comes Alive 25th Anniversary (HDCD) - 2CD Peter Green Splinter Group - 1999 - Destiny Road (HDCD) Peter White - 1996 - Caravan Of Dreams (HDCD) Pieces Of A Dream - 2001 - Acquainted With The Night (HDCD) Pieces Of A Dream - 2002 - Love's Silhouette (HDCD) Rick Braun - 1996 - Body And Soul (HDCD) Rickie Lee Jones - 2003 - The Evening of My Best Day (HDCD) Rod Stewart - 1972 - Never A Dull Moment (HDCD) Rosemary Clooney - 2000 - Brazil (HDCD) Roxette - 2006 - Roxette Hits! - A Collection Of Their 20 Greatest Songs! (HDCD) Roxy Music - 1972 - Roxy Music (HDCD) Roxy Music - 1973 - For Your Pleasure (HDCD) Roxy Music - 1973 - Stranded (HDCD) Roxy Music - 1974 - Country Life (HDCD) Roxy Music - 1975 - Siren (HDCD) Roxy Music - 1976 - Viva! Roxy Music (HDCD) Roxy Music - 1979 - Manifesto (HDCD) Roxy Music - 1980 - Flesh + Blood (HDCD) Scott Henderson - 1997 - Tore Down House (HDCD) Seal - 2009 - Hits (HDCD) - 2CD Shana Morrison - 1999 - Caledonia (HDCD) Stabbing Westward - 1998 - Darkest Days (HDCD) Stephen Stills - 1972 - Manassas (HDCD) Stevie Nicks - 1998 - Enchanted (HDCD) - 3CD Story of the Year - 2003 - Page Avenue (HDCD) Studebaker John & The Hawks - 1997 - Time Will Tell (HDCD) Sun Ra - 1978 - Lanquidity (HDCD) Talking Heads - Stop Making Sense (Special New Edition)(HDCD) Teardrop Explodes - 1980 - Kilimanjaro (HDCD) Teardrop Explodes - 1981 - Wilder (HDCD) The Band - 1978 - The Last Waltz (HDCD) - 2CD Tom Petty - 1995 - Playback (6-CD Box HDCD) Tool - 2001 - Lateralus (HDCD) Tortoise - 1998 - TNT (HDCD) Tracy Chapman - 2000 - Telling Stories (HDCD) Trisha Yearwood - 1998 - Where Your Road Leads (HDCD) Tsuyoshi Yamamoto trio - 1974 - Misty (HDCD) VA - Asian Travels 2 - 2002 [Six Degrees](HDCD) VA - Blues Way Vol 8 (2001)(HDCD) VA - FIM Audiophile Reference II (2003)(HDCD) VA - FIM Audiophile Reference IV (2003)(HDCD) VA - Funky Harmonica (2007)(HDCD) VA - HDCD Sampler Vol 2 (1995)(HDCD) VA - Jazz For The Road (2006)(HDCD) VA - Moroccan Spirit (2002)(HDCD) VA - Mushroom Jazz Vol 4 - Mixed by Mark Farina (2002)(HDCD) VA - Ocean's Eleven (2001)(OST)(HDCD) VA - Paint It Blue - Songs of the Rolling Stones (1997)(HDCD) VA - The Music Of Pink Floyd (2005)(HDCD) VA - Tribal Matrix 2 (2009)(HDCD) Van Halen - 1978 - Van Halen (HDCD) Van Halen - 1979 - Van Halen II (HDCD) Van Halen - 1980 - Women And Children First (HDCD) Van Halen - 1981 - Fair Warning (HDCD) Van Halen - 1982 - Diver Down (HDCD) Van Halen - 1984 - 1984 (HDCD) Within Temptation - 2004 - The Silent Force (HDCD) Within Temptation - 2007 - The Heart Of Everything (HDCD) Yes - 1981 - Classic Yes (HDCD) Yes - 2001 - Magnification (HDCD) ZZ Top - 2003 - Chrome, Smoke & BBQ (Boxset)(HDCD) - 4CD
« Reply #41 on: May 26, 2010, 02:06:53 pm » |
Hey Roy, great list !!
I guess now I can avoid that function that will sort out the HDCDs we have, right ?
But it is true, there are many more than the coversheets tell. Plus I think it matters for SQ ... But that could just as well Mani's mani ... the recorder.
Anyway Roy, thanks a lot.
« Reply #42 on: May 26, 2010, 02:08:32 pm » |
That looks like a list of 'official' HDCD releases. The ones I'm talking about are things like 'Steve Vai - The Ultra Zone', 'Dave Brubeck - Time Out' and 'Jacques Loussier - Satie', etc...
Without opening up a whole HDCD discussion, these may have the HDCD flag included in the LSB (hence why they're being detected as HDCDs), but may not necessarily be recorded with Peak Extension. There is a debate as to whether this is a good or bad thing.
« Reply #43 on: May 26, 2010, 02:10:44 pm » |
I will make a function which will find them all. I really think it is worth while.
In the mean time Mani, please give a few examples of hires HDCD (you talked about that yesterday), so I can cover that hopefully.
Thanks, Peter
« Reply #44 on: May 26, 2010, 02:11:31 pm » |
[Verification date: 26/03/2010 19:56:46] [Disc ID: 00098475-002b4bb5-4009a905] HDCD: peak extend: yes, transient filter: none, gain: -4,0dB..0,0dB Offset applied: -48 Track [ CRC ] Status 01 [b342b2a6] (07/117) Accurately ripped 02 [11b1018b] (07/115) Accurately ripped 03 [a88a4af9] (07/114) Accurately ripped 04 [0c737411] (07/115) Accurately ripped 05 [4896bbcb] (07/111) Accurately ripped Offsetted by -1474: 01 [3cd1e572] (32/117) Accurately ripped 02 [19ac3ee2] (31/115) Accurately ripped 03 [f9e14cf6] (31/114) Accurately ripped 04 [80a0f59c] (32/115) Accurately ripped 05 [f2eee870] (31/111) Accurately ripped Offsetted by -438: 01 [3427830f] (36/117) Accurately ripped 02 [150c6672] (35/115) Accurately ripped 03 [402205d1] (35/114) Accurately ripped 04 [38e32539] (35/115) Accurately ripped 05 [27eaec18] (32/111) Accurately ripped Offsetted by -254: 01 [d80ae5f3] (07/117) Accurately ripped 02 [8a3ab54d] (07/115) Accurately ripped 03 [f2e2eb44] (07/114) Accurately ripped 04 [6ef235cd] (07/115) Accurately ripped 05 [e92a49fc] (07/111) Accurately ripped Offsetted by -236: 01 [d0fdf35d] (02/117) Accurately ripped 02 [ccc27c68] (02/115) Accurately ripped 03 [738e6cfd] (02/114) Accurately ripped 04 [b39a5cdc] (02/115) Accurately ripped 05 [9019721d] (02/111) Accurately ripped Offsetted by -51: 01 [7517627b] (02/117) Accurately ripped 02 [8e8dec66] (02/115) Accurately ripped 03 [ff104c1b] (02/114) Accurately ripped 04 [5406f7b4] (02/115) Accurately ripped 05 [1ed340f4] (02/111) Accurately ripped Offsetted by 508: 01 [37307916] (10/117) Accurately ripped 02 [404613da] (10/115) Accurately ripped 03 [557ab0dc] (10/114) Accurately ripped 04 [2e09e57d] (10/115) Accurately ripped 05 [8fdcc972] (10/111) Accurately ripped Offsetted by 715: 01 [a8b0864a] (13/117) Accurately ripped 02 [e26a506d] (13/115) Accurately ripped 03 [fd4b6e1e] (12/114) Accurately ripped 04 [c9f5613a] (12/115) Accurately ripped 05 [7e3bc3d4] (12/111) Accurately ripped Offsetted by 744: 01 [16e51768] (03/117) Accurately ripped 02 [1e49d2ee] (03/115) Accurately ripped 03 [cbf0c937] (03/114) Accurately ripped 04 [9ddd97fd] (03/115) Accurately ripped 05 [0c962e2d] (03/111) Accurately ripped
Track [ CRC32 ] [W/O NULL] -- [6F274184] [AEFEDC42] 01 [90D2C7F0] [CD31ED3C] 02 [648F8303] [2EA0B281] 03 [24971479] [CBB9C403] 04 [FCA8CE58] [CDBF9AE5] 05 [C104AB5A] [1293E363]
This log is shown in every folder, created by cuetools.
