April 05, 2025, 03:35:42 pm *
Pages: 1 [2] 3 4 5 6 7 8 9 10  All
Author Topic: 0.9z  (Read 123193 times)
« Reply #15 on: May 25, 2010, 11:41:15 pm »
Well, I don't know what's happening!
Over here:
- Engine#3 doesn't work at all - I mean for all files (HDCD, non-HDCD, all resolutions) for all buffers (set in soundcard, not XX) - I get 'XXEngine#3 has stopped working' error.
- Special doesn't work for 16.44.1 HDCDs - cursor/timer moves, but no sound.
- Adaptive's right channel doesn't work for 16/44.1 HDCDs.
- AP indicator switches off at resume UNLESS 'PeakExtend' is activated also.
Am I the only one with these errors?
« Reply #16 on: May 25, 2010, 11:45:57 pm »
Yep, I can confirm the AP light not being on after restart when Peak Extension is not on.
And yep, I can confirm Engine#3 not working at all.
So, at least that is clear. swoon
« Reply #17 on: May 25, 2010, 11:46:13 pm »
For now i have only one word: SLOW, painfully slow UI and that's from my E8500.
PS: please remove the transparency below the top bar, it is annoying.
« Reply #18 on: May 25, 2010, 11:49:58 pm »
Not true ... If you quit and restart it works. Not sure what that is, but I can imagine some things.
« Reply #19 on: May 25, 2010, 11:51:21 pm »
The slowness is yours (isn't it always Happy).
You could try to qualify it though ...
« Reply #20 on: May 25, 2010, 11:55:50 pm »
True after all. Sorry for the confusement.
« Reply #21 on: May 26, 2010, 12:56:16 am »
The HDCD mystery is solved...
Even though 4x AP is selected, and the output is showing as 176000 in XX, this is NOT what is being actually being output. The output is 24/44.1. I had my DAC set to 24/176.4 (i.e. in dual-wire mode) instead of 24/44.1, so only one channel was working.
I got confused because of the 17600 output showing in XX - I thought the 24/44.1 file was being upsampled to 24/176.4. I know that at some point, XX will be able to upsample 24bit files, but I guess not yet!
EDIT
I think this will need to be changed. I played around with HDCD.exe and didn't really like the results. I preferred the HDCD filter in my DAC. But even moreso, I preferred HDCD files with QAP.
« Reply #22 on: May 26, 2010, 01:06:14 am »
WHAT ?!
No, it should just upsample ...
But of course I believe you. It is complicated enough to ... no, wait ... shoot, you're right ! My driver says so too.
Great thanks for your time on this one Mani. Really appreciated.
« Reply #23 on: May 26, 2010, 01:18:36 am »
WHAT ?!
Ah, that mystery is solved at least for me. It only works with OAP (and DOAP) ...
I was already afraid I had been listening to 44100 without noticing it ... aggressive
Will be solved.
« Reply #24 on: May 26, 2010, 01:29:21 am »
I made a special gallery for this, about 400 HDCD's Wink
Great job ! and perfect timing !
But do they sound better, extracted to 20/44 ?
« Reply #25 on: May 26, 2010, 09:24:00 am »
It is strange indeed, since you have a slower cpu.
I was straight to bed when i posted. I will elaborate:
The gui takes 3s to load compared to <1s. Then, when i click play it takes more than 5 seconds to start playing! Same settings as the previous version.
Moreover, the library is behaving slowly and weirdly like when you first introduced KS. Maybe some code rolled back? Maybe some optimizations are out?
BTW, ceteris paribus i THINK SQ improved (adaptive).
i'll talk about the GUI in the other thread.
Marcin_gps
« Reply #26 on: May 26, 2010, 09:39:24 am »
Few remarks from my side:
- new GUI is nice, but quite unreadable (especially indicators next to the buttons and in settings area - I had to come closer to the screen to see if it's red or green, that's also confusing - red usually means that it's not active)
- I can't upsample 24bit files (wasn't able before as well)
- there's been a problem with application's window size and here is the same thing - one section appears on other. You should set fixed min. size of each section.
- sq is awesome  Happy
« Reply #27 on: May 26, 2010, 09:45:14 am »
Hey Telstar,
Quote from: Telstar
Yes, I can imagine something like that. Not 100%, because in the before situation it wasn't under a second on my system, while today it indeed may come down to 3 seconds.
Personally I don't think this is a big deal, because you don't do this often. And very important : this doesn't happen this slow at Unattended and Remote Commands.
I know what you mean, but I'm afraid I can't do anything with it because as far as I can remember you always had the problem, and me myself and I dedicated it to you (to the sense of : couldn't interpret the problem well, caused it yourself etc. etc.), while at the same time I don't think I ever heard you solved it. ... Which is what you now imply.
In either case I don't recognize it, but I sure hope you read the Release Notes - about the scrollbar issues.
So, it is not that I don't believe you, it is that I don't understand you (did I ever ? hahaha)
When you can describe the problem better, please open a new topic for it, so we can better deal with it there, ok ?
« Reply #28 on: May 26, 2010, 09:49:07 am »
I don't think so. What I do think is that you set the OS font size to more than 100%, and there is no way to deal with that properly at going from 100% to (e.g.) 125% by means of explicit code. Very hard to explain, but what it comes down to is that you must fix the sections yourself (there are two splitter bars) and then it's okay.
Or otherwise just show your screen so I can see what you mean. Ok ?
Marcin_gps
« Reply #29 on: May 26, 2010, 09:56:59 am »
You're correct, 125%... Wink
