« Reply #105 on: May 29, 2010, 04:09:43 pm » |
I really don't understand what you mean now. Is this related to the earlier posts ? or something new ? In either case I don't get it.
« Reply #106 on: May 29, 2010, 04:23:40 pm » |
Hi Peter, when trying to play an mp3 I ripped from a dvd back in 2006, I got the tag.exe security warning shown here. I assume it was part of the software I couldn't get to run when I installed 9z. I may have to try to find that dvd to rerip the file.......
« Reply #107 on: May 29, 2010, 05:50:04 pm » |
Hi boleary,
that Tag.exe was compiled over 7 years ago now and wouldn't incorporate the publisher coding that Micro$oft likes everyone to include. My advise would be to take the tick out of the "Always ask before opening this file", then click on "Run". You shouldn't be bothered again by that message following that course of action.
If you really want to know what it does, simply google Tag.exe , and read all about it in places like hydrogenaudio.org forums.
Marcin_gps
« Reply #108 on: May 29, 2010, 06:03:30 pm » |
Ok ... and when this happens, did XXHighEnd come up automatically after Unattended playback ? It should ... (after some 15 seconds or so).
It pops with the window telling me to set up a library. I don't use that, like total commander + drag & drop
Marcin_gps
« Reply #109 on: May 29, 2010, 06:06:25 pm » |
Another tiny bug; mouse scroll doesn't work in the settings area.
easternlethal
« Reply #110 on: May 29, 2010, 06:13:51 pm » |
Peter is there any chance you can add 3024 to the buffer settings? This is my DAC's highest buffer after 2048. Unfortunately I can only chose 2048 or 4096 in XX but 2048 or 3042 in my DAC's settings. Also, if my DAC is 24/192 why does it default to 174 when I select Arc Prediction? When I select the 96 or 192 only button in the settings area and Anti Image then I get 192 but that option is not available in Arc Prediction? Sorry as you can tell I don't have a great understanding of device buffers and latency..
[PC: Win7Ultimate 64 bit - SP1 Spinning Disk (no SSD)/Intel dual core/XXver.09Z-4-00 Settings: Adaptive/1024/Q1:1024/Arc Prediction + Peak Extension/Quad/SFS=2/Mixed/Unattended/12ms/Scheme 3] [Audio Chain: Weiss Dac 2 (via firewire) - Holfi 1.5.1 & NB1 - JBL 4428]
« Reply #111 on: May 29, 2010, 06:40:43 pm » |
Thanks Russ, but the problem is that when I click "Run" nothing happens and I have to hit cancel for the security warning to go away. Leaves me unable to play the file. When I was first installing 9z many of the software components that generate security warnings failed to run when I hit run and now, it seems, parts of XX are not working.
« Reply #112 on: May 29, 2010, 07:06:23 pm » |
Correct. I hope I have solved it here for the moment of installing (very hard to test). So for now indeed it can't be used. Btw, nice for new users ... they won't be able to use anything ...
« Reply #113 on: May 29, 2010, 07:08:18 pm » |
It pops with the window telling me to set up a library. I don't use that, like total commander + drag & drop So it will forever and ever ask you for this. Better make a dummy folder and point it to there. Btw, you are missing 95% of the functionality now ...
« Reply #114 on: May 29, 2010, 07:11:59 pm » |
Peter is there any chance you can add 3024 to the buffer settings? This is my DAC's highest buffer after 2048. Unfortunately I can only chose 2048 or 4096 in XX but 2048 or 3042 in my DAC's settings. Of course I can. And so I will ... it is important enough to have it right. Also, if my DAC is 24/192 why does it default to 174 when I select Arc Prediction? When I select the 96 or 192 only button in the settings area and Anti Image then I get 192 but that option is not available in Arc Prediction? Sorry as you can tell I don't have a great understanding of device buffers and latency.. Because Arc Prediction can only filter to / upsample to "even" sample rates. Thus, 44.1 to 88.2, 176.4, 352.8, 705.6. Or 48 to 96, 192, 384, 768. If your DAC can't cope with the first row, you are in bad luck I'm adraid ... If it is not clear (enough) let me know. Peter
Marcin_gps
« Reply #115 on: May 29, 2010, 09:51:34 pm » |
It pops with the window telling me to set up a library. I don't use that, like total commander + drag & drop So it will forever and ever ask you for this. Better make a dummy folder and point it to there. Btw, you are missing 95% of the functionality now ...  Total Commander is functional too, but I'm gonna switch to XXHE library once I will handle missing covers
easternlethal
« Reply #116 on: May 30, 2010, 01:59:37 am » |
Of course I can. And so I will ... it is important enough to have it right. Appreciated, thanks. The rate is actually 3072, to be precise. If your DAC can't cope with the first row, you are in bad luck I'm adraid ... Thanks for the clarifying. My DAC is capable of receiving 44.1/176 (which is what I am using now, but it is capable of going up to 48/192). so.. 48 to 96, 192, 384, 768 from this, I take it that it is possible for XX to upsample to 48/192. Do you know how I can do that? The octo slider seems to only allow one to select the multiple (i.e. 44.1X1, or 44.1X2 etc.) but not from 44.1 to 48. Sorry if I am missing something.
« Reply #117 on: May 30, 2010, 07:45:25 am » |
There is a base. This base can be anything. This base can be upsampled to even amounts (look at the two before mentioned rows). This is done with the slider (2x, 4x, etc.). When you want to go from 44.1 to 96 or 192 you must make the "96 Khz / 192 KHz only" setting active (Settings Area), and when you now use 2x with a base of 44.1, 96 will be selected instead of 88.2. If you use 4x with a base of 44.1, 192 will be selected instead of 176.4. But keep in mind : The Anti Imaging filter will do it now. There is no real useage in this, unless your DAC can't take 88.2 and 176.4 for input (and they do exist).
PS: Currently only 44.1 (and 48) can be used as a base for upsampling. The others will follow later.
easternlethal
« Reply #118 on: May 30, 2010, 10:36:06 am » |
There is no real useage in this, unless your DAC can't take 88.2 and 176.4 for input (and they do exist). But isn't it better to have arc prediction play 48/192 rather than 44.1/176?
« Reply #119 on: May 30, 2010, 11:59:05 am » |
If all your material would be 48KHz yes. But the argument for it is wrong. I mean, if you ask the question like this, to me it seems that you will be converting 44.1 to 48 first (?). Don't !
