April 05, 2025, 12:38:54 pm *
Author Topic: Optimising PC for KS Special Mode  (Read 23600 times)
Marcin_gps
« Reply #15 on: May 25, 2010, 04:33:33 pm »
Well, assuming that your soundcard can take both 24 and 32 bits (which is not common at all), when set to 24 bits you're using less bandwidth (because I'm sending 24 bits instead of 32 bit in that case).
But it sounds so much worse on a 24bit DAC.
I don't understand ?
I don't understand as well. How a wav track with 16bit resolution sounds worse when I set DAC to 16/44 in XXHE? Also, how could the same 16bit wav file sound different when DAC needs is set to 24bit and again 32bit? Technically there should be no information, all zeros, right?
« Reply #16 on: May 25, 2010, 04:44:09 pm »
Ah ... about the 16/44.1 ... of course that matters, but it depends on settings. Never mind for now, but before you know it you imply the useage of 24 or 32 bits. And that certainly won't happen when you tell XX that your DAC is 16 bits.
About the 24 vs 32 ... as I told ... this is bandwidth related. And *everything* matters ...
« Reply #17 on: May 25, 2010, 08:19:54 pm »
That leads me to conclusion: drivers' "performance" is more important than overall performance of a PC
I quite agree with this Happy
