November 23, 2024, 08:58:48 pm *
Author Topic: MB energy saver  (Read 20598 times)
« Reply #15 on: May 22, 2010, 07:09:15 pm »
How will mobo still effect sound quality with NOS1 connected ?
Sheer impossible. I didn't test (swap) anything for mobos, but I just don't see how it would be possible. The MB shouldn't do/add/contribute anything to anything. You can have a lousy PSU as well. yes You will see ...
The speed remains important though.
PS: are you already building ?
Hehe, I guess it is time to make a photo of the line up of stuff that is ready now. It will be a nice 20 meter or so row ...
But not finished yet.
« Reply #16 on: May 22, 2010, 08:19:05 pm »
Sheer impossible. I didn't test (swap) anything for mobos, but I just don't see how it would be possible. The MB shouldn't do/add/contribute anything to anything. You can have a lousy PSU as well.  You will see ...
Thnx Peter,
Thats all I needed to know, this is good news actually.
This makes it a whole lot easier to build a dedicated pc, good job.
So Gerard just keep this mobo, no problem.
I made the Winmate PSU choice because of same price range, high(er) efficiency, silence, separate ac/dc.
By the time you are maybe experimenting with pre room-correction, x-overs, filtering, dsp's and such
Then you might (maybe) consider a I7 chip (with a 1366 mobo or later innovations when available)
But before we get this going, that ill be another job. (several years of experimenting)
Happy clapping
« Reply #17 on: May 23, 2010, 08:06:48 am »
And then what ? Then you have divided your power into 8 pieces and playback can use 1/8 only. Unless you shut off hyper threading ...
